History the 427 Mystery, mystery
Discussion in 'The Hokey Ass Message Board' started by porknbeaner, Feb 24, 2016.
Tags:
  1. seb fontana
    seb fontana
    from ct
    Yep, them is the two...
  2. falcongeorge
    falcongeorge
    from BC
    the bores on the Mark IV gaskets are notched for valve clearance.
  3. seb fontana
    seb fontana
    from ct
    Neither look to have round bores..
  4. falcongeorge
    falcongeorge
    from BC
    Yes, I noticed that too.
  5. I had a big block 402, and it was out of an early 70s 1/2 ton. I don't know for certain, but back in the day, I was told that, in some models, if you ordered the 400 2bbl, you got the small block. If you ordered the 4bbl, you got the big block. I didn't much care, because I was only interested in big block engines.
    loudbang and scruff like this.
  6. I saw one in Vancouver in 1963. It was listed as a 427/435 horse and it was fast. I had no idea how special it was at the time. Couldn't have been that expensive, a longshoreman owned it :)
  7. jimmy six
    jimmy six
    That's funny.... In 1963 the guys I knew with the most $$$$ in the pockets were Longshoremen. Like was stated some actually showed up a dealerships. The guy could just walked in at the right time wanting a 63 409 and bought a true Z11.... If it just could have been a Biscayne with no back seat or operating rear windows....
  8. It is too long ago to remember the exact model of the car, I only saw it and talked to the guy a few times while I was working as a gas jockey.
    I was in love with the W engines because one of my buddies had a 409/409, and it went like stink.
  9. mgtstumpy
    mgtstumpy
    The base price of a 1963 Impala was $2774.00. Adding the price of the R.P.O. Z-11 option of $1240.00 to that brings the total price just over $4000.00 not including destination charges, taxes, etc. http://www.348-409.com/z11.html
    • Produced only in 1963
    • The R.P.O. Z-11 option was an additional $1240.00
    • Shipping weight-3245 lbs.
    • Curb weight-3405 lbs.
    • 57 Z-11 Impala's were produced
    • Modified 409 engine rated at 430hp@6000 RPM's. (Actual horsepower was 480-525)
    • Block casting #3830814. Code "QM"
    • Block part number #3838253
    • Cylinder Heads #3837731 2.19 intake/1.72 exhaust
    • Valve Covers #3837739 (left), #3837740 (right)
    • Oil pan (deep sump) #3816322
    • 2 piece Intake manifold #3830623 (top)-#3837733 (bottom)
    • Waterpump #3837691 (aluminum)
    • Cam #3837736 .556 intake/.556 exhaust lift with 325 duration
    • Crankshaft #3837472
    • Distributor #1111023
    • Coil #1115107
    • Generator #1100628
    • Starter #1107274
    • 3.65" piston stroke
    • 4.3125" bore (same as 409)
    • 13.5:1 compression ratio
    • Special cowl induction air cleaner #6418986, #3839764 (duct)
    • Tach (redlined at 6200 rpm's)
    • Borg Warner T-10 4 speed transmission (close ratio)
    • Special posi rear with 4.11:1 rear gear ratio
    • Sintered metallic brake shoes
    • Screened rear brake backing plates with air scoops
    • 15 X 5.5 wheels with 6.70 X 15 bias ply tires
    • Front coil springs #3824693
    • Rear coil springs #3824694
    • Deleted front sway bar
    • Optional sound proofing and insulation delete on most
    • Optional heater delete on most
    • Hood #3837710 (aluminum)
    • Hood catch #3837718 (aluminum)
    • Grill filler panel #3837750 (aluminum)
    • Left fender #3837765 (aluminum)
    • Right fender #3837766 (aluminum)
    • Front bumper center #3837751 (aluminum)
    • Front bumper LH #3837755 (aluminum)
    • Front bumper RH #3837756 (aluminum)
    • Rear bumper center #3837752 (aluminum)
    • Rear bumper LH #3837753 (aluminum)
    • Rear bumper RH #3837754 (aluminum)
    • Front bumper bracket LH #3837763 (aluminum)
    • Front bumper bracket RH #3837764 (aluminum)
    • Rear bumper bracket LH #3837757 (aluminum)
    • Rear bumper bracket RH #3837758 (aluminum)
    • Rear frame to bumper brace LH #3837759 (aluminum)
    • Rear frame to bumper brace RH #3837760 (aluminum)
  10. It was more than that in Canada because of the import duty. I don't know know how much duty, but I think it was 25 %
