The Banger is dead - long live the Banger. 2010's first banger thread
Discussion in 'The Hokey Ass Message Board' started by Stovebolt, Dec 31, 2009.
  1. Crazydaddyo
    Crazydaddyo
    Those A quick changes aren't worth the effort......Just send it to me and I will dispose of it ........:D:D:D:D:D:D:D:rolleyes::eek::eek:
    I'm running the V-8 version and I had Hot Rod Works in Idaho set it up for me. They know there stuff. Try calling them for info / parts.
  2. Reddy
    Reddy
    Thank you Crazydaddyo,
    I will try this tomorrow Mike
  3. BCCHOPIT
    BCCHOPIT
    This Guy????????????
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]The Hot Rod Works [/FONT] [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]P.O. Box 53900[/FONT]
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Cincinnati, Ohio[/FONT]
    [FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]45253-0900[/FONT]
    [FONT=Arial,Helvetica,Monaco]E-mail to.....[/FONT]
    [FONT=Arial,Helvetica,Monaco]woodguy@hotrodworks.net[/FONT]
  4. BCCHOPIT
    BCCHOPIT
    opps Idaho I will look some more[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular][/FONT]
  5. BCCHOPIT
    BCCHOPIT
  6. Crazydaddyo
    Crazydaddyo
  7. BCCHOPIT
    BCCHOPIT
  8. Reddy
    Reddy
    Steve,
    The engine is not new, but looks really good inside, I think it sat for some time
    before I got it. I have replastigage it .0015 and it's still tight??
    Mike
  9. If it ain't broke don't fix it!
  10. V4F
    V4F
    from middle ca.
    reddy ,
    then go back & loosen one (rod or main) at a time , retightening as you go , untill you find the tight one .... bummer ....... maybe check the distibutor ......steve
    dumb question , did it ever rotate ? is it in gear ?
  11. I'm running an "A" halibrand. The one I have was used in sprint cars the one used in midgets uses a thinner pick off gear (change gear) I believe the one for midgets used a 1" wide gear and the one for sprint cars used the same width as the V 8 . This information was from Joe Mac The Kiwi "A" quickchange patterns are for a later midget. I bought mine in a "basket" and had to do some machining on it . The Main modification is to relieve the differential carrier so it will clear the lower shaft. No machining on the ring gear. Most of the problems with the "A" rear end is from the pinion climbing the ring gear and cracking or breaking the case. The one I have has been welded a few times in that area. This problem is solved by installing a snubber in the axle housng. When you load the rear end with a lot of torque the ring gear pushes away from the pinion and the pinion tries to climb the ring gear and something has to give. The V8 has the saddle bearing and it supports the pinion. The snubber stops the ring gear from moving Not hard to do and now is a good time to do it. If you don't plan on stressng it too much it is not necessary. I have a friend that ran one on the street behind a SBC in a 29 tudor
  12. Dave in Denver
    Dave in Denver
    from Denver, CO
    I just finished replacing the stock Model A engine in my 1930 CCPU with a rebuilt Riley Two Port inserted and pressurized Model A Ford engine. I would like to install an external oil filter on this engine, but am unsure of which type to use based on other past experience. If any folks have any photos of their installations I would greatly appreciate it.
    Thanks,
    Dave
  13. This is a Kiwi but basically it is the same as the "A". This should be the only modification required. I used a manual from Speedway and ***embled it with out gaskets as to their instructions.http://rides.webshots.com/photo/2777973360049181497MptMFw
  14. 4bangertroy
    4bangertroy
    from Phoenix
    Jim Brierley, 4portriley on the hamb, wrote on article in the F.A.S.T. (Ford A Speed Technology) magazine in 2005 on building a Model A halibrand and the modifications needed. Its a great article that I followed when building mine.
  15. andyg
    andyg
    speaking for yours...how's it holding up....also how is the new engine doing?
  16. 4bangertroy
    4bangertroy
    from Phoenix
    Hey Andy,
    Mine is holding up great. The new engine is good. Much smoother than before.
    Thanks for asking.
  17. andyg
    andyg
    good to hear that....what bearings were used in your bottom end?
  18. 4bangertroy
    4bangertroy
    from Phoenix
    I used the new inserts for Model As from Antique Engine Rebuilding for the mains and British Leyland inserts for the rods.
  19. Can you give me the specs for the rod inserts?
    Bill
  20. Liberty Garage
    Liberty Garage
    I bought a lower shaft a few months ago from Norm Rapp Racing in San Francisco (415)333-8510 $89.00
  21. andyg
    andyg
    hey it worked!!!
  22. 4bangertroy
    4bangertroy
    from Phoenix
    Sounds great Andy!
  23. Crazydaddyo
    Crazydaddyo
    Andy,
    Your car sounds good. Thanks for posting the video.
    Now you need some action footage. This is me running down a V-8.
    Here is one I found on Youtube:
  24. BCCHOPIT
    BCCHOPIT
    Thanks guys for all the info. I will have to look for that F.A.S.T article at my buddy house but I don't think he goes back that far.
    Thanks Bill
  25. BCCHOPIT
    BCCHOPIT
    Nice run CDO looked like lots of fun. :D
  26. Stats DAN por favor!!!! I think you ran what a 17.8 at........
    Oh I am back to the thread fellas. Will post some pics for ya'll tonight I promised awhile back.-Weeks
  27. BCCHOPIT
    BCCHOPIT
    welcome back WEEKS did you have a good vacation :)
  28. 4bangertroy
    4bangertroy
    from Phoenix
    Bill,
    Rod bearings are British Leyland MGB 1965-76 rod bearings Federal Mogul #65385CP
    Shaft size- std. 1.8759/1.8764
    Housing/Block size 2.0210/2.0215
    Troy
  29. 4bangertroy
    4bangertroy
    from Phoenix
    I can try to e-mail you the article or fax it to you if you have a fax.
    Troy
  30. andyg
    andyg
    that's a cool vid...anytime your running down a v8 it's cool!
    i posted 4 videos on youtube today. mostly experimenting...said a lot of the same stuff in every video! oh well....:eek:
