The Battery Buy
Discussion in 'The Hokey Ass Message Board' started by 51_Chieftain, Dec 27, 2013.
  1. 51_Chieftain
    51_Chieftain
    from Tacoma, WA
    51' Pontiac Chieftain
    So, aside the standard size. Which I have no issue with, these batteries are essentially the same thing, and cost after tax+ almost 100.00 of difference! Am I just paying for the 2E size? I think so, this batter I'm look'n to pick up tomorrow is comparable, if not better in the places it needs to be.
    The one it says I need. 2E Battery 169.99
    UPC: 83996012141
    6 Volt Commercial
    CCA: 620
    CA: 750
    Minutes Reserve Capacity: 190
    Cold Cranking Amps (CCA): 620 CCA
    Cranking Amps (CA): 750 CA
    Group Size (BCI): 2E
    Length (In): 19-1/4 Inch
    Width (In): 4 Inch
    Height (In): 8-7/8 Inch
    Voltage (V): 6 Volt
    The one I'll pick up.Modern Size 89.99
    UPC: 721112782591
    Cold Cranking Amps (CCA): 640 CCA
    Cranking Amps (CA): 800 CA
    Group Size (BCI): 1
    Length (In): 9-1/8 Inch
    Width (In): 7-1/8 Inch
    Height (In): 9-3/8 Inch
    Voltage (V): 6 Volt
  2. which one fits your battery box?
  3. 51_Chieftain
    51_Chieftain
    from Tacoma, WA
    The 2E, the long slender style. It is the correct size. However, I have the clearance and battery tray to deal with the other size. Lots of room under that hood with the lil' ol' straight six.
  4. 5window
    5window
    Probably has more to do with the economies of scale-cheaper to make more of the modern size than a specialized old size-than the quality of the product. But, if you're changing batteries and not restoring to stock,, why not just convert to 12 volts?
