Projects Thames Resurrection
Discussion in 'The Hokey Ass Message Board' started by GlassThamesDoug, Nov 1, 2022.
  1. GlassThamesDoug
    GlassThamesDoug
    Back to baseline rims.
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  3. GlassThamesDoug
    GlassThamesDoug
    15 x 8.5 Americans.
    Have Ansens for front..
  4. 05snopro440
    05snopro440
    On a car, wire nuts are not your friend. With the vibration of the car they're at high risk of arcing and burning something. Please don't use them on cars. There are a lot of much better solutions.
    I understand if you have nostalgia that your dad used them, but they don't belong on a car.
  5. GlassThamesDoug
    GlassThamesDoug
    Looking at a weatherpak kit. I need plugs to unhook separate components, and the gl*** front end.
    05snopro440 likes this.
  6. 05snopro440
    05snopro440
    Weather Pack will work. You could consider Deutsch connectors as well.
  7. GlassThamesDoug
    GlassThamesDoug
    Running on 8 cyl after plug fouling. Running previously like valves hanging up. Pulled valve covers, top end too dry for my liking.
    Now to T/S top end oiling. Oiled fine with roller cam, and T&D rockers.
    Lifters to rockers ... engine oil pressure is strong 60psi at 180deg.
  8. GlassThamesDoug
    GlassThamesDoug
    Trans Throwout bearing needed swapped, after putting street soft clutch in, was not enough linkage stroke. Used my trans dowels, slid back Muncie, swapped to my next longer T Brg. Good to go.
    8in dowels allow clutch fork, or T Brg swaps.
    20240821_132536.jpg 20240821_132500.jpg 20240821_141045.jpg 20240821_132448.jpg
  9. GlassThamesDoug
    GlassThamesDoug
    Field trial tomorrow.
    T******* clearance around shifter.
    Heat and bend new shifter.
  10. GlassThamesDoug
    GlassThamesDoug
    Finally after 4 yrs, it moves under its
    own power.
  11. GlassThamesDoug
    GlassThamesDoug
    More pics, it's still a little *******.
    20240822_153946.jpg 20240822_153933.jpg 20240822_154016.jpg 20240822_154009.jpg 20240822_154051.jpg
  12. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    May it stay that way.
  13. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Your gonna have to go get more water for the well if you keep washing everything.
    Looking good.
    GlassThamesDoug likes this.
  14. GlassThamesDoug
    GlassThamesDoug
    She's the best well on this road. When she is slow, everybody hauls water.
    Water is 1 cent /gal at tower. It takes quarters too
    chryslerfan55, catdad49 and brEad like this.
  15. GlassThamesDoug
    GlassThamesDoug
    Now do I heat and bend a $100 Hurst chrome shifter, or find another piece of **** brand, cut, drill bend..... now I go look in shifter pile. Or next swap meet.
  16. GlassThamesDoug
    GlassThamesDoug
    Looking for speedo the cable ... :) hanging on a nail somewhere.
  17. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Doug you had one that had a neat little hook kinda up the handle some.
    You sent me a pic of about ten. Lol
    427 sleeper and porkshop like this.
  18. GlassThamesDoug
    GlassThamesDoug
    Sold it at swap meet.
    Someone said it was perfect for Mopar B Body.
  19. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Now that sounds like something I would do. Lol
  20. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Get another one /off brand or I actually cut one out of 3/8 flat aluminum once. Even managed to thread the end for a knob. Worked pretty slick.
  21. GlassThamesDoug
    GlassThamesDoug
    Found what looks like a Camaro offset shifter unknown history. Might be a swap meet rattle can rebuild. Might be able to swap it out, or go with brand new NOS shifter, and bend a handle.
    chryslerfan55 and brEad like this.
  22. mkubacak
    mkubacak
    I don't believe shocks are designed to limit suspension travel. You need limiting straps.
    Tickety Boo and GlassThamesDoug like this.
  23. GlassThamesDoug
    GlassThamesDoug
    Other things:
    I need to add 2x additional rear shocks.
    New Tank Fire Wall ... cover for fuel tank in back.
    2x rear tires that hold air.... funny 2x old MT tubes hold air....
    Connect Turn Signals back up, wiring is there,
    catdad49, brEad and loudbang like this.
  24. catdad49
    catdad49
    It’s the little things that make it…… interesting! We are going to need a “down the road” video pretty soon.
  25. GlassThamesDoug
    GlassThamesDoug
    I did buy a Go Pro camera with my points...
    Need to see ch***is movement and front axle if the resonance occurs.
    My road.... buddy stopped by pickup my s**** pile, his 1ton dually got beat up trying to get up hill. He thought I was joking.... hopefully after city water comes down road, they might pave it. Brutal washboard gravel, dirt Road.
    brEad and catdad49 like this.
  26. GlassThamesDoug
    GlassThamesDoug
    City (rural) water almost here. Halfway across property. In most cases lately, they pave road after its installed.
    Small shop is white building in background.
    brEad, catdad49 and 427 sleeper like this.
  27. Greg Rogers
    Greg Rogers
    Love your thread- Great car- I would love it but prolly couldn't fit in it!
  28. GlassThamesDoug
    GlassThamesDoug
    I fit, but 6ft2in. In NHRA legal condition, 5ft 8in would be ideal. With automatic & reconfigure steering would be plenty of room. You can see mustang steering box is under floor. I have been planning vegà box up front to cross steer, then can move steering forward, thru firewall.
  29. catdad49
    catdad49
    Guess what? I just happen to be 5’8”!
  30. GlassThamesDoug
    GlassThamesDoug
    I will let you make a p***...
    5'8" you fit with clutch, stick shift.
    I have a power glide I have not installed. Would make it much easier to operate.
    THE FRENCHTOWN FLYER likes this.
