Event Coverage Texas Mile Lets play how fast will I go?
Discussion in 'The Hokey Ass Message Board' started by temper_mental, Mar 10, 2009.
  1. temper_mental
    temper_mental
    from Texas
    The heads are cast in Australia and the machine work is done in the states shipped bare.
    I bought them knowing I was using the blower not to worried about flow and also brought the weight down in the nose of my car.
    The motor is 13 to 1 with this pulley set up I am using.
  2. temper_mental
    temper_mental
    from Texas
    I hooked the chute to the four link attachment points worked out well. The body ride height is five to six inches.
  3. hahahahha, 135!??? thats all? ****, my old 54 dodge hooptie with a SBC will do 135
  4. FuelFC
    FuelFC
    Lets see aero of a small brick.
    But forgiving the minor aero a cool as hell car.
    Big enough motor. Well it could have been a little bigger. LOL ;)
    Watermelon sized balls.
    Gear choices til Tuesday.
    Lets see, carry the six, divide by 3, mulitply by 47, times radius of clinched puckered **** cheeks, plus weight of layden swallow and one hen weigh, log function, inverse obtuse angle of 37.4532 degrees, add 5, sun angle of three divided by barometric pressure and wind constant formula...equals.
    Prediction 158.6537594893425 or so. Calculator ran out of room to carry it any further.
    Good luck. Be safe. And check over everything after every run twice and then again for good measure.
    And write a damned Denise style story with lots of pictures please!
    Godspeed boy and please above all have fun and be careful.
  5. bonesy
    bonesy
    Good luck, be safe, I'm pulling for you.
    My guess is 135+ then you will have to lift.
  6. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    oops missed that earlier
  7. A 31 MO FO
    A 31 MO FO
    from D/FW
    I think 163. But Larry just do as some people have said and you will be fine. Have fun and be safe! Dennis and I will be there also, he will be in his blue chevy 55 will be our first time there. Shoud be a great time either way.
    Robert
  8. Thirdyfivepickup
    Thirdyfivepickup
    In one mile? From a dead stop? :confused:
  9. Kool Kat
    Kool Kat
    Get used to doing this.
    This is speedjunky's car and we have had it at the the mile the last 3 events. In this configuration, alcohol injected BBC with a 6 speed and 373 gears we broke a lot of **** and smoked the clutch.
    In this configuration the best we did was 172 back to back. But that was with skinney rear tires.
    There WILL be a 15 mph head wind.
  10. Thorkle Rod
    Thorkle Rod
    With my edumacation and utilizing my soupor math skills plus a pinch for the pucker factor say's 151.2
  11. Hoosier Daddy
    Hoosier Daddy
    Larry, Glen's right about where your tether is anchored for the chute. This is the first I've seen of your mount. The body only being 5-6 inches off of the ground may be lower than where your tether is anchored. If so, when deployed the chute will try to lift the rear of the body in pulling it's tether tight.
    Matt Lemons
  12. temper_mental
    temper_mental
    from Texas
    This will work out fine it mounts to the lowest part of the frame. I really have no other choices this is the best place to hook up the tether. And other wise it will make for a fun ride.:)
  13. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Dam......that looks like a whole lot of fun......I need to try this in the future !....Goodluck...Littleman
  14. Rocky
    Rocky
    Classified Editor
    My kid and I took his Porsche with a leetle bitty 2.5 litre turbocharged stock 4 banger to Bonneville and ran 157[before he put the BIG turbo on it] ...surely your blown big block can do 165 if it will stick on the ground.
    The Porsche did tend to wander around a bit over 150 on the salt but later we [after mounting the BIG turbo] took it road racing and I was navigating in the p***enger's seat at over 160 on asphalt....road was narrow and crowned and we had to keep it in the center of the road at 140 and over...it wanted to drift around a bit.
  15. 53OlderThanMe
    53OlderThanMe
    I'd guess somewhere between insanely fast and off your rocker fast.
    Good luck and stay SAFE!
  16. Hoosier Daddy
    Hoosier Daddy
    Small world, let me guess his name is Jeremy? He posts as 2bridges on Rennlist, got to be the same guy.
    I've been on those forums for over seven years. Sorry for the O.T. Larry...
  17. oh yeah, your right, dunno, prolly close though, not really much of a hoopti motor though.:D
  18. temper_mental
    temper_mental
    from Texas
    Checked the last things off my list for the car. Took the head lights off. Put the numbers on the door and mounted the video camera. Last chance to guess a speed.
  19. swade41
    swade41
    from Buffalo,NY
    I'll say 158, I think it'll skate around on ya, you got plenty of power but no weight to hold you down.
  20. Caretaker of the 41
    Caretaker of the 41
    I would like to guess 163, and can't wait for you to post the results!
    STAY IN THE THROTTLE until you know the sute is fully open then you will be able to tell if it lifts.....godspeed.
  21. draginsteel
    draginsteel
    I've done the math here:
    1:1 gear ratio in the transmissions highest gear x 2.68:1 ratio for the rear end x 98.171875" per tire revolution x 6000 RPM = 208.22 mph
    Figure a reduction of 40% for the total lack of aerodynamics and a 10% addition cause things are just bigger in Texas I figure 137.43 mph.
  22. senior fried
    senior fried
    Larry, I've seen your car run and it runs great, I know it will run faster than that, but my guess will be 154 mph. only because cars tend to act funny over 150 and that might be when I hope you get out of it, but I've seen you drive too... Good luck Man come home safe we have more drag racing to do. Dennis
  23. Big Tony
    Big Tony
    Good Luck and here is to many safe runs at ...144mph
  24. pecker head
    pecker head
    163 seems to be the magic number ! I hope you go faster bro , but be safe !
  25. gavonovich
    gavonovich
    I ran my stude at maxton with bags in the front. I didnt like how it felt and i was going pretty slow. (138) Gear is your friend on a mile. i would suggest 3.00 or lower. Im geussing you'll go 150ish.
  26. temper_mental
    temper_mental
    from Texas
    I have gears I will start out with the 268. If I need to I can go down259 or back up 299 335 380 414:)
    I changed out my pulleys and tuned the carbs I will be running ten pounds of boost. Car runs extremely healthy now.
    Not interested in killing my self but I will push the car to the limit to see how fast I can make it go.
    Ran 112 in the 1/8 mile no problems other than the tires breaking loose at the end of the track.
  27. gavonovich
    gavonovich
    Cool. sounds like you got it covered. One thing for sure, you're gunna have a blast.
  28. Kool Kat
    Kool Kat
    We put 300lbs of weight in the back of the sedan and went faster. Bring extra weight and 3/8 and 5/16 fuel line.
  29. bonesy
    bonesy
    So - how fast did you go? I'd love to see the footage from that camera.
  30. Rudy J
    Rudy J
    yeah . . that should be pretty cool
