Projects The 48 hour coupe
Discussion in 'Traditional Hot Rods' started by redzula, Jun 12, 2023.
  1. redzula
    redzula
    Also I apparently didnt look very hard at all at the end of these header tubes pretty obvious that its just a chunk in there that needs beat out. Socket and a hammer and it moved a bit. A few more minutes and they were both out.
    Tim, Deutscher, Thor1 and 1 other person like this.
  2. redzula
    redzula
    Y'all know i still try for that thousand word milestone. Lol
    Tim, Thor1 and Outback like this.
  3. Outback
    Outback
    from NE Vic, Oz
    Good, didn't think they would be fixed in there
  4. redzula
    redzula
    With me seemingly getting close to the first actual drive. I figured I'd better check and change fluids.
    Went out after work today and started with the rear end. Found out right away that the square hole in the drain plug is neither a 1/2" or a 3/8" so a rachet wasnt going to work. While googling to see what size it is and start looking for a tool i came across a post saying that you could use a pipe plug with the raised square. Dont know what size it is but I had a few in my stash of plumbing **** and I can confirm at least on this axle it worked. I'll try to figure out what size and if I do I'll post it here incase it could be of use to someone in the future. Pipe plug shoved into the hole. Pipe wrench on the threads side and they both came out easy.
    After that I did the transmission. That had regular fill and drain plugs. But also was over filled so when I pulled the fill plug a bunch of oil came out. I decided i wanted to look inside the trans to see if there were any big red flags. And also would make it easier to refill the oil instead of trying to squeeze it in through the fill. Trans looked ok.
    Ugly welded the s**** pedal that came with the car onto the pedal ***embly I installed. Its ugly but it works.
    Then I decided to tackle the parking brake and making that work. I started with issue #1 the brake handle and shifter touch in 3rd gear. I redrilled the holes in the brake mount to lower it a little. Still touched so i bent the shifter a little more than i had before. And moved onto the linkage that was attached to the brake handle. It had a loop on one end that had been broken and bent. So I heated and bent that back into shape and welded it together.
    fail #1 - I soon realized that that loop end I fixed wasnt even going to work with the cable equalizer.
    Thankfully The equalizer piece i got from third Gen a while ago actually came with the end thatbworks with the equalized and takes a 5/16 fine threaded rod. So I found a bolt in my bin that was the same size. Put the equalizer on the cable and lined up the rod on the handle and found out I would basically be left with just the clevis part of the shaft that came with the handle. So cut that part off and drilled a hole in it for the bolt I found that was the right thread and welded the bolt into the clevis to make a very short adjustable link.
    fail #2 - I cut too much off and now it was too short. So the brakes were still engaged while the brake was "released"
    Attempt #3 I has what I think is part of the throttle from the Model A frame i picked up last year. It had the 5/16 fine thread on one end as well as a clevis that would fit the brake handle and a jamb nut. So I cut the threaded part off to make a short piece of all thread. To go between the clevis and the equalizer fitting and the jamb nu to prevent the rod from spinning itself out of one side from vibration while driving.
    And the brake works well now.
    Had a pretty productive night so a left it at that.
  5. redzula
    redzula
    Pulled the radiator and finished draining the coolant and flushing the radiator last night... (there isnt a pet**** to drain it that way)
    Changed the engine oil and reinstalled and refilled the radiator.
    This morning I had a little debate with myself over whether I should try for a test drive now with the nurse tank strapped to the visor. Or of i should tackle flushing and cleaning the fuel tank. Running new lines and hoses from tank to engine. I decided to go with the nurse tank.
    Started it up and let it run and get hot. I didn’t have thermostats in it so it would struggle to get the temp high enough to turn on the fan so I hadnt ever been able to verify that that circut of my wiring actually worked. (Never run an electric fan that wasn't just on its own switch before so I wanted to check it)
    With the thermostats I installed last week new coolant and fluids etc. I started it up. It build temp fan kicked on at 175 right on queue. That also verified my temp gauge is functioning and accurate too. Ran it for 10 15 minutes or so while I cleaned off the roof and trunk to prepare for a drive.
