Projects The Anti-nowhere coupe. Banger to Av8 build
Discussion in 'Traditional Hot Rods' started by tulfabrication, Jan 11, 2017.
  1. Got some stuff done today. Not sure if it'll seal, but I got a little fuel line run from my pump to my carb:
    benchseat4speed likes this.
  2. benchseat4speed, Texas36 and waxhead like this.
  3. I'm hoping I can get everything set up so I can light it off. I have a pretty short list to get to that point. From there it will be radiator and grille time
  4. Binger
    Binger
    from wyoming
    Go man GO!!! Lots of fun steps ahead!!
    carbed87 likes this.
  5. Thanks man, getting excited/nervous
  6. Got my distributor set, motor timed and plugs ran (before you ask...yes the plug wires are temporary)
    Is there a gasket or seal that goes here?
    Also got some hardware together for my clutch linkage. The only issue is it looks like I have just a tiny bit of interference with my Clovis bolt. I'll have to hear it up and bend it just a bit.
    brEad and Texas36 like this.
  7. Tobbe J
    Tobbe J
    This is a great build thread and a true inspiration, I'm following!
    Skickat från min iPhone med H.A.M.B.
  8. Thanks man!
  9. Ran my vac advance.
    Also, I fired that ***** up! Started perfect, had great throttle response...only issue is my fuel pump doesn't seem to be pumping fuel which is a bummer
    Binger and Aaron D. like this.
  10. BuiltFerComfort
    BuiltFerComfort
    Asking because I don't know - is running the brake lines down the rear wishbone ok? Seems like a side load twisting bump would stress the lines where there is no flex (rubber) line.
  11. Tim
    Tim
    from KCMO
    Yeah it's fine. With a torque tube none of that stuff better be moving, if it's moving enough to mess with that brake line you've likely put the car off a cliff
  12. I ***ume you have a rubber line from the master cylinder to where the brake lines are attached to the torque tube/wishbone.
    Charlie Stephens
  13. So after I got it to make some noise I decided to finally see what my fan/radiator situation was going to be like. So I borrowed an sbc 32 radiator from a buddy just to mockup
    The results are good (if My motor is foreword enough that I don't have to mess with my firewall I won't complain). The fan barely touches the radiator which means that I will need to make some special brackets to push the thing out a little.
    Can anyone tell me the ideal spacing for a fan? I was thinking around 3/4"?
  14. Couldn't resist putting my shell on:
    What this also helped me figure out is what size radiator I needed. I could never get a straight answer on what a 30/31 coupe sitting on stick rails with a 32 grille needs for radiator size. Well the answer is around 27.5, which is nearly identical to stock model a.
    Jeff34 likes this.
  15. From there I kind of looked around the garage scratching my head...what now? I hate that feeling.
    So I decided to knock out a few small things.
    Like the clutch pedal situation. This poor thing has probably been heated up about 3 times now. Looks like I'm in good shape though.
  16. So I think the time has come. I'm honestly running out of stuff to do so what better time to prep the body for removal.
    Turns out the whole damn floor comes out in the back
  17. 30 AV8
    30 AV8
    Man this is exciting .... can't wait to see this all come together :cool:
  18. Thanks dude. Body is coming off tomorrow
  19. Getting some prep out of the way before some friends come over.
    Had to pull the starter and pedals on the banger to get the column out. Just have to cut the sub rails to make way for the kick and it'll be good to go.
  20. ...this thing is heavier than I thought
    Got it on the new ch***is. Some very small hiccups so it isn't bolted down just yet (you guessed it...firewall stuff)
    v8paul, benchseat4speed and 30 AV8 like this.
  21. trey32
    trey32
    Money AF
    As the kids are saying nowadays...
  22. brEad
    brEad
    Looks bad ***!
  23. slim38
    slim38
    from Sudan TX
    Just come across thread and read the whole thing. Love all the info and pics. I can't wait to see it finished. Inspires me to start working on my oldie.
  24. 30 AV8
    30 AV8
    Looking Good !
  25. Thank you fellas. Making some room for the motor. Got my radiator in, should be moving forward soon. Hoping to get the body bolted down this weekend
  26. Getting wood under the body and (you guessed it) cutting the firewall
    I'm not mad, I'm just disappointed
    Every time I think I am out of the woods on that p***enger side cylinder head, I end up needing another 1/8". Going to give it a few more whacks but to be honest I am getting close to just cutting a relief and patching
  27. Well she's mounted now.
    May toy with shimming up front but we will see.
  28. OFT likes this.
