TH/350 Fittings question
Discussion in 'The Hokey Ass Message Board' started by Fossil, Feb 12, 2007.
  1. Fossil
    Fossil
    I'm about to order the parts to replace the hard lines going to my ****** cooler with braided lines and fittings. Does anyone know the thread size for the ports on the side of a TH/350?
    -Scott
  2. Nick79
    Nick79
    from Austin, TX
  3. Fossil
    Fossil
    Thanks!
  4. hmmm..i've always used 1/4" NPT
  5. Thirdyfivepickup
    Thirdyfivepickup
    its a straight cut pipe... doesn't taper like a regular pipe thread. If you tighten it too much it WILL crack the case.
    I'd suggest using the br*** fittings in the case and adapting them to AN fittings. Aeroquip FCM2111 is 1/2-20 to -6AN (the br*** fitting is 1/2-20 I believe) that will adapt you from the trans to -6 line.
  6. 4woody
    4woody
    Mine has adapters, then 5/16 ( std., not -AN double flare) brake line for the hard lines.
  7. swade41
    swade41
    from Buffalo,NY
    This is how I did my 41 and it works great.
  8. Nick79
    Nick79
    from Austin, TX
    I'm also running the -6AN adapters to hard line. Lots O pressure in dem lines.
  9. spookydave
    spookydave
    This is some solid advice. The thread is a 9/16-18 straight. Some use a -6 to -6ORB (o ring boss) fitting but that's still not correct. The T350 case does not have the groove for the o ring to sit in as they seal with a crush washer. So seeing as you already have the br*** adapter in there with the crush washer crushed you might as well keep it.
    One other thing to add is you should use a teflon braided hose over the CPE (rubber) braided hose. The Teflon hose is rated for 450 degrees and the CPE is good for 250. Trans fluid is getting close to the max rating of the CPE hose and when you add some exhaust heat in the mix it's just a matter of time before you have problems.
    I make fittings and hose ***emblys for a living. If you have any questions or need any thing feel free to give me a ring. Just say you are from the HAMB and I'll hook you up. contact info is in my profile.