    Shut it off and started getting it off the jack stands. Grabbed my daughter to come be my movie director for the first drive.
    https://youtube.com/shorts/6bnoX1E0tSg?si=SeHiWQs889D12vra
    And Failure. Clutch won't disengage.
    Tried adjusting out my pedal pushrod but ran out of threads. So I went to extending that figuring if I screw it up new ones are less that $10 and I can replace it if necessary and persuade other solutions. I 2 of them this length so Im just going to use the 2 to make 1 longer one. Got them cut and beveled for welding tacked together... and my welder ran out of gas. So that will have to wait until tomorrow at least. For those curious I also plan to sleeve the rod to help with strength around the weld.
    Kinda bummed, mostly anxious to drive it since Im so close. And instead of working in the fuel tank... probably going to find something else non-car related to do today. Im really hoping I can get the first drive in by the end of Thanksgiving weekend.
    Nailhead A-V8, Tim, Thor1 and 2 others like this.
  6. redzula
    redzula
    No video yet cause I had to take the kids to volleyball practice.... but the coupe is facing the other direction now.
    Apparently it is possible to make the clutch linkage too long. And me thinking it wasn't getting disengaged I made it even longer. Texting with @Tim he was certain it would be something stupid... and it was. I shortened my recently lengthened pushrod, re***embled a couple times to get the actual adjustment dialed in, And now it works.
    https://youtube.com/shorts/KkzybfiOrAM?si=4Pq6nxAv_hkDVv4c
    I'll get a video later this week.
  7. Tim
    Tim
    from KCMO
    Congrats man! This is huge!
    gonna get the best old jeep award at the neighborhood show for sure! ;)
    Deutscher and redzula like this.
  8. chlsnk
    chlsnk
    Neat!
    redzula likes this.
  9. redzula
    redzula
    Went to a neighbors house for Thanksgiving this year since my in-laws weren't able to make their normal trip down for the holiday.
    They're car people too just off topic stuff. Anyway brought the coupe down the street to their house for a little bit of a drive. Shoukd have let it warm up more cause it was pretty cold out and the car wasn't running too well.
    Wallowed in my sadness yesterday as Nebraska got steamrolled by Iowa their football game. So I didn’t get back to the car until today.
    Started by pulling the tank in the trunk. I hadn't looked too closely at it but I always ***umed it was an aluminum tank... once I git it out I realized it was actually stainless and surprisingly clean inside and probably wasn't bad enough to warrant my nurse tank but if you recall when I first started looking at it the rubber hoses connecting the line to the tank basically disintegrated so redoing all that was warranted at least.
    The old gas in the tank smelled real nasty so I drained whatever was left as best I could and then a few cycles of water and a mix of water and simple green and rinsing till it was as good as it was going to get. I had previously purchased a tank sealer kit ***uming there was going to be some corrosion in the tank but after cleaning it I don't really think that is necessary and with all the horror stories of the sealer not sticking and ending up in the lines, I'll avoid that risk.
    The tank had a "sight gl***" made out of some of that notorious clear tubing. I sad had cause it broke almost immediately once I started cleaning things. I decided to plug the holes instead of trying to remake that and I'll keep a stick in the car to check the level when I need to.
    There was also a piece of clear tubing connecting the fill port to the tank. Wasn't anything that I could see wrong with it but I went and got a new rubber hose to replace it anyway.
    The fill port i thought was interesting. I like the way he did that piece. Studs welded into the exterior side. That goes through the body and through a plumbing flange with a close ****** that the hose clamps onto. Then there's a matching close ****** on the tank for the other side. Simple and clean.
    Also I bought a new gas cap when I first got the car. And then today found this other one under the tank when I pulled it out. Which ine do yall think I should use?
