term ? locking the distributor....????
Discussion in 'The Hokey Ass Message Board' started by captmullette, Apr 15, 2013.
  1. captmullette
    captmullette
    have any of the drag racers here heard that term.....supposedly moves your timming to fire first on plug 6 on a sbc......thanks
  2. hotroddon
    hotroddon
    i have only heard that used when they lock out the advance completely
  3. captmullette
    captmullette
    good , bad, ????
  4. Flingdingo
    Flingdingo
    Locking the advance gives you one less thing to worry about. No weights or springs to stick or break during a run.
    It'll make the engine hard to start, but some of the timing boxes have a start retard feature built in.
    Definitely not something for an engine that sees a lot of street use, the advance mechanism helps with a lot of drivability issues during part throttle cruise or light acceleration, where a street engine spends most of its time.
  5. Mr48chev
    Timing it on 6 rather than one may be because 6 is easier to reach for someone.
    Firing order 1-8-4-3-6-5-7 2 puts 6 180 Degrees opposite of 1 in the firing order and the marks line up the same. It really makes no different if you use 1 or 6 to set the timing on that engine.
    And sometimes those things are just an old timer messing with your head.
    Doing a bit of searching I found that "locking" the advance at a set point is somewhat popular with guys who run drag only cars or cars with extreme engines that don't see a lot of street duty.
    No advantage or a disadvantage for a mild street engine but it might make a fairly radical engine easier to tune for wot use. A guy has to remember that a lot of things that work on highly modified engines or race only engines don't work worth a damn on mild street engines.
  6. hotroddon
    hotroddon
    Drag Race only where you are wide open only and moving advance isn't needed.
  7. ParkinsonSpeed
    ParkinsonSpeed
    I've seen super heavy weights for racing, kind of like plugging a carb up.... Some loose terminology for a quite simple racing term. IMO... As it was said, one less moving this is one less thing to break.
  8. captmullette
    captmullette
    im having my car worked on by a drag racer and that's what he has done. dizzy 180 out and carb,750cfm, blocked.... got me worried a little, its an old dirt track racing engine, can I run this setup on the street at all.......?
  9. captmullette
    captmullette
    by the way, im running a single 4 tunnel ram a560 something cam iron double humps.....
  10. ParkinsonSpeed
    ParkinsonSpeed
    I wouldn't run it on the street, you either have a drag car, fast-2mile to the gallon street car or a cruiser... Pick one. I prefer a quicker cruiser because in the long term it will be less wear and tear and you get to enjoy it more.
  11. Yes you can. If it starts hard or kicks back on the starter just wire a toggle switch on the ignition side so you can spin the motor over then hit the toggle to fire. I run my car like this it works great! 11.3-1,266/276 dur@.050 .730 lift,750 d.p.
  12. captmullette
    captmullette
    thanks, im excited and nervous, he said it will definitely rap up now....we'll see soon
  13. ParkinsonSpeed
    ParkinsonSpeed
    Yea it's not impossible, I had some issues with a 468 bbc in a off topic ride with the same race set-up when I was younger. I thought it was fun until I started to learn to advance and found the weight issue. Hope it works out!
  14. Pops1532
    Pops1532
    from Illinois
    Exactly.
    As for locking the advance....
    I did it on my circle track cars. I wouldn't do it on a street only car.
    Wire it so you can spin the starter then switch on the ignition once its turning over. Otherwise it will be real tough to start.
    How much advance is your engine guy telling you to run?
  15. captmullette
    captmullette
    32 degrees
  16. I Drag
    I Drag
    There's no real advantage to it. If the advance springs break, it will go to full advance instantly, which is the same as locked-out advance anyway.
    I also use a starter ****on to spin the motor and an ignition switch to light it. Easier on starters.
