Customs TH400 problem....?
Discussion in 'The Hokey Ass Message Board' started by airbrushguy, Aug 21, 2021.
  1. airbrushguy
    airbrushguy
    from NJ
    Finally at the stage of road testing my 1949 Hudson project.
    Installed a running 500ci engine that I took out of a 18K original owner '76 Coupe de Ville, drove the car to my yard (felt great).
    Starts and runs fine, new custom one-piece driveshaft Ididit column, Lokar column shifter....but when I put it in gear (on the lift) I need to rev it up to about 2000RPM before I get the wheels to turn.
    Brought it down to ground and it moved a little in reverse but not enough to get over lift ramp then put it in Drive and wouldn't go forward at all.
    The trans has a new filter and fluid....any ideas?
    Thanks in advance...
  2. 67drake
    67drake
    from Muscoda WI
    It will do that if fluid level is low.
    swade41 and squirrel like this.
  3. saltflats
    saltflats
    from Missouri
    Filter pick up tube not sealing?
    Elcohaulic and Kevin Ardinger like this.
  4. greybeard360
    greybeard360
    Low fluid... Shift linkage not adjusted correctly.
  5. squirrel
    Describe your fluid level checking procedure.
    gimpyshotrods and anthony myrick like this.
  6. If it was fine before you touched it, check everything you touched first.
    Fluid level
    Shifter linkage
    Modulator line
    Converter
    Filter placement
    my th400 acted the same way. Fluid level was low.
    Deuces likes this.
  7. Mr48chev
    ______________________________________________________________________
    This first!!
    Plus did you use the same dipstick and tube that it had in it from the start?
    Did you check it while running after you fired it up?
    gimpyshotrods and Deuces like this.
  8. airbrushguy
    airbrushguy
    from NJ
    Same dipstick and tube (original)
    Checked fluid with engine running.
  9. Kevin Ardinger
    Kevin Ardinger
    Like saltflats said probably ****ing air. Put two o rings on the filter pickup. Make sure they fit snug in the pump. Also, if it’s a daycron type ( cloth like element) filter chuck it. I’ve seen them brand new won’t flow. Probably been damp in the box. Put a wire mesh/Allison type filter in it.
    jimmy six likes this.
  10. squirrel
    Did you move the shifter through all the gears, then check it again?
    And did you look carefully at the dipstick? both sides? They can be tricky. I usually end up checking the level several times, and get it so it gets up to the "full cold" line, or the bottom of the crosshatch if it has one, then go for a drive, and check it again hot.
    If you're sure it's filled, then you might need to pull the pan and look at the pickup tube again, make sure the O ring is in place at the top of it.
    Driver50x likes this.
  11. Inked Monkey
    Inked Monkey
    When mine did that it ended up being the pump. Hope you have better luck.
  12. greybeard360
    greybeard360
    How long did the trans sit after being pulled from the Cadillac?
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Just so you know, not all TH400s are created equal.
    For myself I would leave it with 'the guy' who know how to build them.
