TH350 leak
Discussion in 'The Hokey Ass Message Board' started by BaBa, Aug 19, 2013.
  1. BaBa
    BaBa
    When I started thinking about building my truck, I had the TH350 rebuilt that was going to go into it. Trouble is the project didn't start for 15 tears. Now that the truck is finished, the trans leaks, probably from sitting around all those years the seals dried out.
    Most of the leaking seems to be in front near the torque converter so I think it is the input seal?
    Is this something that can be easily fixed or do I need to take it back to a trans shop?
  2. Pull the tranny and replace the seal, or pay someone else to do it for you.
  3. birdman42
    birdman42
    Could also be the o ring around the pump. I saw that a lot when I was working in a tranny shop. Pull the pump and do a complete reseal.
  4. deto
    deto
    also make sure its not leaking out where the kick down cable goes into the trans above the pan.
  5. saltflats
    saltflats
    from Missouri
    If it is leaking will it is just setting its probable the o ring around the pump.
    You may need some help with this if you dont know all the tricks.
  6. EZ Cool
    EZ Cool
    Alliance Vendor
    from Slaton TX
    over time the fluid will leak out of the torque converter into the pan over filling it. Then it will leak from the dip stick tube and/or the kickdown cable. Driving it regularly will keep this from happening. And like mentioned it could be the front pump oring or seal.
  7. d2_willys
    d2_willys
    from Kansas
    Dipstick tube o-ring is dried up.
  8. BaBa
    BaBa
    It seems to be leaking out of the converter cover. When there is a drop at the small hole in the cover, when you wipe it away another drop forms at the hole.
  9. d2_willys
    d2_willys
    from Kansas
    take the inspection cover off and wipe down the inside of the bell housing. Then using an inspection mirror see where the leak is coming from. If it is running down the inside of the bell housing, then it probably is either the front seal or the pump gasket.
  10. jfreakofkorn
    jfreakofkorn
    i agree w/ willys
    isnt to bad replacing ( the seal or the gasket ), once the tranny is out .....
  11. Replace three parts: large o-ring, pump gasket and front seal (for torque converter) make sure there is no rust or pitting on the torque converter hub.
  12. hoop98
    hoop98
    from Texas
    Daarn, just when I know the answer I'm late to the party...what Rick and others said pump oring get's hard ...replace the 3 pieces
  13. d2_willys
    d2_willys
    from Kansas
    Here is some good advice: When the transmission is out, replace the following too:
    Second gear accumulator cover o-ring (These things go bad, especially if near exhaust)
    Rear seal
    If ambitous, replace vacuum modulator o-ring, governor seal, linkage seals, speedo seal.
    Make sure vent is clean too.
    IOW's, reseal it!
