Testing the waters. Possible chrome venture being considered.
Discussion in 'The Hokey Ass Message Board' started by Jimmy2s83, Sep 24, 2013.
  1. What about stripping chrome? Would you offer that as a service? I've found most local platers won't just strip, they want to then charge for replating the parts. A good example is a chromed part that needs welding or machining and needs the chrome stripped. If this is done in a different tank, do you have the same maximum size range as mentioned for your actual plating process?
    Thanks,
    Steve
  2. falcongeorge
    falcongeorge
    from BC
    I'm still working on my parts. Should say this next question is directed to jimmy2S83. Any advice on how best to fill the two draw marks by the green arrows? I was thinking silver solder?? or maybe braze? They are pretty deep to pick and file, and they are on both valve covers.
  3. falcongeorge
    falcongeorge
    from BC
    You can anodize aluminum at home with a battery charger.
  4. Jimmy2s83
    Jimmy2s83
    from Indiana
    Silver solder probaly a better (safer) avenue as it doesn't require the same heat as brazing which could warp the cover. I've seen it done both ways. With the thinner sheet steel I would just rather go with the solder for the better safe than sorry aproach.
  5. Lone Star Mopar
    Lone Star Mopar
    Im in, sent you a pm !
  6. falcongeorge
    falcongeorge
    from BC
    Thanks. Before I finish that area, I'll open 'em up a bit with a dremel, and fill them with silver solder.
  7. seb fontana
    seb fontana
    from ct
    I have read through this whole thread..I appreciate what the OP is doing, it will make many people have a whole new world of fabrication/creativity depending on how they finish the item, from a milled or belt sanded finish, crosshatch block sanded, or polished to a mirror finish with a rubber wheel on beveled edges...One question I have is can you plate up to a point [what will be seen] and then paint the rest [not seen area]? Like a wheel hoop [rim], since it will only be seen from the out side once the center is in..
  8. primerhotrod
    primerhotrod
    from ILLINOIS
    Do it the way you want it. Not what others tell you.
  9. falcongeorge
    falcongeorge
    from BC
    wtf???
  10. manyolcars
    manyolcars
    What I learned is that the preliminary process (acid??) eats away mild steel faster than br*** and leaves a awful line between the two materials. Possibly a plater who cares would make this less of a problem
  11. theHIGHLANDER
    theHIGHLANDER
    Diecast and aluminum require a specific copper 1st. Some parts tossed into the wrong solution will simple dissolve like sugar in hot water. The difference in cost is huge. I get confused on the 2 coppers used, there's acid copper and another form of copper as well. One is like a plater's "primer", the other a bright copper that almost like a sealer that can be polished to a mirror finish then bright nickel and off to chrome. None of it fills well with exception of the 1st copper I mentioned. With the price of copper being almost out of consideration it's easy to see why the prices for chrome services has risen so much. The EPA thing, that started to ******** the business decades ago. One of my local shops uses (I think) 'grey nickel' for polishing and finishes with bright nickel for shine. Chrome is so thin, if you could remove the layer you can damn near see through it. These are things I've learned over decades of show/restoration work.
    All of those concerns gone, I too might have some parts to send off soon. The good experiences far outweigh the bads in my history, but excess copper use was one of my peeves, parts that were simply too big to go back where they came from. If it's not too much to ask I'd like to hear how you're handling such concerns. I get the idea of reducing the hours needed to finish and promoting metal finishing in advance of the service. It's always been the time to finish that drives the price (labor hrs), then add the EPA and the spike in metal prices? I don't envy your choice to go for it but I hope it works out. For fill, low temp silver solder is indeed the best. It files and finishes nice, in the hands of an experienced finisher simply disappears once chromed. Again, time=$$$$ and better to spend/earn your own beforehand.
  12. Pics ?
  13. chubbie
    chubbie
    local guy did just that. low $ chrome small parts. he said they should fit in a 5 gallon pail. He spent alot of money on it and now it's setting unused. His mistake was he didn't sell the program as LOW $ every one thought it was a chrome shop!!! till they got their parts back.
  14. falcongeorge
    falcongeorge
    from BC
    Good to hear this from yet another source I trust. Chromeplater Josh mentioned silver solder to me off-board before, in regards to repairing a horn ring prior to plating. Still just thinking about that one, its gonna be a real ***** to repair, and its for a future project, so not a high priority right now. Silver solder is also a material that I am fairly comfortable working with, so its a win/win.
