Hot Rods TH-350 help
Discussion in 'The Hokey Ass Message Board' started by woodiewagon46, Aug 23, 2025.
  1. woodiewagon46
    woodiewagon46
    from New York
    About 20 years ago I had my gauges rewired by a company called American Cl***ic Restoration Inc. in Uxbridge MA. The device that bolts to the speedometer cable fitting on the tail shaft that converts it to an electronic signal to the new speedometer is leaking trans fluid and needs to be replaced. It has a tag on it with the numbers 59D-02392-1. The company is still listed, but never answers their phone. Anyone have any ideas where I can get one and what is it technically called?
    Tow Truck Tom likes this.
  2. Pulse generator. Some of the O rings are probably same as regular speedo drive.
  3. 51504bat
    51504bat
  4. gimpyshotrods
    gimpyshotrods
    Wipe it off and post a picture of it.
    HemiDeuce and Algoma56 like this.
  5. e1956v
    e1956v
    Alliance Vendor
    X2 on the o-ring
  6. Hotwyr
    Hotwyr
    There's also a seal internally on the "bullet" that goes into the tails haft housing. It seals to the driven gear. You may have to get one from trans shop since parts houses seem to have trouble locating it.
    Tow Truck Tom and rockable like this.
  7. woodiewagon46
    woodiewagon46
    from New York
    No, it's not the o-ring, it's internal, it's probably the seal that Hoywyr mentions.
  8. gimpyshotrods
    gimpyshotrods
  9. woodiewagon46
    woodiewagon46
    from New York
    Gimpy, similar to the top picture but plastic. I'll call Autometer tomorrow to see what they recommend. Thank you for your help!
    gimpyshotrods likes this.
  10. rockable
    rockable
    Fix the leak first. The pulse generator doesn't have anything to do with the leak. The leak, however, will ruin the pulse generator.
