Hot Rods The best engine you have ever had- looking back
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jun 13, 2022.
  1. hipojoe
    hipojoe
  2. chevy57dude
    chevy57dude
    My wife thinks we're a bunch of kooks, reminiscing about engines we loved.
    Ned Ludd, Deuces, Roothawg and 3 others like this.
  3. 296ardun
    296ardun
    Best engine I ever had? That's easy. 296" Ardun, welded stroker, Wilcap mains, Herbert roller cam, Forgetrue pistons, stock rods, Hilborn injectors, flowed by Stu Hilborn himself. I put 70 runs on it, over 40 on straight nitro, ran 137 at 10.51. Sure, a good stocker could exceed that today, but I was using parts from 1955. The only thing I broke were the lifters, when I mis-adjusted them. As Herbert had stopped making them, I took Harley Davidson lifters, reamed out the lifter bosses with a brake hone, and good to go. I have no idea where it is today.
  4. Magfiend
    Magfiend
    I DO have what may become my new favorite - correct 69 302 block, unstamped. Could be used for a real Z28 rebuild...
    Deuces and Roothawg like this.
  5. Might tell her at least we aren't talking about best women. Or not!
    Ben
    Wanderlust, Deuces, Roothawg and 2 others like this.
  6. COCONUTS
    COCONUTS
    The best looking engine I had was a 241.6, Dodge Red Ram stuffed into a 41 4 door Plymouth. When I first fired it up, it had a skip at idle. Turn out to be a bad valve (1/2 was missing). Had to go to a junk yard and pull another valve out of another 241.6 because the auto part store/machine shop told me that they could not get one. Ended up with a Jeep carb (M-151), new lifters, and a fresh paint job. Not a real power house but ran like a sewing machine.
  7. Koz
    Koz
    Best by far, four bolt high nickel block 350, .030 over, (355) with Edelbrock Performer RPM heads, Crane full roller cam to 30/30 specs, Harland and Sharp roller valve train, H beam rods Mahle pistons, 10 to 1 C.R., Mallory Pro Billet ignition with MSD box, 2x4 or 3x2 depending on my mood. Great balance job and careful ***embly. One of those motors where everything just clicked! Absolutely brutal in a light car. Drove the wheels off it reliably with decent (considering) gas mileage.
    Hank37, Deuces and GlassThamesDoug like this.
  8. lostmind
    lostmind
    262 flathead 6 in my last Hudson. 24 miles to gallon with overdrive,
    no oil consumption, trouble free.
    Drove it wherever I needed to go, any state any distance.
    The PO had it rebuilt at a machine shop in New Jersy.
    GlassThamesDoug and rod1 like this.
  9. hipojoe
    hipojoe
    chevyfordman, OahuEli, Deuces and 2 others like this.
  10. hipojoe
    hipojoe
    Its a Fritz Voight built Full Boogie flat head now installed in the Tom Medley coupe! Cant wait to take it to the Vintage races...
    elgringo71 and Deuces like this.
  11. modified1927
    modified1927
    I'm hoping this will be, the one 355 ci, **** crank, h beam rods, heads are now Trick Flow, oh and the Magna Charger I was able to track down on HAMB new old stock. I have a 6" narrow 26 touring front half modified about ready to stab it in, T400 and Franklin. The Power steering was on long block in a 68 firebird, off now
  12. Dean Lowe
    Dean Lowe
    This little 301" SBC by far. Only beat one time in 5 years when the driver lit the red bulb.
    das858, chevy57dude, Roothawg and 8 others like this.
  13. aussie57wag
    aussie57wag
    from australia
    The trusty old Ford y-block. They dominated nasca in 56-57. They have many performance design features that others just don't have.
    They all have solid lifters. Rocker shafts, high swirl combustion chambers, all conrods are longer than 6.2 inches long, they all have air gap inlet manifolds and everyone a side oiler. The early ones did have some oiling issues. That's not an issue with modern oils and filters. But they have are very dependable and strong and have great performance potential.
  14. Atwater Mike
    Atwater Mike
    Most memorable was my Mom's '56 Ford sunliner (ragtop) :eek::cool:
    I kept it when she p***ed, the 292 was fresh, dealership engine when P.O. had engine stolen from in front of his San Francisco apartment! Hood wasn't even removed!
    Ford had a T86 trans w/O.D., rear was 3.90. I did a few things to it, one of them was turning pistons backward, an old Smoky Unich trick for more 'leverage advantage' for offset wrist pins...Cam was a mild regrind by a San Jose speed merchant, John DeLong. (He specified closing valve lash specs to .015", hot.)
    Teapot carb was re-jetted, and ignition was the original distributor, re-curved by Red Mayfield. (my boss)
    This mild Ford would turn 92 in the quarter, (Fremont Drags) in high 13s. Always.
    Ran it on street daily, raced 3 nights a week (street stuff, mostly Chevies)
    Best engine I ever had, including Hemis, big Buicks, etc.
    OahuEli, Papas32 and aussie57wag like this.