    Sorry still no video of my driving it lol
  10. Tim
    Tim
    from KCMO
    Kinda like the new one. Stick the old one under the tank were it was and when you drive off with out the new cap you’ll have a back up ;)
    redzula likes this.
  11. redzula
    redzula
    What a pain in the **** that turned out to be. But I got the tank back in.
    The springs holding it down ****on up against the back of the horizontal bar of roll bar hoop. And I didnt like the electrical tape cushion between the tank and the stands. So I cut and sliced a bit of rubber hose and fit that over the edge of the stand as a cushion but that made the spot between the spring and roll bar even tighter so I fought a lot with getting the stand bolted down. There is no way to mount the stands first and then install the tank. Well I could mount 1 stand first the non fill side and then put the tank in place and then had to slide the stand in under and try to stand it up in place to line up correctly with the bolt holes... it was a chore. But I got it finally after a few choice words of motivation lol.
  12. Tim
    Tim
    from KCMO
    One step closer!
  13. redzula
    redzula
    And another one.
    Bye bye nurse tank.
    Started at the back. I removed the old shut off valve that was in line. There's plenty of room to add one back in if yall think it's a good idea.
    (I just figured with it being in the trunk if there were any issue by the time you got out and went around to shut the valve how much good would it really be doing especially once I eventually find or make a trunk lid for it)
    I went with 5/16 hard line. Cut the double flare off and crimped a bubble flare. Go figure the new flaring tool I bought wouldn't hold this pipe but the fancy one that kept messing up the brake lines made perfect bubble flares in this lol. Used 2 sticks to get front to back. There's is a compression union to connect the 2 under the car and I brought the line all the way up the firewall and over to just under the fuel pump. Before there was a good foot of rubber hose off the tank and probably 2 - 2.5' feet on the engine side. Now there is only about 6" on either end thats rubber and the rest is hard tube.
    After I got it all hooked back up. I was letting it run off the tank in the back and work out any air bubbles from the line and fiddling with the carbs some after it was running so poorly on Thanksgiving seems to be better now but ill have to drive it to be sure. Pretty stoked that I can say I need to drive it more to start working out bugs now.
    As long as I dont find anything catastrophic between now and next weekend I should be able to make it to the neighborhood cruise in that I've been saying I was working to get to since we moved here. And if im feeling extra randy maybe ill try taking it to the proper cars and coffee a couple miles down the road next sunday.
    After that, I think ill start working on the driveshaft headers. I bought some misc bends but accidentally got 1 1/2" and really need 1 5/8" so I ordered the bigger ones which shoukd be here later this week.
    Cheers.
  14. Tim
    Tim
    from KCMO
    You don’t have a trunk lid? I don’t think I ever realized that.
    congrats on getting the slightly larger gas tank plumbed I’m stoked for you to get some miles in on it!
    redzula likes this.
  15. redzula
    redzula
    I have a trunk lid but its a pretty beat up fibergl*** one that I took off a while ago and just havent put back on. It used rumble hinges and at the very least I want to flip it to a regular trunk opening.
    Tim likes this.
  16. redzula
    redzula
    Took it to the mail boxes after work today. Let it warm up before I drove it to see if that was part of my troubles on thanksgiving... it wasn't. Carb tuning helped but also wasnt the the problem. There's a pretty nasty stumble off idle unless you throttle up real slow. Idles just fine and returns to idle just fine.
    Didn't have a ton of time to look into it cause its back to volleyball practice tonight. But I think I'm going to check for vacuum leaks and check that vacuum advance actually works like it should. I rebuilt the carbs a while back but never did much with jetting or the power valves other than just putting in new ones. But I would think those would affect the whole range instead of just off idle hence me starting with vacuum and ignition.
    Thor1 and Tim like this.
  17. Tim
    Tim
    from KCMO
    Better than nothing! I’d check the fuel filters but
    Sounds like you’ve got a good line of questioning figured out!
