TH350 help
Discussion in 'The Hokey Ass Message Board' started by Burny, Nov 13, 2005.
  1. Burny
    Burny
    AAAAAAGGGGGGHHHHHHH!
    ..that felt good
    I recently installed a 283 in front of a TH350. Now, because the trans seemed to be workin' fine before the new engine install, and the previous owner (a HAMBer) said it had about 10K on a rebuild, all I did was install a new seal, pan gasket and filter in this trans.
    The trans doesn't work...period. Don't know how to better describe it. I shift through the gears and "nada". Not one gear is being engaged. It's dead in the water...or at least dead in my garage.
    Now I keep going back to when I had the coverter out...I swear I never drained the trans fluid, but then, you never know for sure...I did sniff a little too much gas as a young child and I coulda forgot to fill it, if in fact I drained it.
    Do these symptoms match having not filled the torque coverter with fluid?
    Just want to know what to do next, before I haul it to the trans shop...
    Thanks.
  2. 50flathead
    50flathead
    from Iowa, USA
    Sure the converter in engaged correctly in the pump?
  3. squirrel
    the ****** will fill the converter with fluid all by itself when the engine is running, but you do need to add fluid to the trans. Tell us about how you've been checking the fluid level, ie engine running or not? what gear is it in? did you run it thru the gears before checking? did you look at both sides of the dipstick?
    how many quarts have you put in it?
  4. Burny
    Burny
    Pretty sure it seated correctly when i installed it...any ideas on how to check it?
    thanks
  5. CadillacKid
    CadillacKid
    Check your fluid level Schmo Jackson.....:)
  6. squirrel
    The converter should be a bit loose after you bolt the trans case to the block, before you bolt the converter to the flexplate. Should be 1/16" to 1/4" play front-back.
    Kind of hard to check once it's installed, you could pull the bolts off and see if it has the necessary play in it.
    Double check fluid level firsth, though, that's easier and more likely the problem
  7. Burny
    Burny
    I put 3.5 quarts in to start. Checked after running for about 5 minutes and running through the gears and it's smack in the middle. It was in Neutral when checking. I'm going to go run it again and see what it reads.
    thanks
  8. kb cookout
    kb cookout
    did you install the converter bolts :confused:
    sounds dumb but thought i ask
    later kb
  9. Burny
    Burny
    Rechecking now...I hopes it's something simple like this...thanks Chumly.
  10. Burny
    Burny
    Yep...
  11. plw
    plw
    A TH350 holds about 11.5 quarts.
  12. Burny
    Burny
    That's including what's in the TC-right? I read the stock pan's capacity is 4 Qts.
  13. squirrel
    Usually if you drain it, remove the pan, put it back togethr, and refill it, it will need about 4 qts. If the ****** has been out and the converter removed it will need more than 4 qts to fill it up, the exact amount depends on how much was drained. No way for us to know that.
    So it will need more than 4 quarts, but less than a case.
    You need to check the fluid level, add a pint and see if it comes up, if not then keep adding till it is definitely up above the "add" mark on both sides of the dipstick. Wipe the dipstick off before checking the level.
  14. Burny
    Burny
    Damn...Pulled the bolts of and turned the TC and "chunk" it dropped back towards the trans...It's got more like 1/4" of play. The bolts are out of thread at this point and if i tighten it back down it will pull the TC back towards motor...what to do? Do I get longer bolts and add shim between TC and flexplate? WTF did I do wrong? Install flexplate backwards?
  15. squirrel
    sounds ok to me....
    Did you try adding some more fluid to it?
  16. Bill.S
    Bill.S
    from NW OH
    Sounds like you didn't have it seated in the pump, don't use any shims just tighten up the bolts now and run and check the fluid.
  17. Burny
    Burny
    Hey, just sent you an Email---sorry 'bout that. Yeah I got about 5 qts in it now and it looks to be reading full. It has a Lokar aftermarket dipstick in it that looks real cool and all, but is a ***** to get a good reading off of. It seems to pick up fluid off the walls of the fill tube...
  18. Burny
    Burny
    Problem is I barely have enough thread to get a bolt on it and won't it pull the TC out of seating on the pump once tightened down?
  19. squirrel
    Push the TC back towards the engine. It is supposed to be against the engine, pulled out of the transmission about 1/4" when it's bolted to the flywheel. Otherwise it would grind up the front pump if it were pushed all the way into the trans when it's running.
    The lokar filler tube is probably the problem, they are a *****...stockers are much better if you can find one and make it fit.
  20. plw
    plw
    If it clunked in, I think you should be able to turn it. Do that, then pull it back alittle towards the flywheel and bolt it up. You should only have about 3/8ths inch play on the TC itself. Hope this helps.
  21. chopped
    chopped
    Take some sandpaper to the end of the Locar, it"s easier to read that way.
  22. Don't worry about installing the flexplate backwards - it'll still work, I had a truck come through here that had that exact condition (bak'ards flexplate), and it drove fine. Starter engaged wierdly, though...
    Cosmo
  23. Burny
    Burny
    Thanks, I'll try that.
  24. Burny
    Burny
    Thanks Cosmo...not sure if that's it though, 'cause the starter is engaging fine...
  25. Burny
    Burny
    ***UPDATE***
    Got everything bolted up again and fired her up...still nothing. Now, the vehicle is a bare bones T modified and I have the trans tunnel cover off, so I can see the top of the transmission. I can see where the Lokar fill tube goes in, so i get an idea. I'll pop out the fill tube and I'll be able to tell for sure if there's enough fluid in the pan. Well, there's enough fluid alright...a bubblin crude...
    Seems to me like not enough fluid aint it...
    Could the pump be bad?
