Technical Thanksgiving Table Discussion Drilling Brake Drums-Oh Oh!
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Nov 28, 2024.
  1. Jack E/NJ
    Jack E/NJ
    from NJ
    Think these'll work. 1-1/2" thread length.
    2OLD2FAST likes this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No M&M’s. Only SAE candy please.
    Also, 12.8mm (.504”) knurl is too small.
    41 GMC K-18, alanp561 and Sharpone like this.
  3. Just drill, some drums are quite sloppy around the hole, make sure it's not an interference fit or you might not get the drum back off.
    saltflats and Sharpone like this.
  4. RodStRace
    RodStRace
    therobredracer, alanp561 and Sharpone like this.
  5. 2devilles
    2devilles
    Anytime I need a lug stud, I just head down to the local NAPA and my parts guy buddies pull out the old school catalog. They've got pages and pages of studs available and they're pictured to scale, so I can just take the old one down and match it up to the pic, or figure out what I need if it's different from what I've got....and if that doesn't work, just drill the drum. It's not like it's got some magic hardening material that is only the size of the hole that's already drilled.
  6. I had to get longer studs in my '41 with a tri 5 rear. I looked all over and came up with the same on as Johnny, but I have a lathe. I've made split collar to hold things in the past.
    I think you'll be fine opening up the drum if you're going to use those lug nuts in your previous post.
    Johnny Gee likes this.
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    alanp561 likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No brake drums were harmed in any way after all @seb fontana. IMG_3500.jpeg IMG_3502.jpeg
    dwollam, alanp561, Deuces and 6 others like this.
  9. Clydesdale
    Clydesdale
    Who needs a lathe eh!!!!
  10. seb fontana
    seb fontana
    from ct
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    RodStRace, 427 sleeper and Sharpone like this.
  12. jimmy six
    jimmy six
    Gorilla sells lugs with the added reach into the aluminum wheels that only use a taper to attach them.
    I will NOT use lugs without the extended threaded part going into the wheel!
  13. Sharpone
    Sharpone
    Deuces, Deutscher and 427 sleeper like this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have them.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    now lets some pics of the car with its new Cragars on it.....
    Deuces, Sharpone and 427 sleeper like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Gotta pull it out and do the other side. Locked in at the moment. Gotta pull it out of the garage (passenger side just inch’s from the wall, red 56 behind it covered, then daily truck behind that) so I can finish up. You know the feeling.
    Sharpone, Moriarity and 427 sleeper like this.
  17. 427 sleeper
    427 sleeper
    Hey Johnny, not to change the subject, but weren't those studs supposed to be swedged into the flange after install? Maybe that's the reason for the extra shank length. Not that it makes a whole lot of difference now.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Happy to say. Since fronts are direct bolt mag shank style, no lug swapping required. Heck, back side of wheel design even allows brake drum rivets to remain. One less thing to deal with.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No. It’s just that the correct replacements only come in 1” of exposed thread.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
  21. Moriarity
    Moriarity
    SUPER MODERATOR
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Doing some clearanceing at the moment since the wheel opening tapers inward at the rear half of the tires vertical centerline. At the moment that’s a 5mm/.197” wheel spacer. After trimming I’ll see about moving tire away from leaf spring a tiny bit more? IMG_3510.jpeg
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Cut and touched up crudely with paint given to me from previous owner of the 57. IMG_3511.jpeg IMG_3512.jpeg