  18. redzula
    redzula
    After a very stressful week at work. I had 2 stores set to open a week apart which meant 2 weeks ago we did the final walk through for the first one then last week we walked the 2nd. Then this week we opened the first, and set to open the 2nd next wednesday. But that all included health inspections, final building sign offs and trying to get certificate of Occupancy for bothe stores. My boss deciding he didn't like where our sign was and making us redesign, repermit, relocate, and brick in at the new location all during a holiday weekend and short timeline before store opening with everything else going on. Lol. Sorry to ramble its but its been a lot. As my dad says though "if it was easy everyone would do it" right.
    Anyway on top of that the winter weather thats been crossing the country has hit us here and its been raining for the last few days and is going to rain out our cruise in tomorrow morning. So when I got home from work tonight instead of digging further into my tuning problem. I decided to start building my driveshaft headers.
    I had a basic layout of what I wanted to end with and with that I unbolted the current "headers" and moved them out of the way. Bolted on the flange and started figuring out the bends needed for the front port on the p***enger side. (Figured I've never attempted to build headers before so I should start with the "easy" side to get my feet wet and then when it came time for the complicated side I've better equipped to handle that)
    Rubber hose as a spacer to set it off the frame
    Anyway the front pipe took 2 bends to get up and over the frame with plenty of clearance.
    I started by tig welding the 2 bends together. Struggled at first to get the tig to work right (definitely operator error)
    So I switched to mig. But that went even worse. The other day when I was welding the clutch rod I was getting a ton of porosity and realized the gas was out. Refilled that but the porosity didnt go away. I was basically done at that point and forgot about it thinking maybe it was something with the metal I was welding together. Well when I tried sticking the pipes together tonight it was still super porous.
    After trying multiple things to get it to stop I eventually gave up with mig and tried the tig again and I actually started figuring it out and got a little better as I went. Im not a professional by any means but I eventually got it done.
    Then i went back to the car and stuck the piece into the flange on one side and driveshaft on the other messed with it until i had it where I liked it. Marked the position with a sharpie and took them both to the vise to be my 3rd hand and hold everything.
    I do have to trim a little on the block side oh the flange but other that it'll work
    Plenty of clearance between pipe and frame.
    Going to call it a night and get back at it over the weekend.
  19. Tim
    Tim
    from KCMO
    Looking good man! Good way to end a stressful week and replace a rained out event/deadline.
    It’s looking more and more like Adams hot rod. Those headers will be great!
    redzula likes this.
  20. redzula
    redzula
    Pics looked the same but this time there are no shims or jackstands holding it all up.
    P***enger side header is done except for 2 spots where the middle and rear holes in the driveshaft I cut a little wonky and I think ill have to figure out how to fill or figure out whats going on with the mig and use that to close them up. They're both on the underside so looks wise it wouldn't be a big deal.
    Other than that my tig skills seemed to improve as I went. Still not much to write home about but better.
    I'm kind of a wing it guy which is how I did the front tube and that was able to hold up the front of the big tube while I positioned the rear end where I wanted it.
    From there I worked on the rear tube. That needed to come out and up slightly then another partial bend got the tube horizontal and clearing the frame. Once past the frame another bend down roughly to the main pipe.
    Drilled my hole. Used a 1.5" holesaw because none of the hardware stores near me had a 1 5/8" like the pipe is. Then i used a combo of files and a flap disc to open the hole up to fit the primary tube. This was where I went a little wonky with the hole. Though I think it was partially my holesaw work too. Either way I got it so i could slide the main tube onto the front primary and then slide the rear primary in and it would hold itself up. 20251207_145351.jpg
    After that I started working in the middle primary. Same sort of flow as the rear except I didnt have to bump it up as much to clear the frame. The hard part was figuring out where the hole in the driveshaft needed to be. Looked at it a bunch, made some half *** marks roughly where it looked like it needed to be. Snuck up on the length of the primary and ground one side of the hole further up the tube until I could get it in. Once it was is I could scribe the primary to profile it to fit the tube. I didnt gonsuper crazy coping as I didnt want to make it too close and then struggle to weld it without blowing holes trying to welt the thinner primary to the thicker drifeshaft. So the primaries stick into the driveshaft a little but nothing thats going to be a problem. Its just a flathead after all nothing too crazy.
