testing
Discussion in 'Questions & Suggestions' started by stealthcruiser, May 16, 2005.
  1. stealthcruiser
    stealthcruiser
  2. Tudor
    Tudor
    from GA
    keep after it old dog- new tricks aren't out of the question.
    here is what I do:
    find the file icon, then right click on it, pick edit photo
    it should open up in widows
    reduce the image size - then check photo attributes to see the size.
    If you aren't starting with huge 1MB files - meaning your camera is not set on fine- you can simply just open the file up and save it and it will reduce the size just by doing that.
    Let me know what your file size is that you are starting with.
