The Art of the Headlight location.
Discussion in 'The Hokey Ass Message Board' started by Beau, Dec 30, 2012.
  1. VoodooTwin
    VoodooTwin
    from Noo Yawk
    11 kids? Holy smokes! Now I understand your username!!
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I messed with mine til I got them 'right'. I tried them low, like this:
    Then moved them higher, and rearward. Like this:
    The 2nd pic sits better with me, so that's what I'm going with. Whatever works!
    tinsled and D-Russ like this.
  3. Fenders
    Fenders
    I felt the same way about posts 6 and 15....
    but still, it's YOUR car, do what you like....
  4. pecdaddy
    pecdaddy
    x2.
  5. Ditto!! Perfect Hotrod Primer!! The other looks a bit low!
  6. BORRACHO13
    BORRACHO13
    from Menifee CA
    i agreee!!!:d
  7. daddio211
    daddio211
    I'm just bustin' ya back, its all good. Will check out your build.
    Yup, for REALS!
  8. big daddy Raleigh
    big daddy Raleigh
    from Denver CO
    Perky, large and firm, you might have to play with them for a while until they're turned on.
  9. falcongeorge
    falcongeorge
    from BC
    And the centerline of the bucket more or less on the centerline of the grill shell. For fenderless/cycle fendered cars anyway... But hey, thats just my opinion...
  10. falcongeorge
    falcongeorge
    from BC
    Heres one that nailed it. Maybe not exactly HAMB friendly, but one of the best proportioned T's ever built, IMO.
  11. falcongeorge
    falcongeorge
    from BC
    Another one that nailed it, HAMB friendly in spades...
  12. falcongeorge
    falcongeorge
    from BC
    Couple more, some famous, some recent...
  13. Dane
    Dane
    from Soquel, CA
    Perfect! :cool:
  14. Bcometfx
    Bcometfx
    from NC Indiana
    I think it sets the whole at***ude of the car. It's not if they are high of low. Set out or set back. It's that perfect spot that sets the at***ude of your build. You just have to put them in different places till you you get that perfect placement. You will know as soon as you get it.
  15. Jim Bouchard
    Jim Bouchard
    One thing's for sure, every car used as an example in this thread has the lights
    in a different place. The placement varies as much as opinions on this thread!
    There is no formula, it either looks cool or not. Opinions vary!
    HunterYJ likes this.
  16. willowbilly3
    willowbilly3
    from Sturgis
    It is a subject that does deserve great consideration but there is no single solution. I spent several days moving mine around and deciding what looked best. I found that I liked them about flush with the front of the grill and just a bit higher than the tires.
  17. RUSTY2
    RUSTY2
    from Canada
    At the end it is really up to you! We have all gone through this , bottom line it is what you like
  18. Ester Eddie
    Ester Eddie
    from Alaska
  19. brett4christ
    brett4christ
    Interesting thread! One thing I noticed is all the examples are fenderless. Any full-fendered examples?
    I have original A units, a pair of 33-34 Model 40 car buckets and a set of slightly smaller sealed-beam buckets. Which would look best?
    Sent from my DROID device using the TJJ mobile app
  20. For a forties style a bit too big, a bit too close, but low.
    A pinch of jalopy to foil the sinister look of a fenderless, lowered car.
    But as HOTRODPRIMER wrote, it depends on what era your aiming for.
  21. falcongeorge
    falcongeorge
    from BC
    Thats so wierd. Yet when I look through Tex Smiths books and '48/'49 issues of Hot Rod, the majority of the cars have 7" headlights...
  22. tommy
    tommy
    On questions like this, I mock it up and look at it often from different angles. It can seem just fine and then you walk around from another angle and it just doesn't look quite right. Sometimes it takes a compromise. It has to look good at as many angles as possible. An inch one way or another can make a difference. Commercial H/L stands become the norm strictly because streetrodders are more prone to buy them.
    wasn't sure how much to shorten my 34 P/U bed so I leaned a piece of plywood against it. It was in front of the garage so as I worked on the frame I kept looking out side. I moved it a few times. When I finally liked what I saw it turned out to be 10".
  23. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Like HRP said, it depends on the car and era. I like them to be high or low but I often critique when they are too far forward.
    Even cars like this one can look good with unique headlight placement. All depends on the car!!
    I like Tom Branch's roadster, I think that's perfect for that car. But then Jack Carrol's '32 5w is my favorite coupe and his are high up. You gotta respect that the ones with high headlights are true to the era and where they legally needed to be back in the day. that supersedes anything to me. If that's where they were back in the day then it can't get much more perfect then that....period.
  24. ratrod0
    ratrod0
    I tried diffrant things but this is what I ended up with
  25. maplefrm
    maplefrm
    from Central IL
    Day and night shots of a '32 using a drop bar headlight stand.
    tinsled likes this.
  26. chaddilac
    chaddilac
    I got em high on my T coupe because of the chrome shocks out front. It was really the only place I could put them that weren't behind the shocks.
  27. OldoginMd
    OldoginMd
    I put mine where they would fit and light the road.... hope there is a picture here ???
  28. HOTRODPRIMER
    HOTRODPRIMER
    The headlights on my Deuces ran the gamut,,from stock height to low. HRP
  29. fonti
    fonti
    low...try and try and try...
  30. ARTSWRK
    ARTSWRK