    Once I had it where I liked it I welded that primary to the flange. At this point I had all 3 primaries welded to the flange and nothing welded to the driveshaft. The front end if the driveshaft was a little bigger than the front primary tube and the gap was bigger than I was comfortable with trying to fill. So I marked the end in a cross pattern an about an inch down the tube and used a cutoff wheel on the grinder to cut 4 slits. Once they were cut I was able to use clamps and the vice to close up the gaps between primary and main tubes. Refit the driveshaft in place on the primary tubes and welded it on for good. After that I was able to weld up my relief cuts and weld the rear 2 primaries to the main tube. Nit sure why I'm explaining all this... you all know how this works lol.
    Overall im pretty happy with the results of my effort but this was just the p***enger side
    The drivers side is going to be a bit more complicated because ill have to get around the steering box. Ill so my best to match the look side for side. Front and middle primaries should be straight forward but that rear one is definitely going to be different. Not starting on that tonight though cause its midnight and I need to get some sleep before another crazy week at work with another store opening on wednesday.
  21. Tim
    Tim
    from KCMO
    Man for a guy just winging it that turned out great! With that many jogs on the p***enger side I don’t think in the drivers side should give you too many curve balls.
    very cool :)
    Outback and redzula like this.
  22. redzula
    redzula
    Back in the garage last night.
    Got myself in the zone by working on closing up those big gaps I mentioned last update. With a mix of patience, welding angle, and welding from a comfortable position. I was able to get them closed up. Big ugly weeds on the bottom side and I did have one spot that blew through on the top side which led to an ugly bit on the top in 1 area. Kinda kicked myself for that but it is what it is. Not planning to dress up any of the welds so other than paint they will remain in raw welded form. I think the homemade look of them actually fits the rest of the car pretty well.
    Bottom side
    And the booger on the top side
    I did go back and flatten out this one a bit to make it look a bit better than this photo.
    Old exhaust system out.
    It almost looked like he'd used an off the shelf set of headers and then modified them to fit the car as needed. There were some bice parts and some clearly pieced together parts. No judgements as piecing together is exactly what im doing but interesting nonetheless. From there it went to flex pipe. And finally to some heavy straight tube that was pretty thick wall.
    Now for the new
    The flange just slips past the dipstick tube but it clears.
    Again started at the front primary tube
    Tightish bent straight out of the block
    Added a second bend to get it turned back the right way. Amd welded those 2 pipes together separate from the flange.
    And then when it had them together I promptly welded them to the flange at the wrong angle which I figured out when I mounted the flange and set the main tube on and it was sitting right on the frame essentially. (The other side has like an inch or more of clearance in this spot) of course I used up all my patience filling the holes i already talked about so when I welded to the flange I welded it off completly instead of just tacking and rechecking it. So with that my fix was to cut if off in the middle of the primary and rotate the outlet side. This time I actually checked it and it was better but still not there so I cut another wedge shaped piece to add in between. Its a little ugly with that many welds in **** a small piece but I'll live with it.
    With that fix done both sides measure out pretty close to each other at the leading edge of the driveshaft measured to the floor straight down. Both sides are sitting at about 22.5" and when looking straight dogn the primary meets the main in the middle of the width of the frame. Cant ask for much better than reasonably close to each other side to side 20251212_001751.jpg
    Without measuring it does seem like the engine is canted to the p***enger side some I ***ume to make room for the steering box on the driver side. Obviously I still have a ways to go but happy so far with the overall symmetry with how the main pipes are sitting
  23. Tim
    Tim
    from KCMO
    Be making noise in no time!
