Hot Rods TH350 - Sounds like Marbles .....
Discussion in 'The Hokey Ass Message Board' started by ricklove, Mar 20, 2016.
  1. ricklove
    ricklove
    Had a rebuilt TH350 installed last June (less than 5k miles ago). No problems until yesterday coming home from 200 mile trip. About 30 miles from home, started hearing what sounded like "marbles" as it shifted into 2nd gear. First few times time, the sound was very short, but as I continued to drive, it got louder and and longer when in 2nd. No symptoms of slippage, and only noise is in 2nd gear. Checked fluid when I got home; a tad low, so I added fluid and drove around the block. Still sounds as bad as previously. Coincidently, my brake master shows slight sign of leakage, and pedal does not always return to full up position by itself. Any ideas?? Many thanks!!
  2. Boyd Wylie
    Boyd Wylie
    First thing: take off the pan and look for lumps and chunks.Drain the fluid into a white or light coloured pan,and look for metal shaving in the fluid.
  3. Check the ring gear to torque converter bolts.
    hipster likes this.
  4. saltflats
    saltflats
    from Missouri
    Sounds like a problem with the sprag
    Does it make the noise if you have the shifter in second
  5. squirrel
    take it apart, take some pictures....
    should be entertaining.
    David Gersic and hipster like this.
  6. This was my thought as well.
  7. hipster
    hipster
    All of the above- & your master cylinder needs replacing.
    Sent from my SM-G900V using H.A.M.B. mobile app
  8. Jalopy Joker
    Jalopy Joker
    warranty on trans?
  9. falcongeorge
    falcongeorge
    from BC
    Loose ring gear bolts will make noise at idle as well. If the noise is in second gear ONLY, I concur with the guys that are saying sprag.
    hipster likes this.
  10. ricklove
    ricklove
    Work was completed and paid for 15 Jun 15, and 12 mo/12k miles warranty was written on receipt by shop. Gonna trailer it up there 1st thing in the morning. We'll see what happens. Many thanks to all for what I figured ....... nothing simple or easy. Thanks!!
    hipster likes this.
  11. 56sedandelivery
    56sedandelivery
    Sounds like the intermediate sprag race has broken/cracked/shattered (different variations of severity). If that's it, will need a complete rebuild and upgrading to a better race (some shops do that anyway). I am Butch/56sedandelivery.
    hipster likes this.
  12. Did you look to see if all your torque converter bolts are in place and tight?
  13. Old TFFdriver
    Old TFFdriver
    I had a parking "pall" not sure is that is correct spelling but it broke the end off and it rolled around in the pan and it sounded like " marbles " and only did it on certain situations.