  15. aussie57wag
    aussie57wag
    from australia
    The trusty y-block is one of the most underrated engines ever.
  16. Todd553
    Todd553
  17. 6sally6
    6sally6
    I've had VERY good luck with SB Fords(260-289-5.0) ****........
    This 4.3 V-6 is the beat'n-est (is that a word?!) little engine I have ever owned! 1/4 million miles and the heads have never been off.....still doesn't use any oil !
    I have loaded this truck until the body set down on the rear axle several times and it pulls off and up the road...
    no problem! (It even rides and drives BETTER grossly overloaded)
    I bleed Ford blue but Shivel-lay hit a home run with this combo!!
    6sally6
    Truckdoctor Andy and Roothawg like this.
  18. aussie57wag
    aussie57wag
    from australia
    40,000 or 80,000 isn't very high mileage for a motor to be worn out. Doesn't say much for the brand if they were brand new.
  19. I really have a soft spot for ford FEs, 1st car was a 65 Galaxie with a 390, added a holley street dominator, holley 600, mallory dp and voltmaster coil, was pretty fast I thought…. Till I built a 454 for my OT gen.2 chevy.
    Roothawg likes this.
  20. Nobey
    Nobey
    Has to be my flathead Fords, I've had plenty Chevrolets, but have had flatheads all my life.
    In there stock form they just, run and, run and, run. When you hop them up, that's a different
    story, but you can say that about all engines.......
  21. jnaki
    jnaki
    upload_2022-8-11_4-59-36.png 280 hp stock, from the factory in late 1957
    Hello,
    When I was not driving as yet, I always enjoyed it when my older brother’s friends came over to our house for their teenage gab sessions or just to hang around. It was a long standing thing that tools and parts were available at our backyard garage area and the local auto parts store was a bicycle ride up the street. But, I think back and I know the real reason. It was that our mom was a fabulous cook. Her prepared meals were to die for then and now, if we could still get them.
    She was happiest when she served the hungry teenagers plates of sandwiches, her famous hand rolled Sushi and vegetables. Teenagers eating vegetables? That was a new concept, but fresh, coated and/or stir-fried vegetables are/were a way to get hungry teenagers not just eating meat. Char-broiled chicken, steak and hamburgers on a grill were some of the “ordinary” meal items.
    So, when these guys came over, their motors were purring like no other. High performance motors with the correct exhaust pipes just made the teenage mind get in a good place for the cruise or road trips.
    When my brother had me help him install the side Lakes Pipes on his 51 Oldsmobile Sedan, it made some great sounds. Since the motor was stock, it just sounded good. The bad, it was the lowest part of a rake and s****ped the ground on almost every road dip and intersection. So, they bit the dust.
    My brother did not want to wait for many months of building a fast hot rod for the street and local Lion’s Dragstrip. So, he sold the Oldsmobile and the Model A Coupe sitting in the backyard. Then he drove up to the driveway in a new black 1958 Impala with a 348 motor and 280 hp. It was an instant power hungry sedan, ready to do wonders at the drags.
    The 348 motor with 280 hp was the most reliable motor set up we ever had in our ****nal. It gave us plenty of satisfied miles going to work, school, with plenty of road trips around So Cal beaches, mountains and nearby lakes. Although it was supposedly a high performance motor, it was also, a daily driver that did not give us any problems in any climate. From three open carbs, to three chrome caps, to finally the best, the top lid chrome stock 3 carb air cleaner.
    upload_2022-8-11_5-5-19.png a smile for selecting a very reliable, powerful hot rod sedan…
    During the hot summer road trips, even idling in traffic, there was no overheating. It was like the Energizer Bunny, “…it takes a licking and keeps on ticking…” You would think that weekly all day drag racing at Lion’s Dragstrip would put a damper on the reliability of the Impala set up from the factory. But, on those cold Monday mornings, one click was all that was necessary to get started for the dreaded Monday morning school blues.
    The changes over the years to also include a Moon Aluminum Breather set on the chrome valve covers at a later stage.
    We kept it stock as per required rules, but it was set up to race on Fridays and Saturdays while a changeover to daily cruising was back in play for the rest of the week. 4:56 Pos***raction gears for racing and 4:11 Positraction for daily driving and an chance encounter on the street was the norm.
    Until I was able to save up enough money to buy a nice Flathead powered 1940 Ford Sedan Delivery, our surf transportation was the powerful 58 Impala. We got stares and the over-the-top joking comments about our surfing and hot rod sedan. We got the last laugh when our surfing skills far surp***ed those that made those comments.
    My brother was a nice older brother, since I had helped him with the Impala since purchasing it in late 57. So, before I got my official license, he allowed me to race the Impala in trial runs and then leading into the elimination runs while he took over the filming on those days.