    I really like the idea of reducing my costs by doing my own metal finishing, as I find that as a general rule, work that I farm out isn't usually done with the same care I would give it anyway.
    A quick tip, if anyone has trouble finding different temp silver solder, I get mine from a place that sells jewelers supplies.
  15. Jimmy2s83
    Jimmy2s83
    from Indiana
    I'm still working on getting pictures posted.
    Just so much going on this month!
    I'll be in Detroit this weekend only to come back long enough to go to a Christmas Eve party.
    Once the New year is here I'll have much more free time to get things all sorted out.
    Thanks for the patience!
  16. This took 37 seconds on my ****ed up phone.
    Not chrome but seasonal scenery is ok to look with you guys to look at, right?
  17. theHIGHLANDER
    theHIGHLANDER
    She has a bit of a "*****y" look about her. I like that. Isn't she the one from USA Network's series "Suits"?
  18. alchemy
    alchemy
    Sorry for the delay on the pics. Here's the water pump he did for me. It was an old chromed job that was mostly peeled, so I blasted the remainder of the chrome off and sent it to Jimmy. I didn't want it polished in the nooks and crannies. I think it looks great, and will be sending more stuff to him when he's ready for full-blown production.
  19. Floorboardinit
    Floorboardinit
    Can I just say how great this is? Finally a lower cost option AND it's more true to 40's and 50's chrome work. I had been told of an older local guy that did backyard chrome work and that he did a "****py" job but all the traditional guys loved his work because it so closely resembled that of the old chrome work that was found at swap meets and on old hot rods. I look forward to doing an imperfect polish job on some smalls and sending them off for this gentleman to dip. I'm very much hoping this endeavor is as successful and I think it can be. JohnnA
  20. Lone Star Mopar
    Lone Star Mopar
    Im ready..
  21. I'm hoping this is still 'on'....
    Being a home polisher, I will say that understanding the prep process is critical. If this were a paint job, imagine not being allowed to use any filler, no primer, and you're putting the top coat over the bare metal... and you're only allowed one thin coat of paint. If the part will look good doing this, it will look good plated.
  22. cheesegrater
    cheesegrater
    from california
    The biggest problem is people "SAY" they want it "DOWN & Dirty" but once they get it they want a 100% perfect product at the "Down & Dirty price"
  23. cheesegrater
    cheesegrater
    from california
    A friend of mine had a very HIGH CL*** paint & body shop & I talked him into doing some "DOWN & DIRTY" paint jobs ( which he didnt want to do) where he would literally use a scotch brite pad & paint the car when the car came in it was numerous colors & when it left it was one color HAPPY HAPPY HAPPY& $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
  24. falcongeorge
    falcongeorge
    from BC
    Its really straightforward. Its down to how YOU prep the piece before you send it in. Whatever you get is a reflection :D of the quality of YOUR work.
  25. Floorboardinit
    Floorboardinit
    Exactly...there's no complaining allowed...it's a very simple premise. You get back what you put into it. And realistically if the part you want chromed is obscenely rare or valuably don't send it to the guy but it's a great opportunity to add some bling to you're smaller bits and pieces. JohnnyA
  26. ems customer service
    no epa nazi's,
  27. Jimmy2s83
    Jimmy2s83
    from Indiana
    Sorry for the delay guys! Working on a good address to have the parts sent to. My home address just won't work as I am gone all day at my job and don't want packages sitting out while I am away and unable to secure them.
    Getting a P.O. Box and checking on other options so UPS and FedEx can be used.
    Any ideas or recomendations on shipping options? Thought about putting a container that boxes could be put in at my house but hoping to avoid that. (as is the wife. LOL)
    On a side note I will peform mild refinishing on the parts but only a quick polish and shine before plating. No repairs, no heavy copper buffing, ect. Any deep pitting, gouges, ect will still be there. Only light pitting and scratches would be removed. So you don't "have" to polish them. Though I will say doing your own polishing to what you like will allow you to get the finish you put into it. Any defects left will only be highlighted in plating. Once again I can refinish the parts but not to a high end finish.
  28. dirt in ur beer
    dirt in ur beer
    This is a recipe for disaster ! One mans "oh it looks fine" is another mans "WTF ! "
  29. K13
    K13
    Nice first post.:mad:
  30. dirt in ur beer
    dirt in ur beer
    correct application of cyanide copper before the acid copper will not result in any etching or damage to your base material. You can actually apply acid copper directly over br*** because br*** is copper with zinc . always safe to hit it with cyanide copper first just to b safe.
