Technical TH350 Transmission Mount Bolts
Discussion in 'Traditional Hot Rods' started by dwleo, Jun 9, 2017.
  1. dwleo
    dwleo
    Hi guys,
    As I wind down to my inspection date (June 15) I am replacing my mechanical fuel pump for an electric one as I could not overcome the drip of fuel from the fittings. I am also wriggling underneath and rechecking all bolts for tightness and re-torqueing those that require torqueing. And what did I find? I neglected to install the two bolts that go from the transmission cross member to secure the rubber mount. The bolts are in place from the mount to the transmission (th350).
    Does anyone happen to know the thread and length of these bolts?
    Thanks.
    - Daryl
  2. ididntdoit1960
    ididntdoit1960
    from Western MA
    usually a 7/16 co**** thread
  3. Sheep Dip
    Sheep Dip
    from Central Ca
    They are roughly about 5/8" long ....7/16-14
    Stick a welding rod up there for proper length and test with proper bolt/thread pitch
  4. squirrel
    some of them are metric, just to make it more interesting...but try the 5/8" first. And they like to get rubber stuck in the threads when they make them, so the bolt might not screw in easily.
  5. dwleo
    dwleo
    Hi Guys,
    I found a couple of bolts in my bolt drawer that were the right size.
    Thanks for all the info.