  24. redzula
    redzula
    Well I almost ****ed it up completely.
    Last time I got the front primary on and holding the front of the main tube. Same as the other side I started with the rear and will tackle the middle primary last.
    There really isnt much room at all coming out of the flange and straight into the steering box. None of the needs in my ***orted bends kit. Were tight enough to clear and I really didnt want to hard 90 with 2 45* cuts straight out of the engine. Learned a while ago that when youre cutting bends if you cut at an angle that lines up with the center of the circle you'll end up with 2 perfectly round pieces instead of making the end oval shaped. Well here I don't really have any choice but to make it oval to try and gain any bit of space I could and keep my primary tighter to the block. I went as far with that as I could and when that still wasnt enough I ended up pie cutting the very end where it meets the flange and once I welded that closed and i trimmed a little bit more on the end it finally fit in the space and didn't hit anything.
    You can see my mark for the next cut and once I did that. I learned from my mistake last time and just tacked it into the flange and worked on the next piece. In order to clear the steering box I ended up pointing in forward and slightly down. Once i know that was going to work i welded it fully ro the flange and here is where I almost ****ed it all up. Because I was so tight to the block I barely had any room to get the torch into the gap to weld the tight side. In trying I got it way too hot and blew a big hole in the primary pipe. Think oxygen torch cutting where you get a big globe of molten metal slag that just falls off from gravity. There was a glob that fell off here. I took a few minutes to regroup and set to trying to fill the hole and much to my surprise somehow I was able to get it closed up. No pictures of the hole cause I was in crisis mode and focused on fixing it. You can kinda see in the color of the first piece out of the flange hot hot I had gotten it as the whole piece was blue not just where the weld is.
    So back to my next piece, it started as a full 180* which I cut down to around a 150* or so and that got me coming back up and out. I was going to have the same issue with welding space here so I welded what I could and decided once I have the whole header tacked/welded together ill go back and cut out the section of flange between the middle and rear primaries which will give me more room for the dipstick and allow me to weld it completly around. I may go back and remove the joining piece of flange throughout and just have the actual gasket area of flange left. Not sure yet. I dont hate flanges as one solid piece but if I need to cut out 1 section it might look weird if I don't do the others... thoughts? Regardless I have some time to think on that.
    After that I got the next piece its a straight with about a 60* bend at one end. Held that up and got it marked for alignment and grabbed another slight bend that will get me lined up in the right direction to enter the main tube and welded these 2 together. From there i was able to go back to the car and get it all lined up where i wanted it, marked the alignment, pulled the header back off the car and tacked them together on the bench rather than try and fight welding it on car.
    As I was getting them tacked i ran out of argon so I stopped. Im going to refill that tomorrow along with taking my mig gas back and see if they can test the mix on that for me.
    Ne t time ill drill the hole in the main tube and extend that last piece to meet it. That will let me hand the tune completely off the primaries without jackstands while I work on the middle tube. Clean up the rust on those sides tube, weld everything off, cut out the section of flange, finish weld anything i missed, and paint both sides headers. Id like to get that all done before we head to Iowa at the end of the month so when we get back maybe I'll be able to keep my date with the monthly cruise in I keep shooting for.
  25. redzula
    redzula
    Oh and yes I can get the header bolts in on the rear primary but its tight. I basically have to hang the header from the front and middle primary bolts only starting the bolts a couple threads. Then using fingertips from both hands on either side if the steering box to start the upper bolt at the rear primary. Then the bottom one has to go it and get screwed all the way in but not wrench tight yet. Then I run the rest of the bolts all the way in and then i can tighten everything. Shoukd be a fun exercise once I add the extra few pounds the driveshaft will add. But I know it fits and as long as i know that the fight won't be so bad.
  26. Tim
    Tim
    from KCMO
    Looking good!
    That tight tight bend right off the flange is why so many cars run manifolds lol. I’ve spent countless nights trying to figure out a mega tight, fast bends like that. Good job man.
    redzula, Outback and Deutscher like this.
