Technical TH475 slip yoke conversion
Discussion in 'The Hokey Ass Message Board' started by Apache Albert, Jul 27, 2020.
  1. 38Chevy454
    38Chevy454
    A driveshaft ***y with the slip yoke does not require a carrier bearing. A carrier bearing is needed when you have more than one driveshaft ***y.
  2. Ebbsspeed
    Ebbsspeed
    Nope, they don't need a carrier bearing. I think that's more a requirement based on length of the driveshaft than anything else.
  3. Apache Albert
    Apache Albert
    I think I know what I'm going to do then :cool:
    I'll keep this forum active until I make a definitive decision and show ya'll the work.
  4. 38Chevy454
    38Chevy454
    If it matters, the splined part of the slip yoke driveshaft ***embly points to the rearend. That's just the way they are set up.
    Sent from dumb operator on a smart phone
  5. Apache Albert
    Apache Albert
    Yes, I knew the direction the slip should be pointing but it's a good refresher.
    After coming to a consensus with pops, it looks like we're going to do the bolt in yoke! Now to continue pestering HAMB: is there an existing bolt in the yoke that uses the th475 brake extension housing that is shorter? Or should I just grab a standard roller bearing or bushing truck tail housing with a standard truck yoke?
    I measured the RV yoke at close to 10 lbs and needs 1410 joints lol.
