Technical TH 350 ID
Discussion in 'The Hokey Ass Message Board' started by 48stude, Apr 1, 2016.
  1. 48stude
    48stude
    I'm thinking of using this trans in my Model A roadster. It's been sitting in my garage for over 25 yrs. I just power washed it off and I'm wondering if it's worth using. I noticed that it doesn't have a removable tailshaft. This was a good ****** when I took it out. I was thinking to have a ****** guy go through it,but if it's a ******* then I would have second thoughts. Thanks, Bill
  2. indyjps
    indyjps
    I'd at least replace front, rear seal and change filter and pan gasket. ****s pulling it back out for a couple dollar part.
    I'm sure more experienced transmission guys can also make recommendations, the parts above are about as far as I go into an auto trans.
  3. I'm not seeing a vacuum Modulator either. it is an oddball to me but that doesn't mean that you shouldn't use it.
    I would be interested in knowing ig it is a T350 or some other variation with an odd number that we are not accustomed to.
  4. HOTRODPRIMER
    HOTRODPRIMER
    How many bolts are in the pan? HRP
  5. redo32
    redo32
    I'm not the trans expert around here, but I think that is a TH200. Light duty trans from late 70's- early 80's. Don't put too much horsepower to it and it should(maybe?) be fine in a light Model A.
  6. HOTRODPRIMER
    HOTRODPRIMER
    I agree, If it has 11 pan bolts it would be a GM turbo 200 or 200c, manufactured from '76 - '87. HRP
  7. Gregg Pellicer
    Gregg Pellicer
    that is for sure a 200 c
  8. bobss396
    bobss396
    TH200 R4 it is. Still an OD unit. It may pay to have a shop look it over and I'd say a full rebuild may be the way to go. Some shops have a reasonable carry-in service.
  9. tazareno
    tazareno
    bobg1951chevy likes this.
  10. 48stude
    48stude
    Yup, It has 11 pan bolts. Here's the crazy thing, A guy gave me a 77 Impala which had a remanufactured motor( 350) and ******( I think from Sears) in it , which I took out and put in a 79 El Camino and ran until the body gave up. I rebuilt the 350 and it's been in a friends 36 Ford pickup for a good while . This is the same ****** that was in those two heavy vehicles with no problem. But since I'm using a tri-powered 327 in my roadster, I'm leery about using it . I knew you guys would nail this pretty quick and I thank you .:D:D Bill
  11. 56sedandelivery
    56sedandelivery
    They're (TH200) considered to be a "metric" trans. The Stock and Super Stock drag racers have taken to them due to their overall weight, internal rotating m***, and gearing. Of course, they are heavily modified to hold up. You're appears to have an electronic speedometer. Rebuild it, shift kit installation, and don't continually beat it like it's an ARMY mule, and it'll be fine. Do an online search for TH200 in drag racing.
    I am Butch/56sedandelivery.
  12. 48stude
    48stude
    Thanks Butch, I'm running a banjo rear with a Winters center section and 820-15 rear tire , neither like to be treated like an army mule:cool: Thanks again, I appreciate it. Bill
  13. gotta56forme
    gotta56forme
    from Seattle
    48stude: did you figure out from the measurements if it's a TH200 (not overdrive) or a TH200-4R (overdrive). I'm curious, since people said it was both in this thread.
    Gotta56forme/Scott
  14. mgtstumpy
    mgtstumpy
    TURBO HYDRAMATIC 200 (METRIC) http://www.700r4l60e.com/transmission_gm.html
    General Motors 1976 & Later
    11 Pan Bolts
    THM200 (TH200) - Light duty, "Metric" 3 speed transmission.
    Gear ratios on these units were 2.74 1st gear, 1.57 2nd gear, 1.00 3rd gear.
  15. Gregg Pellicer
    Gregg Pellicer
    wrong that is a 200c not a 200r4.It is a 3 speed not an OD trans. It is a good little trans though.Like the 700 4r and the 200r4 the TV cable adjustment is critical
  16. bobss396
    bobss396
    Do I get partial credit at least?
    kidcampbell71 likes this.
  17. 48stude
    48stude
    It's definitely not a OD transmission. Bill
  18. As Gregg mentioned above; THE TV CABLE ADJUSTMENT IS CRITICAL TO THE LIFE OF THIS TRANS.
    The cable is NOT a kick-down like a TH350, but a throttle pressure control. I burned one up after less then a mile due to a broken cable end.
  19. dan31
    dan31
    Maybe one of you transmission guys can answer this. Would a 200 4r live behind a 450-500 hp small block in a model a coupe?,is it the same trans used by grand nationals because i see them run 11 second runs all day but always hear that they are weak,so what is the real deal?
    caseywheels likes this.
  20. mgtstumpy
    mgtstumpy
  21. gimpyshotrods
    gimpyshotrods
    If it is a TH200. S**** value only.
    dan31 likes this.
  22. 48stude
    48stude
    For the time being , I've lost interest in using this transmission. That tv cable turns me off. I took a better look at that cable, until this thread enlightened me, I thought it was just a kick down . I see a spring for the pressure and an adjustment. Wouldn't look that great on a traditional style build. To be more blunt , it's fugly. But, it's certainly been an education for me and fun. Thanks again, Bill