  27. redzula
    redzula
    Well went out to work on it a little last night and ended up knocking it all out completely. Well except for that little bit that was too tight behind the flange to get to with my tig torch. Think since its not easily seen im going to try amd get it with the mig rather than cut out that part of flange like I was talking about before. I will if I have to and then ill just weld it back in when I'm done. I just dont want anything to shift when it get cut apart and then struggle to get it realigned. Anyway enough about that here's the pictures lol.
    Overall for my first ever attempt at headers, first time really tig welding in probably 15 years, I like how they turned out. I think I am going to dress up the welds some before painting. Some of the fatter welds I had to do to fill the bigger gaps where the primaries meet the main tube are ugly. I'm not going to go crazy blending them all out or anything just want to make them look a little nicer.
    Y'all know im open about my wins and fails. And honestly I struggled getting the main tube situated on the primaties on the drivers side. I was kinda just in go mode and in the process I messed up the alignment of the tube on that side. And when all was said and done the tip of the outlet of the drivers side tube sits about 1.5" higher than the one on the p***enger side. You cant really tell from above or when you look at each side individually but if you measure it its off. Oh well can't do anything about it now. I guess I'll have to live with it.
    Haven't started the car yet but I'm already planning out how to add caps and porters or similar if I need to. Baffles inside the headers themselves would also he an option just depends on how they sound. I like my eardrums but I also dont want it to sound like dog **** either lol
  28. Tim
    Tim
    from KCMO
    I’d say some over the ear muffs may be in order lol.
    Looks great man. If someone gets out a tape measure on an old hot rod that 1.5” difference in collectors is the least of their worries lol.
    IMG_3396.jpeg Really like this angle. They snake over really nice!
    J.Ukrop, Deutscher and redzula like this.
  29. redzula
    redzula
    After work today i pulled the drivers side back off and tried welding that last little bit and i was actually able to get it with the tig in just a couple minutes. Chalk that up to me overthinking things again i guess.
    Then I dressed up the big ugly weld on the top of that side which definaly made it look a lot better. Next DA'd as much as I could of the rest of that side. What i couldn't get with the DA I hand sanded to hopefully get a good stick with the paint. When that was ready I cleaned it all with acetone and painted it with high temp. The handle of the jack makes a pretty handy paint stand by the way.
    While that was drying i pulled the other side header and dressed the ugly welds on that side and sanded everything same as before. By the time I was ready to paint the first side was dry. Swap and paint.
    That header paint drys crazy fast so I went ahead and bolted the first one back on with new copper gaskets to replace the paper ones that were a little worse for wear with all the on again off again while I was building them. When that was done the second side was dry so all in about 2 hrs i had finished welding, dressed welds, painted, and reinstalled both sides.
    And the verdict, it is pretty loud. Lol
    Well obviously its just open headers after all. It actually isn’t terrible at idle but above that haha. Nothing I can't live with for a little while at least. But like I mentioned before I'll probably look into some collector baffles or adding caps and porters at some some point.
    Also not sold on the paint color either, options were limited for high temp paint but the silver i went with is kinda Meh so far. I'll leave it for now and see how it looks once it wears in and gets a bit grimy. Other options I thought about were white and black. White o think would stick out like the silver does. And I thought black might dissappear too much. Again probably overthinking it.
    This was as is with the engine and while I was letting it idle and get warm I messed with the tuning some. I reset the throttle plates and idle which did exactly nothing. Then I grabbed my timing light and adjusted the distrubutor which made a huge difference in how it idles and revs. Before had just adjusted on sound being lazy. I went more advanced and I dont know what I was listening to before because it immediately sounded better at idle and would rev a bit. I need to try driving it again to see if my problem is completely fixed or not but it was raining so not tonight.
    roadwarrior84, Deutscher, Tim and 2 others like this.
  30. Pretty *****in, just in time for Christmas too.
    redzula likes this.
