Ive scoured the net and cannot seem to find width dimensions for a TH350, can anybody tell me the distances from the centerline of the main shaft to both the right and left side of the pan? I also need a dimension from the bottom of a stock pan to the centerline of the main shaft. Thanks
https://paceperformance.com/p-28983-gm-transmission-dimensions.html https://yourcovers.com/Merchant5/graphics/00000001/transmission-pans/9589webdim.jpg
that doesn't answer his question...but nice try. Driver side pan sticks out a bit over 6 inches, p*** side is right at 8 inches. The input shaft is at 7" high, output shaft is 5" high, with the trans sitting on the floor. The pan is angled vs. the centerline of the transmission. So, the pan distance to centerline varies, it's lower at the front than the rear, and is generally 6" to 6.5"
