Technical Th400 vacuum
Discussion in 'Traditional Hot Rods' started by Mikey67, Nov 5, 2022.
  1. Mikey67
    Mikey67
    I have a th400 and a tunnel ram with no vacuum ports. Question where do I get my vacuum from for modulator valve. Thanks.
  2. mad mikey
    mad mikey
    What carbs are you running? You should be able to tap into a vac port for manifold vac on one of the carbs or a single carb if that is your set up.
    gimpyshotrods likes this.
  3. Mikey67
    Mikey67
    Single holley 650 dp.
  4. mad mikey
    mad mikey
    There should be a vac. port for manifold vac. on the front left side.
  5. Kevin Ardinger
    Kevin Ardinger
    If there are no ports on the carburetors may be consider spacer plate under the carburetors with a vacuum port. Or, convert the 400 to full manual and forget about the vacuum.
    Algoma56 likes this.
  6. You could also find a spacer plate that has a vacuum port in it. Some 60's Ford came from the factory with them. Aftermarket ones are available.
    I was typing this while @Kevin Ardinger was posting!
  7. mad mikey
    mad mikey
    The 650 dp should have the vac. ports in the front . Rht side is timed vac. lft is manifold vac.
  8. sdluck
    sdluck
    Algoma56 and jimmy six like this.
  9. squirrel
    drilling and tapping a hole in the intake is apparently too much work.... :)
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    Walls of a tunnel ram manifold in some spots are awfully thin to drill & tap , easiest way out is a spacer plate IMO.
  11. Illustrious Hector
    Illustrious Hector
    2old2fast's idea eliminates removal of the manifold to avoid drill chip contamination. Factory uses direct manifold vacuum, seems to work, so....
