Th 350 lock up
Discussion in 'The Hokey Ass Message Board' started by dondogarage, Mar 13, 2014.
  1. dondogarage
    dondogarage
    from richmond
    Looking at a th350 today13 bolts, pan shape is like 350 vacuum modulator kick down cable. But driver side has a two wire plug that I was told was a lock down for the converter. If so are they any better than a standard 350
  2. fsae0607
    fsae0607
  3. dondogarage
    dondogarage
    from richmond
    look at the 350 lock up you suggested. Think I will look for a 700 r4 THANKS
  4. aaggie
    aaggie
    They are called a 350C with the lockup feature. You gain about 300 or so RPMs with the converter locked. It will work like a regular TH350 if you don't wire it up.
  5. squirrel
    The lock up converter really only helps mileage if you have ultra long rearend gears like 2.29s or something...that's what they were invented to work with
  6. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Had one in an OT truck, converter would sometimes lock and not unlock!
    Like trying to drive with a clutch that doesn't disengage, scary!
    KK
