Projects the '27 Roadster saga
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 20, 2010.
  1. Paul
    Paul
    Editor
    I don't know yet, I would also think the more glass above the notch the more stress and possiblity of cracking from wind pressure.
  2. I don't think the notches are a good idea. A square corner may be a spot that could crack, if it was likely to crack, that would be the place. I'd try a test drive with the plexiglass to see how the wind goes over your head, and it may give you a little idea of flexing, although the safety glass will be stronger. Maybe ask the glass shop their opinion?
  3. LB+1
    LB+1
    from 71291
    Tape some string and push some air at it - Anything for a poor mans wind tunnel
  4. Paul
    Paul
    Editor
    Whisky Tango Foxtrot over
  5. LB+1
    LB+1
    from 71291
    don"t for get the damn tick marks - OVER
  6. atch
    atch
    i've never had a roadster, but on my h-d i had the windshield cut down to where i'm looking over it, but just barely. about all of the wind goes over my head and most of the bugs/rain/etc. do too. i like it a lot better that way than looking through it.
    don't know if this would translate to a car or not, but it's a thought.
    b-t-w; i've been following this from the beginning. i like it a lot.
  7. alchemy
    alchemy
    Leave the plexi in and drive it a while. If the plexi cracks, the glass would probably crack too.
  8. -Brent-
    -Brent-
    I think you'll be okay with laminated glass. If the notch was rounded it may help remove some of that stress at the corner. I actually think it'll hold up well, there's not that much glass above the notch to be an issue. That's my opinion, anyhow.
  9. jonathan
    jonathan
    from Phoenix,AZ
    Any pictures of how the rear of the body is attached/supported to the frame? Is it sitting on the rear crossmember?
  10. Boones
    Boones
    from Kent, Wa
    Paul, that is looking good, would never have thought about having the glass above the stantions.. now i have to reconsider my windshield shape on my 27 Modified
  11. LB+1
    LB+1
    from 71291
    You know I bet he cranked that baby up and is some were pushing real cool air at. {;-)
  12. Paul
    Paul
    Editor
    got the windshield back from the local glass shop,
    I had them cut and grind the corners to avoid any sharp inside corners
    and leave just enough to let the frame caps cover
    they said they couldn't polish the edge but I'm going to try to smooth it a bit.
    here is the glass just sitting loose in the frame,
    it will get set with black silicone.
    oliver westlund and brEad like this.
  13. Paul
    Paul
    Editor
    the rear frame connector of the sub rails hangs behind the rear cross member
    the sub rail is notched to sit on the ends of the crossmember
    I will take pictures as that area gets finished up
  14. LB+1
    LB+1
    from 71291
    I like the look of lets say " Thought " on the windshield / windscreen?
    Are you going to use a strip of emery dry on the smoothing or?
  15. Paul
    Paul
    Editor
    don't know yet, gotta think about it for a minute
  16. LB+1
    LB+1
    from 71291
    LOL - I have to think myself out of here and go do some bracing work on my fishing pier
  17. youngster
    youngster
    from Minnesota
    You might want to give setting tape some thought for the windshield glass. With the tape there is no movement. Not so with the silicone. If you where running a top channel then the silicone would be OK.
    I used 100grit wet n dry paper to polish mine. Then 220 and finially 400 grit.
    Ron
  18. -Brent-
    -Brent-
    I want to know what's in the bucket in the windshield reflection, Paul? :D
  19. Paul
    Paul
    Editor
    two arms a leg and a torso
    brEad likes this.
  20. Paul
    Paul
    Editor
    got the radiator back yesterday too,
  21. daddio211
    daddio211
    Windshield looks PERFECT and its just how I planned to do mine. Almond oil works great for polishing the edges!
  22. jonathan
    jonathan
    from Phoenix,AZ
    Great! Thank you. I just picked up a turtle deck for mine. The rails that come off the back of the body that the deck sits on, were excised from my little roadster some time ago . . .
  23. thunderbirdesq
    thunderbirdesq
  24. kisam
    kisam
    Looking good Paul!
  25. PRB
    PRB
    from Az
    Nice detail on the glass....altogether a really balanced look
  26. Paul
    Paul
    Editor
    was trying to find a picture, didn't he use a curved windshield out of a volkwagen square back or something?
    Archiewest likes this.
  27. jonathan
    jonathan
    from Phoenix,AZ
    This one maybe?
    Ulrich Wöckener likes this.
  28. youngster
    youngster
    from Minnesota
    That's Mago's first '27 roadster. After he got his shop up and running he build a clone of that car.
    Ron
  29. Dennis Lacy
    Dennis Lacy
    In my car I removed the seat riser completely and have a 3" foam cushion right on the floor with a 1" foam under that in the original floor pan that goes under the seat. I'm 5'10" and look right through the middle of the glass when seated. The top of my windshield glass goes straight across and even with the caps on the frame.
    I have spent a whole day in the car and have no complaints as far as comfort goes.
  30. iammarvin
    iammarvin
    from Tulare, Ca
    What the fuck does that mean?
    And by the way, hide the bodies better next time.:eek:
    Good job, really like windshield notch.
