Technical TH350 in 40 Ford
Discussion in 'Traditional Hot Rods' started by Smart62, Feb 23, 2021.
  1. Smart62
    Smart62
    from UK Sussex
    Hi would greatly appreciate some input on installing the TH350 in my 40 Ford Coupe. Fitted a TCI split wishbone kit and bolted in the trans ok. But trans pan hits the rails. Is it safe to cut them away a bit? Should the pan miss the rails and I have it set up wrong? Or would a spacer below the trans mount sort it? What did you guys do? Cheers Smart
  2. 40Standard
    40Standard
    from Indy
    can you use a shim or two?
  3. Weedburner 40
    Weedburner 40
    You can trim the lower flange on the X-member or shim the trans up. You may need to trim the flange anyway to facilitate pan removal.
  4. da34guy
    da34guy
    X2 what Weedburner40 said.
  5. i.rant
    i.rant
    X3 What Weedburner suggests. Had to do this on a 37 Ford I had for pan removal and never a problem afterwards.
  6. Smart62
    Smart62
    from UK Sussex
    Thanks for your help guys. Good to know I'll be doing it right.
  7. warhorseracing
    warhorseracing
    from cameron wv
    Some more hype that those shivrolas fit like a glove. Just cut grind or bash it with a BFH to make it fit.
  8. Mr48chev
    Show us your Ford in a 40 Ford photos. Or are you another of those Ford in a Ford guys who has never put a Ford in a Ford. Seems we here the talk but never see the photos.
    dirty old man, okiedokie and Budget36 like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I notched the X member just enough to clear the pan, that's normal. HRP
  10. warhorseracing
    warhorseracing
    from cameron wv
    All of my Fords have Ford engines in them. My '51 Shoebox has a Flat Head V8. My '55 T-Bird has a 302. My Wife's '62 Falcon has a 200 Straight Six. My '34 Three Window has a 351 Cleveland. My '64 F250 4X4 has a 460. My '35 4X4 Pick up has a Flat Head V8. My '29 Briggs 4 Door has the original Banger. I did have a OT '66 Impala with a ford 390 back in the '70's that ended up tearing the rear end loose from the car. That engine came from a 'OT66 Fairlane that met a tree sideways. Well, I do not currently own any '40 Fords but if I did it would be Ford powered. I have other Fords that are Ford powered that are OT for this site so there is your answer. Every shivrola in a Ford installer says "How easy they just slide in, like they were made for em ,wire em up, fire em up." While the truth is butchery and destruction of the original vehicle suffers. Admit it they are not just a "Drop in". Too many installers have let the cat out of the bag. So, there ya go.
    RmK57 likes this.
  11. Roothawg
    Roothawg
    I always trim mine to clear the pan. You don’t have to, but it makes your life easier in the future.
    okiedokie likes this.
  12. Nitroholic
    Nitroholic
    from SoCal
    I notched the lower frame rail in the X-member for easy pan removal and then I added a removable piece of flat stock to the rail to maintain integrity. I don't know if that was necessary but I figured it couldn't hurt.
    TrailerTrashToo likes this.
  13. Budget36
    Budget36
    I’m not trying to argue, but bare with me. My 36 Ford PU had a 265 in it with a Hurst mount up front. The truck was set up with a Muncie 4 speed before I got it. Anyways, I wanted the Ford in a Ford thing, and in order to sit the 302 in it, I had to cut out the firewall, now at the time I didn’t know about other solutions, but as it was the Ford in a Ford was still hacking up the truck.
    I never liked it like that. So pulled the 302 and am glad I saved the piece I cut out, but even if it would have fit, the C4 I had would still take the same bite out of the x-member.
    The SBC drops right it is in fact true, but even if a another engine would, any “modern” ****** would require some work to fit.
    Nitroholic likes this.
  14. 40Standard
    40Standard
    from Indy
    I used 2 shims on the trans mount
  15. warhorseracing
    warhorseracing
    from cameron wv
    crying face.gif Good!
  16. Budget36
    Budget36
    You the only one shedding tears;)
    Is it okay if I put a 318 in my '36? Ooops, sorry
    What gets me is the car and your **** won't know what's moving it down the road.
    Heck, I'm fine with seeing a FHV8 in a Vette, car is moving, right?
  17. warhorseracing
    warhorseracing
    from cameron wv
    Those are YOUR tears man.
  18. Budget36
    Budget36
