Customs The '41 Merc chop......(((NEW PICS)))
Discussion in 'The Hokey Ass Message Board' started by Pete, Mar 18, 2012.
  1. Pete,I hope you do not construe the "criticism" from the folks here on your chop as an insult.
    It IS- well intended and coming from a good source of custom knowledge, such as Rikster.....
    We all just think for all the time and work involved -everyone- should end up with the best looking results possible.
    I can attest to not liking advice myself,but when it is good advice ,one should consider that ,and check out the possibilities both ways to see what it can end up like.
    I'll say this -then I will back out and let you make your own bed....
    My advice would be to stop where you are in your cuts and before final welding re cut the rear roof and move the rear window opening rearwards a couple three inches and in the process -correct the flow- of the roofline there.... the qtr window is a bit too short in height and length....[bunched up]
    also cutting the rear half of the quarter window loose and lengthening it the 2" or so will net a big improvemnet in looks...
    a slight lessening of the angle of your doortop will also help.
    Having said that, I like everyone else, never want to hear of redoing anything either,
    but its .......a long time ugly...... if you do not make it pretty now while still unfinished...
  2. Slick Willy
    Slick Willy
    Ya, but thats the same way you feel about me!...:(
  3. flash
    flash
    I should be working...but this is way more fun...here it is with a longer rear quarter window (just to satisfy my own curiosity).
  4. flash
    flash
    ...and now with a little more meat added back to the C pillar.
  5. exStreamliner
    exStreamliner
    Easier PhotoShopped than actually making all the changes in steel... but, I like the longer rear window too
  6. NoSurf
    NoSurf
    Except from me.
    :D:):D
  7. Pete
    Pete
    Im on the hunt for some door tops, Fords are the same..
    4 door, tudor or coupe, just need the tops...
    Drop me a PM if you have some.
    Pete-
  8. flash
    flash
    Ahem...Pete...I got what you need buddy. Did you forget about the '48 I hacked up in Colony junkyard before they closed!
  9. billys54
    billys54
  10. hotdamn
    hotdamn
    any progress?
  11. Pete
    Pete
    Im on the hunt for the door tops, have a few local leads and a few other long distance leads.
    I moved the rear window up and down, sloped the bottom up....but just didnt like it so I kept it the way it was. I did start making pieces for the quarter windows and the filler pieces for the rear of the roof.
    Pete-
    Pics to follow soon.
  12. Pete?^^^^^^^^^^^^^^^^^^^^^^^^
    I like that last shot but not the rearward shrinking door gl***.
  13. Pete
    Pete
    I tried it both ways and really liked it better this way, it'll look different that all of the other cars at the shows.
    Pete-
  14. NoSurf
    NoSurf
    Doesn't Keith drive a "pother" custom? Or was that Paras?
  15. Slick Willy
    Slick Willy
    Ya? Is that a new hipster term??
  16. Pete
    Pete
    That's it exactly! Well said.
    Damn! You guys are tough! I meant panther cars!
    Pete-
  17. Phe's pspeaking pin Ppete pLatin.
  18. Pete, there is no need of getting other door tops and them being wasted on your chop,Just clamp and line yours- up, as you cut and form the missing part with some 1/8" bar stock and peices of sheet metal over the voids,weld and grind and no one will know it didnt grow that way......I never use other door tops on any chop I have ever done......
    ,not necessary and is actually more work slicing and dicing the other door chunks to fit than make them from scratch....
  19. Pete
    Pete
    Ohh, that's how you do it, learn something new every day.
  20. Pete
    Pete
    SOme updates.
    Spent yesterday and today at the shop, yesterday I just stared at the Merc and didnt love it.....so I made some changes today.
    I lowered the front of the roof again, remember I cut 5 out of the front and then added 1 inch back in. So I re-removed the 1 inch, raised the B-pillar 1/2 inch, this brought the C-pillar up about 3 inches which gave me the sweep I needed in the rear and shortened the package tray and enlarged the quarter windows.
    I still plan to keep the factory "crease" around the window.
    Pete-
  21. drcwright
    drcwright
    Are you gonna use the moldings? If not, I'm interested in them. PM me, thanks
  22. NoSurf
    NoSurf
  23. Baron
    Baron
    Roof line and window openings look much better this way. Looking good.
  24. Pete
    Pete
    I agree, Sometimes you have to just sit back and look.....and look some more...maybe a little more.
    Pete-
  25. Pete
    Pete
    Anybody have some tail light ideas???
    Pete-
  26. sko_ford
    sko_ford
    Bumper gaurd lites
  27. Baron
    Baron
    Or something like these. Plain a simple, and don't detract from the lines of the body.
  28. hotdamn
    hotdamn
    50 buick bumperettes :)
    I have always thought a set of hudson's, the shields, I think they are 49's? would look good.
    Also a set of 47 caddy bumperettes with lenses put in them.
    I have a set if you get interested, They're pretty rad...
  29. Hotaling
    Hotaling
    from lubbock,Tx
    my thinking is pic #7 is looking pretty dang good. keep up the hard work man.
  30. Slick Willy
    Slick Willy
    1950 Packard tail lights, the models with the short chrome wrap around. custom 8's and converts? maybe
