Folks Of Interest The Baddest 352 on the planet.
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Dec 17, 2025.
  1. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Not my words... but a great story on a often forgotten Ford FE.
    Yeah... you can do a 390,428 and build a stroker. or look for the unicorns.....406 or 427.
    But still today... a 352 or 360 can be found cheap,... and build a street Monster.
    I just enjoy this gentleman's work and explanations.
    This vid is just an overview.. there is an entire series on the build.
    Here....
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Couple of big drinkers on top.
    Built with fuel mileage in mind...... Haha...ahhh no.:)
  3. lothiandon1940
    lothiandon1940
  4. 1952henry
    1952henry
    Nice. This guy knows FEs.
  5. Paladin1962
    Paladin1962
    Had a 352 in a '65 Country Sedan, single 4v, cruiseomatic; that sum***** could definitely move! Keep your foot off the loud pedal and it might get 14mpg
  6. RMR&C
    RMR&C
    from NW Montana
    Wow! Sounds pretty good at 7k rpm! 352's get no respect. I love mine.... tho it's no where as stout as that one
  7. 57 Fargo
    57 Fargo
    Now if only it wasn't a Ford....:)
  8. 57 Fargo
    57 Fargo
    I actually have what I think is a 352 or 360, I’ve never bothered to check. It’s beside a Y block that I’m unsure on displacement as well!o_O
  9. 57 Fargo
    57 Fargo
    In retrospect @Jeff Norwell i should have brought them with me and left them at your house.
    Sharpone, mad mikey, Spooky and 2 others like this.
  10. Spooky
    Spooky
    352's are widely ignored.
    When introduced in 1958, they were a 300 hp engine with a police interceptor option.
    Then Ford dropped the hammer in 1960 with the 360 horse 352.
    LCGarage, Silva, 550Coupe and 14 others like this.
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Hahahaha
  12. bchctybob
    bchctybob
    Interesting series of tests, thanks for posting. Nice to see the smaller FE get some attention. Got some good power without the $1500-2000 stroker expense.
    Sharpone, loudbang, mad mikey and 2 others like this.
  13. 57 Fargo
    57 Fargo
    Shows how much I know, mine must be a 360, it’s out of a ‘67 F-100, apparently the 352 was gone by then, at least according to google
    Sharpone and Jeff Norwell like this.
  14. 1952henry
    1952henry
    I had an OT 67 highboy with the 208 2V 352. That beast had torque. Side step clutch and it would twist the rear leaf springs.
    Just finished tearing apart a 428 for my neighbor, so he could take it to the machine shop. Love those engines.
    would be fun to build a 360hp 352.
  15. Didn't Ed Prout from Connecticut win "A" stock at the Nationals with a bright red 1960 Ford with a 360 HP 352 , inch FE ?
  16. Paladin1962
    Paladin1962
    Also had a '65 F-100 with a 352 4v and cruise; blew it up on Christmas Day 1993. It never knocked or gave any warning, just gave up on me. Good looking truck and I should have just swapped in the '65 Mercury 390 I had on hand.
  17. finn
    finn
    I recall the 67 F series still had the 352. The 360 came the next year, in 1968.
    The 360 got a bad rep because the piston was way down in the hole to drop the compression ratio. Last thing you want in a truck engine is detonation, hence the low cr. The driver often can’t hear it, or ignores it, and destroys the engine. A true truck engine has low enough compression that it never happens, as long as timing is set to factory specifications.
    Don’t know if the 352 truck versions suffered the same way, although I suspect they did.
    The two barrel 352 had a two barrel carb until 1964, when they all got four barrels in the cars. Trucks got the 352 from 1965-1967, with a 2 2 barrel.
    the 62-63 two barrel cars weren’t much, if any, faster than the lighter 289 in the same ch***is, from what I recall.
  18. 1952henry
    1952henry
    True that^^^^
  19. stuart in mn
    stuart in mn
    All FE engines pretty much look the same, so you can tell people your 352 is a 427 and most won't know the difference. ;)
    Interestingly, in the first dyno run in the video his 352 made 208hp, which is right at the factory rating for a 1966 pickup.
  20. Mr48chev
    Back in the mid 60's a cl***mate in trade school and the best bud of one of our members had a 56 Ford two door wagon that he had put a strong running 352 in that suprised a lot of rigs in street races in it's time. our member Hedders (who hasn't shown up as checking in for years but used to check the cl***ifieds daily) rescued him untold times and drug the car home with a broken transmission and the owner pretty well ran local wrecking yards out of Ford 3 speeds before he put a 4 speed in it.
    LCGarage, 63Biscuit, Sharpone and 3 others like this.
  21. slowmotion
    slowmotion
    The old man had 2. A '58 Fairlane, then a 60 Galaxy, both 2dr HT's. Both P.I.'s IIRC but I was a little ****. I remember his buddies all oogling over the engines. I know they pinned me back in the seat many times!
    Sharpone, Jeff Norwell and Spooky like this.
  22. RmK57
    RmK57
    Would have liked to have seen them bump up the compression to 12-12.5. Probably could have made another 20 hp doing that.
  23. 57 Fargo
    57 Fargo
    Well then anyone want to buy a 427?:D
    porkshop, 19Eddy30, Budget36 and 6 others like this.
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Every Car manufacturer made engines that were innovators and then got regulated back to the Nosebleeds.
    Chevy and the 307 and the 305
    Pontiac and the 326
    Mopar and the 318
    etc,etc,etc,...........
    None of them are bad..... they just were pushed into the bleachers and made to function for Mom and Dad.....
    I just like under-dogs.... they can surprise you.
    Silva, Sharpone, Spooky and 5 others like this.
  25. bobss396
    bobss396
    Ted Wells was the 352 master in the late 1960s. He even made his own intake manifolds.
    I wish I had an old issue of Car Craft, it had a great article on his 1954 Ford. IIRC he was from Oregon or Washington.
    Sharpone likes this.
  26. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Did a search and lo and behold. the mag and info was right here on the Hamb.
    A very interesting read, albeit a full race car.. but interesting info to say the least.
    This place has so much info on whatever you need. searching is the Key.. it always knocks me out.
  27. milwscruffy
    milwscruffy
    I can't help but wonder if it is like SBC's where it costs no more to build a 400 than a 265, yet you get the extra cubes and torque. Could be why the 352's have been somewhat ignored.
  28. 409 Bob
    409 Bob
    Great video,
    When I was in Palm Springs in 1969 a friend had a Galaxy with a 352 that I would swap with my '55 Chevy on different days for fun. it would really go.
    Bob
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I completely agree.
    the issue is that the 390's and 428's have become expensive... I certainly wouldn't want a 390 or 428 with a rebuild starting at 40 over... heating issues after that.. the early (64,65) are a thicker cast block...or so it seems to be.
    so a 352,360 is a much cheaper alternative to start....
    Any vintage engine to build is costly.....
    550Coupe, rod1, Sharpone and 3 others like this.
  30. jimmy six
    jimmy six
    Gee I thought this was going to be about a SBC with a 4” bore and 1/2” arm like was done in 1957 by Howard Johanson and Keith Black. A hot rodders dream engine…a 352.
    I also read some where when GM was going to make a bigger SBC than the 327 they shortened the stroke to 3.48” so as not to confuse GM owners with a Ford engine.
    Funny when guys started putting 400” cranks in the their 350’s the suddenly got a MOPAR engine.:rolleyes:
