th350 no reverse
Discussion in 'The Hokey Ass Message Board' started by BORRACHO13, Jul 1, 2013.
  1. BORRACHO13
    BORRACHO13
    from Menifee CA
    i have rebuilt th350 trans in my 50 chev with 327.
    the car will go forward in gear but no reverse.
    we cannot roll the car back either. the drive shaft spins only one way and locks up if you go the other way.
    is there anything i may have installed incorrectly to cause this?
    its my first th350 build so i am lost and open to suggestions
  2. MATACONCEPTS
    MATACONCEPTS
    Don't Drink & Rebuild?
  3. 37gmc
    37gmc
    from upstate ny
    sounds like roller sprag backwards
  4. BORRACHO13
    BORRACHO13
    from Menifee CA
    Thanks will have to open up and check the sprag.
  5. J scow
    J scow
    from Seattle
    You flipped the one way sprag.
  6. J scow
    J scow
    from Seattle
    Sorry I didn't read far enough.
  7. manyolcars
    manyolcars
    What is wrong with a 350 when it freewheels in second?
    It pulls in all gears and only freewheels when slowing down in second
  8. BORRACHO13
    BORRACHO13
    from Menifee CA
    ok so i took the th350 back out. i pulled it apart and checked the sprag. it is turning clockwise and locks counter at this time. that is looking straight down into trans. is that installed correctly?
    i did not disassemble the sprag but do not know if it was correct when i got it
    from what i read it is very hard to install backwards, i have not taken it apart to verify
    does any one have a link to a powerflow chart or something?
    thanks in advance
  9. BORRACHO13
    BORRACHO13
    from Menifee CA
    any input anyone
  10. Baumi
    Baumi
    It should turn freely when rotated counterclockwise... says the manual
    here are the scans
  11. Baumi
    Baumi
    The trouble shooting chart offers the following options:
    Low oil pressure-check with oil pressure gauge for abnormally low oil pressure
    intermediate servo malfunction-remove pan and valvebody, check for stuck or cocked servo piston, damaged piston bore or seal rings
    faulty 2-3 accumulator on 350, 350C and 375-check for damaged or worn 2-3 accumulator seal rings
    intermediate band malfunction-remove transmission,check for band seating, band wear or broken welds on band
  12. saltflats
    saltflats
    from Missouri
    Check the forward clutch make sure its not to tight
  13. BORRACHO13
    BORRACHO13
    from Menifee CA
    I think the pic is for the 'forward' sprag at the front of the trans
    i am asking about the sprag at the center of the trans, at the center support which attaches to the output shaft.
    when the rear of the trans is assembled and i try to spin the output shaft, it will lock up on the sprag. will turn freely forward but will lock the output shaft if i try to spin it the other way.
    i can not even push my car in reverse.
    is that normal? shouldnt the output shaft spin in either direction when trans not engaged?
  14. BORRACHO13
    BORRACHO13
    from Menifee CA
    this question does not even relate to what i am asking about?
  15. saltflats
    saltflats
    from Missouri
    Do you have clearance in all your clutch packs?
  16. saltflats
    saltflats
    from Missouri
    The inner race of the center sprag should turn clock wise.
    Once you have that installed can you turn your output shaft both direction?
  17. OldFord39
    OldFord39
    from Monroe, Wi
    I can't come up with a good picture right now! It would indicate that the low reverse roller clutch or the Intermediate roller clutch are installed upside down, but that would be very hard to do. if you look at the low roller jpg its outer contour should fit the ramp of the reverse clutch support (TH350lowsupportcasesaver.jpg) on the outside and the intermediate roller clutch (TH350directdrumsprag.jpg)should follow the same contour of the ramp except it would be on the ID not OD like the low roller. By the way a 350 uses roller clutches and not sprags there is a difference; I borrowed these pictures from a web site and did not re label the TH350directdrumsprag.jpg You will not be able to turn the output shaft in one direction by hand but can with a channel lock pliers.
  18. BORRACHO13
    BORRACHO13
    from Menifee CA
    The center hub of the low/reverse one-way roller clutch, will spin CW but not counterCW
    With the one way sprag and sungear installed, the output shaft only spins CW.
  19. BORRACHO13
    BORRACHO13
    from Menifee CA
    When i get home i will need to pull apart the one-way clutch and insp the direction of the ramps.
    both the intermediate and low/reverse one-way rollers, spin in CW direction only?
  20. OldFord39
    OldFord39
    from Monroe, Wi
    As saltflats also indicated check your clutch clearances; as a rule of thumb when I used to rebuild for a living I would give .005 to .008" per friction plate so 5 plates .025 to .040 "thousands" I would rather be toward the .040". On the low reverse piston with the valve body out there was a hole in which you could see the piston I would mark this with a scribe and then apply air and then scribe again and look for the clearance.
    Regarding the roller clutches the springs will be at the top of the ramp and the rollers at the bottom of the ramp.
  21. BORRACHO13
    BORRACHO13
    from Menifee CA
    i took the roller clutch apart and it appears to be installed correctly.
    inspecting my trans, i noticed that the case saver (anticlunk spring) was rubbing on the drum in front of it. the case saver does not sit down all the way either. it is partially sitting on the snap ring holding intermediate plate to case, is that normal? prob not
  22. saltflats
    saltflats
    from Missouri
    Not sure I under stand cant think of a drum close to that spring.
    Did you buy a case saver center support?
  23. BORRACHO13
    BORRACHO13
    from Menifee CA
    sorry i mean the sun gear bell, is that what its called? the bell between both sun gears..
    i didnt buy the case saver, that is what was already in it.
    i am rebuilding this trans for the first time. i was told trans was bad from PO but he did not know what it needed. the trans has been worked on before, not by me. i do not know who built it last but i was not sure of the work performed. some clutches were installed friction to friction metal to metal, governer gear broken, upshift cable broken and not connected at v-body, etc. etc,,
    so now i am trying to build a 350, never having worked on one, and parts may be missing and or installed improperly before, and i have no experience nor another trans to compare this one to. i have rebuilt many trans at work at a dealership but no 350.
  24. saltflats
    saltflats
    from Missouri
    If you have not been in one before you may be better off to find one that has not been fucked with.
    Makes the learning curve much easier.
    If you got an O/H kit you can reuse those parts.
  25. BORRACHO13
    BORRACHO13
    from Menifee CA
    thats exactly where i think i am about now..
    thanks for all the help and info fellas
