TH 350 accumulator spring
Discussion in 'The Hokey Ass Message Board' started by Plyerz54, Nov 24, 2012.
  1. Plyerz54
    Plyerz54
    from Mpls
    Does anyone know if anyone makes a lighter than stock ac***ulator spring for a TH 350 ? B&M asks to remove it with the kit I have , but I'm not comfortable doing so . I've heard that can create problems . I would like to try a lighter one in it's place though .
  2. 56sedandelivery
    56sedandelivery
    I've heard of "stronger" ones, but never lighter. In fact, these break fairly often, so that may be the reason for heavier ones. I've also heard of using a piece of broom stick handle in it's place to block/lock it up (?). I have a replacement Sonnex spring, that's heavier, in my collection of HD parts for A TH350 I'll eventually put together. Deleting the spring would probably have the same effect as the broom stick trick. Butch/56sedandelivery.
  3. Plyerz54
    Plyerz54
    from Mpls
    My understanding is that removing the spring makes the shifts harder , and from what I've heard in some cases to the point of damage . That's why it seemed logical a lighter spring would still produce slightly harder shifts , but hopefully lessen the possibility of damage . I find it hard to believe I'm the first to think of this ( although I am a genius ..... lol ) so I hoped someone knew where to get one .
  4. HOTRODPRIMER
    HOTRODPRIMER
    All I know is that I broke a 350 transmission by leaving out aac***ulator spring resulting in shifting too hard,,almost like a drag racing transmission,,resulting in a broken gear. HRP
  5. Larry T
    Larry T
    Which kit do you have?
  6. Plyerz54
    Plyerz54
    from Mpls
    I'm actually making my own . drilling my stock plate , and using a sonnax line boosting valve.
  7. Plyerz54
    Plyerz54
    from Mpls
    I guess the " search " is still on . I was hopeful that someone had done this , and knew where to get one . Appears I'm on my own .......
  8. Mr4Speed
    Mr4Speed
    For a nice quick and firm second gear shift (not HARD like a B&M kit does) you will need "A" good ac***ulator spring, good line pressure, a good size feedhole in the seperator plate and good clearance in the clutch pack.
    If you have those it doesn't matter what spring you have.
  9. Larry T
    Larry T
    I've installed quite a few B&M Shift Kits in the past. It didn't take long to figure out the Heavy Duty set up was a LOT easier to live with than the Street/Strip set up.
    But I realize that doesn't help on your ac***ulator spring question.
  10. bigdav160
    bigdav160
    I have aways thrown them away. Never noticed that they shifted too hard.
  11. birdman42
    birdman42
    I have blown more than sprag apart doing that. Throw the B/M shift kit away and use the Supieror shift kit. Most ****** shops should be able to get that for you. It makes the vehicle launch forward instead slamming.
  12. Plyerz54
    Plyerz54
    from Mpls
    Your right Larry , guess maybe they don't exist . Just seemed like a logical solution .
  13. It won't shift too hard if you don't jack up the line pressure excessively and leave the check ball out.
    Not very hard to try it with your combination.
    Real world ? Yes, I have...Last one was a 455 wagon @4400 lbs. Towed my car trailer and ran 14.50's too, with a 2.73 rear
