Technical TH350
Discussion in 'Traditional Hot Rods' started by Forty-eighter, Mar 10, 2021.
  1. Forty-eighter
    Forty-eighter
    from Indy
    Does the TH350 simply go straight back & straight forward or are there slots, catches for the shifter to go into? Just certain gears?
    Thanks.
  2. Budget36
    Budget36
    There’s a pawl/comb in there with detent nubs on it. I had one come loose once. You can see it when you pull the pan
  3. 19Eddy30
    19Eddy30
    from VA
    Like Bugget36 said , if you take the linkage or cable off @ trans, use your hand You will have Park when you move arm/ linkage about 1 inch movement will be R short click N another short click D same for 2 &1 . Or if reversible body will be the same Except P R N 1 2 D
    Either which way he will fill clicks on the transmission.
    If you do not feel clicks ,drop pan you will see flat spring stock with a roller that rides the detents/ notches .
    Some gear shifter's will have gates but not typically on OEM gear selector's
    squirrel likes this.
  4. 19Eddy30
    19Eddy30
    from VA