    After our drag racing recovery days, the 58 Impala still had the trailer hitch from the Willys Coupe towing adventures. So, we utilized a two desert motorcycle size trailer to hold two 250 ccs bikes, tools and other parts. The Impala handled the heat and dust with ease. It had enough pulling power and never got stuck. For those long distance road trips, we used the 3:78 gears for smooth power and cruising. We only wished we had A/C, but it was only for the road trip home.
    upload_2022-8-11_5-9-44.png me at 15 going 14.68 e.t. Thanks, James...
    Jnaki
    Yes, I put in another post on why the 671 supercharged blower spec 292 c.i. SBC motor that we both built for our 1940 Willys Coupe was “the best engine we ever had…” But, that was a drag race motor for certain builds or modified coupes/sedans. The Impala was a true dual-purpose, factory-built powerhouse hot rod for the times and was the most reliable product for the both of us, drags, daily job, or to high school.
    When it was my turn to own the Impala, the reliability continued until we waved goodbye to it, after we sold it to a young teenager we knew, 8 years later.
    The last stage of the 58 Impala custom race car, prior to all black wheels for the sale to our young friend, in 1965. Thanks for the modified photo by @themoose
    The 348 C.I. 280 hp+ motor was an exemplary motor and car for the times. Thousands of cruising/racing miles without any repairs or damages. It always started in any weather, location or condition (of the car) of the motor in the car. It started, under layers of snow in the local mountains, hot boiling summer weather at the beaches and even after winning trophies at the drags. It started up with the turn of the key and ran well for the rest of the night (s).
  22. Besty34
    Besty34
  23. 53studecoupe
    53studecoupe
    from Eagle WI
    Being a Ford guy I don't have a lot of experience with the SBC. Although I do know they are a great engine for little money. But everyone has one. Yeah I am that guy that has to be different.
    I will give my vote to a 1971 Boss 351C . A high reving SB engine with a sound I will never forget. It's those heads that do it for me. If it is modified it just gets better.
  24. Ned Ludd
    Ned Ludd
    Now that I've inherited a 50% share in my dad's cars, the best engine I've owned, and the only V8, must be the Mercedes-Benz M116: 214cu.in., sohc, 200bhp@6500rpm, completely stock. I can't afford to keep it, though.
  25. 1953, 57, and 65 buick Nailheads, best engines for me. Still have the 1965 425 in my 29 Ford roadster. Good for about 120 in the quarter.
  26. FrozenMerc
    FrozenMerc
    I had a '67 IH Scout 800 during my teenage years powered by an un***uming 266 ci V8. That motor took everything my teenage ignorance could throw at it, and asked for more.
    -30 deg. F Cold starts - Check
    Cruising all day at 3500 rpms, because no overdrive and a 4:11 rear end - Check
    Mudding in central Minnesota iron mines - Check
    Busting trail through snow covered forest - Check
    Pulling dead demo derby cars off the track because it was too muddy for the skid-steers - Check.
    Going way too long between oil changes - Check
    Let's face it, the 266 was a debored and destroked version of IH's already bullet proof 392 that didn't make enough power to hurt itself, but it still put a lot of smiles on my face.
  27. cabong
    cabong
    Like most, I've had lot's of mills of varying makes and sizes. From the 260 in my Model A to the 427 in a Galaxie, to the big Olds in the El Caballo, to the scream'n little Chevy in my Austin Healy Special. But, the most bang for buck and size, was the wee "60" in my Almquist Special. I vintage raced it for years in different configurations, with the last being the best. It loved 6,000 rpm, and was obnoxiously loud. Lightweight midget headers and pipes made from '36 driveshafts. Those shafts were made of some kind of hardened steel, and would ring like a bell if you tapped on them... It ran 110mph on the first straight at Laguna Seca, and was an adrenaline rush every lap. Crosley Garage 012.jpg
    Roothawg and rod1 like this.
  28. Oldtmtech
    Oldtmtech
    C7063658-FC65-4F07-ACC0-1C0ED7F6F789.jpeg 1986 senior year high school my first car paid 500$
    Previous owner had rebuilt motor all 1200 cc of it but could never get it running
    My father immediately diagnosed the distributor being out 180 degrees
    Didn’t touch distributor just rearranged plug wires
    Ran that car for 2 years with 5:11 rear gears pulling 5500 rpm never missed a beat
    Now the Lucus prince of darkness electrical system is a whole nother subject
    Lawnmowers have a more complicated carb 337E599E-EA18-477D-9B0D-69F53E31C5A6.jpeg
    But my best friend had a’66 fairlane gta 390 so I am kinda parchel to that
  29. desotot
    desotot
    Probably I will be alone on this but I once picked up a 64 Skylark 300 4 barrel engine with the factory aluminum intake and heads couple to a super turbine 300 and it went very well, but if I was loaded I would get a Ford 427 SOHC. Reali***y has been for the most part sbcs and nailheads and desoto hemis
  30. daleeric
    daleeric
    from Omak
    I have had several, at 13 a Mac 10 with duel carbs on a caper cycle mini bike, then a 235 chev in my 37 pickup. A 365 cad with factory duels in my 1956 Eldorado Biarritz and a chev 292 six in my 1967 short box pickup. All fun!
