Hot Rods Th350 transmission issue
Discussion in 'The Hokey Ass Message Board' started by Greg Lechuga, Aug 20, 2015.
  1. Greg Lechuga
    Greg Lechuga
    Hey guys having a problem when I come to a stop my c10 is dropping into low gear without me doing anything! As soon as I take off boom it drops down into low, and also my Trans shift linkage comes off at Trans as well! Any help on what to check would be appreciated before I take to shop to get it checked out
  2. Lcats
    Lcats
    Maybe check the trans mount?
  3. cshades
    cshades
    from wi
    Is it actually manually shifting it into low gear? If it is I would look at the motor and trans mounts to see if they are moving enough to make the shift linkage move/disconnect.
  4. onetrickpony
    onetrickpony
    from Texas
    Yep, sounds like a broken mount to me, too.
  5. Greg Lechuga
    Greg Lechuga
    Thanks for the replies guys I will get back to you with what it was, any suggestions on what kind of transmission mounts I should use if it is broken.
  6. Greg Lechuga
    Greg Lechuga
    Yes it is manually shifting into low gear itself! Just been a hell of a issue
  7. onetrickpony
    onetrickpony
    from Texas
    Check the motor mounts,too. Usually it's the left ones that break, then the movement breaks the trans mount.
    Greg Lechuga likes this.
  8. Greg Lechuga
    Greg Lechuga
    I will definitely do that guys thanks for your responses!
  9. Easy way to check mounts. Two people to do safely. One watch the motor from the side, and one put it in gear, and brake torque the motor forward then reverse.
    If the motor mount is bad the motor will pick upon the left side in drive and right up in reverse. Is it a column shift, and the linkage at the shift lever comes look real close at the trans mount.
  10. Greg Lechuga
    Greg Lechuga
    Thank u for your response I go home tomorrow and I will check all these things out! Finally found a no ******** site to get real answers, thanks
