Technical TH350 Question
Discussion in 'The Hokey Ass Message Board' started by Anthony Riley, Mar 13, 2025.
  1. Anthony Riley
    Anthony Riley
    Hey guys I’ve got a question. I recently picked up a TH350. The guy told me it shifted great. The only issue he had was at 80mph his engine was running at 7-8000rpm. He said a shop told him it was a bad torque converter. I dropped the pan and found some tiny metal shavings on the magnet. The fluid looked good and the filter was clean. I don’t know a lot about transmissions so I figured I’d ask you guys what you thought.
  2. Budget36
    Budget36
    I think his tach was set to 4cylinder not 8
    03GMCSonoma, mad mikey, Paulz and 5 others like this.
  3. squirrel
    Put it in, see how it works. Metal shavings seem to be pretty normal in used TH350 transmissions.
    RMcCulley likes this.
  4. If you put it in and it doesn't go into but will go into reverse it's likely the valve body. Ran into that with the th350 currently in my 53. Was a supposedly rebuilt trans we picked up for a customer car. Put it in said customer car and the highest it'd go was 2nd. Shifted great 1-2 and 2-1 but it'd stop at 2nd. Went into reverse fine too. Turns out the rebuild just consisted of new clutches and a slightly higher stall converter. Boss sourced another used th350 that worked and I bought the 2 speed th350. A b and m "stage 1" shift kit later(cheapest way to get everything to overhaul the valve body) and it crisply shifts into all gears. Decided then any th350 I get will get a shift kit
  5. saltflats
    saltflats
    from Missouri
    How hard is it to install it? If easy try it out.
    mad mikey likes this.
  6. 05snopro440
    05snopro440
    I bought a $50 TH350 off our local cl***ifieds site a dozen years ago, in a garage in an alley in the dark. It works great and has a shift kit in it.
    I have doubts the engine was actually at 7-8,000 RPM. Put it in and see if it works.
    mad mikey and The Chevy Pope like this.
  7. Kevin Ardinger
    Kevin Ardinger
    Before you put it in, I would probably pop the governor out and make sure the gears not broken. It’s plastic. While you have it out, hold the governor up with the weights on the bottom. Collapsed the weights in and out and see it valve in the middle moves. I would also probably make sure the vacuum modulator is good. Other than that, you’re gonna have to put it in and see what happens, if you do put a torque converter in it, get a good one. Don’t buy some Daaco **** from the parts store.
    verno30 likes this.
  8. Anthony Riley
    Anthony Riley
    Guy I got it from told me he had the governor recently replaced along with speedo gear and modulator. I’m going to be putting this in my 60 C10 with a 283. I’m going to pull the old straight six out. So I’m planning to just get a new converter and adding a shift kit.
  9. Anthony Riley
    Anthony Riley
    Will be pretty easy. I am pulling the old straight six and 3spd out of my 60 c10 and putting a 283 and th350 in.
  10. squirrel
    so you'll have to figure out the crossmembers...perhaps remove the one that currently supports the bellhousing, and add one for the back of the engine, and you'll also need to add side mounts for the engine, instead of the front mounts it had.
    rod1, mad mikey and Truckdoctor Andy like this.
  11. Anthony Riley
    Anthony Riley
    Yea Ive got a custom crossmember from CaptainFab coming. I just received the 67-72 motor mounts yesterday. I will have to remove the current crossmember.
  12. squirrel
    The frame changed in 63, hope you got mounts that work with a 60-62 frame.
  13. Anthony Riley
    Anthony Riley
    Yes CaptainFab told me he always recommends the 67-72 C10 side mounts. Says worst case is I have to add a 1/4" spacer on top of the frame. The trans mount he makes for the 60-62 swb for a TH350 bolts into existing frame holes so will make side mount locating easier. https://customfab-cda.com/ Thats his website. He has supplied alot of custom parts for guys with C10s.
    dogwalkin and squirrel like this.
  14. BJR
    BJR
    With a name like CaptainFab the parts have to be good. :p:D:p
  15. lumpy 63
    lumpy 63
    His parts are actually pretty nice:D
  16. Kevin Ardinger
    Kevin Ardinger
    I would probably check it anyway. Make sure it’s free. Depending on the shift kit you may have to change the springs in it anyway. Biggest thing is just don’t get some junk cheap converter! Then you will end up with metal in the pan.
  17. 19Eddy30
    19Eddy30
    from VA
    Like @Kevin Ardinger said ,
    Check Governor gear also , easy to do.
    I recently Lost 2 & 3rd on Fresh build ,
    Governor was set up too tight !
    A ATI Built trains from Md ,
    First Time that I experienced this ,
    There should only be around
    .010-.020 tho Clarence between
    Cover & governor,
    The Non OEM gear I installed after
    Stripped a Tooth , Replacement Gear was .100 tho to long &
    .010 tho to round , Needed to be
    File & sanded to OEM Spec .
    The RPM's mention above sounds Unrealistic on Average parts used in a engine to Exceed the 7K & North of ,
  18. jaracer
    jaracer
    A 350 has a non-lockup convertor. There just isn't too much to go wrong inside the convertor. If the stator clutch locks up you would have a hard time getting any high rpm out of the engine and the trans would probably overheat. If the stator clutch slips, you won't get any torque multiplication at low speed. It would be a dog on take off. About the only other thing to fail would be the thrust washer for the turbine. If that fails it acts like a really high stall speed convertor. It would take a good amount of rpm to get the car moving.
  19. jaracer
    jaracer
    I should add that if I bought a used THM 350, the first thing I would do would be to dis***emble it for inspection. I'd be hard pressed to put into something without making sure it was up to parr.
  20. Anthony Riley
    Anthony Riley
    I don’t know anything about the inner workings of a transmission. I’d be worried I would screw something up putting it back.
  21. 19Eddy30
    19Eddy30
    from VA
    Knowledge of working needed & required on Automatics ,
    Not like a Manuel,
    There is a few unique tools also needed .
    This book is worth the $20
    mad mikey and leon bee like this.
  22. Jokester
    Jokester
    TH350 are not too complicated. Good way to learn. Get a good manual and tear into it.
    .bjb
  23. squirrel
    In my experience, every TH350 has something wrong inside it...including the ones that still work...
    but you can also just put it in and try it.
    The Chevy Pope and Budget36 like this.
  24. hepme
    hepme
    "80 mph running at 7000-8000"
    Hell with the trans, what's the engine?????
    05snopro440 and RMcCulley like this.
  25. squirrel
    Might have been exaggerating, folks today think that if an engine is turning more than 2000 rpm at highway speeds, it's gonna blow up
  26. 19Eddy30
    19Eddy30
    from VA
    A few weeks ago I drove my Supercharged home 1-1/2 Or 2 miles
    @ 3000 Rpms in 1st gear , @ 45 ish Mph It sounded Like 6,500
    The converter is real tight ,
    I use a tight converter with small tires set up , & big tire I use 4,500
  27. bill gruendeman
    bill gruendeman
    Are you it’s in 3 rd gear and not in second?
  28. Anthony Riley
    Anthony Riley
    I don’t know I am just going off what I was told.
  29. Check the governor.
    Google search for how to check th350 governor,
    There are several videos.
  30. 05snopro440
    05snopro440
    Drove my 46 all the way to Seattle and back with the 455 Buick and TH400. Runs at just about 3,000 rpm at 75 MPH. You're right, over 2,000 rpm at highway speeds scares people now. Many people just shouldn't have tachs.
    427 sleeper likes this.
