the best way
Discussion in 'The Hokey Ass Message Board' started by 5150merc, Dec 29, 2008.
  1. 5150merc
    5150merc
    what would be the best way to flatten out this raised section on the dash? should i cut it out and make a patch panel?im new to metal working,just a warning.or could i make a few cuts and flatten it then weld it?what would you guys suggest?
  2. Royalshifter
    Royalshifter
    Moderator
    Why are you flattening it?
  3. Unkl Ian
    Unkl Ian
    I would cut out a big section, a make a replacement panel.
    Carve some MDF to the correct shape,
    and hammerform the replacement piece to fit, trim and weld.
  4. 5150merc
    5150merc
    i dont like it.plus the gauges im using wont look good with it there.i want it to look like this,
  5. Unkl Ian
    Unkl Ian
    And it will make a few people scratch their heads.
  6. 5150merc
    5150merc
    thanks unkl Ian.i just may end up doing that but like i said im a newb and i want other more experienced rodders opinions.
  7. ironandsteele
    ironandsteele
    seems like just cutting it out completely and putting a new panel in it's place would be the easiest thing to me.
  8. stude_trucks
    stude_trucks
    Keep the curves. That other dash looks too straight and 80's. Use the gauges that go with the curved dash.
  9. fab32
    fab32
    Seems like you could fabricate a whole new panel or find a donor with the correct shape with a whole lot less effort than trying to eliminate the hump in the one you have.
    Frank
  10. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Totally. Looks like some 80s Caprice dash or something with the curve out. My Merc brotha, don't do it! :D
  11. Bad Bob
    Bad Bob
    from O.C. Baby
    Never could understand why guys want to remove the things that make Mercs stand out! If you straighten out the dash,it will look like some idiot put a Monty Carlo or Caprice dash in it!
    If you really have to do it,don't forget the GM tilt column,CD player ,and the consol with the drink holders. Hell,might as well go with 20's while you're at it!
    Sorry.....i'm a Merc purist!!!
  12. 5150merc
    5150merc
    i dont have any other parts to the origonal dash except the metal frame and glovebox door and dont really have the $$$ that comes with ebay merc parts.plus i want to run these gauges,
    i think they would look weird with the arch in the dash.oh yeah it already has a monte carlo tilt wheel.
  13. Bad Bob
    Bad Bob
    from O.C. Baby
    OOOOOO! Swing and a miss!!!!
  14. Royalshifter
    Royalshifter
    Moderator
    WTF kind of gauges are those?
  15. 5150merc
    5150merc
    new "bomber series" from cl***ic instruments.im a ww2 plane freak in my spare time so they really appeal to me:D
    thought it would be cool to cross a b17 and a merc:eek:
  16. Bad Bob
    Bad Bob
    from O.C. Baby
    UH........NO!!!!!! Not on a HAMB freindly Merc! Save that for a 73 Duster build....
  17. 5150merc
    5150merc
    i had a 71 duster.i miss that car.i got no respect in it till the 383 magnum kicked in.
  18. hellonwheels
    hellonwheels
    from Bastrop
    WINNER! WINNER! CHICKEN DINNER!!! hahaha.
    Bob, you must be clairvoyant.
  19. wbrw32
    wbrw32
    You gonna put a propeller on the front of that Merc too?????????????????
    Those gauges and Mercs are like oil and water...Dont mix very well..my 2cents
  20. chopt55bc
    chopt55bc
    if you had a b-17, would you be tryin to make it look like a merc???
  21. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    This guy doesn't see the problem with the new dash! :D
  22. chopolds
    chopolds
    from howell, nj
    Plenty of replies NOT to do it...I hope you get the subtle hint!
    But......what other options do you have?
    Lots. Get guages from another Merc dash. Install generic gauges BEHIND the Merc openings, so you get modern performance, with cl***ic looks. Get a dash from another car , 56 Olds is very popular, as are mid 50's Pontiacs, 59 Chevy, etc, and install it. A bit more metal work, but still retains the nice old car look the Merc deserves.
    Even if you do one from scratch, keep it old looking, unless you are building a "street rod" type Merc, and in that case, you're on the wrong forum!
  23. rjgideon
    rjgideon
    Look on ebay for something like a '61 Chrysler gauge cluster. Those would look cool with that dash.
  24. Those gauges might "fly" in a hot rod, definitly in a street rod, but not a custom.
  25. 5150merc
    5150merc
    i was thinking of using a dash out of a 55 chevy,but im not sure if the two arches are the same or close enough to work?plus i'd have to get rid of the bowtie.
  26. 19Fordy
    19Fordy
    Stude Trucks is right.
  27. 32SEDAN
    32SEDAN
    I agree. Why make your dash like an El Camino?! Mullet man is on here a lot lately
  28. palosfv3
    palosfv3
    Ok give they new guy a break , he's at least asking for help and guidance.
    I would suggest a little homework before starting out on the dash project.
    Since most everything is missing , you basically have a clean sheet of paper to start with . Go to Rik Hoving's site and look through the pics of traditional custom dashes for some inspiration. Get some 50's custom car mags to look through for giggles. Look at some of the design sketches featured in many of the period magazines.This should get you some knowledge of what works and what doesnt. Once you find out what suit you tastes. Get out a paper and pencil if your old like me or warm up the photoshop program in your computor if your one of the youngsters and sketch out ( photoshop ) your ideas. Its easier to figure this out on paper and you will stand a better chance of a good looking design than if you just "wing it". The exterior and interior should flow together.
    You also will find that this can also help keep costs in line. Styles change but good well thought out design is timeless.
    Oh and dont mind the guys they get like this on "New Years Eve":D
  29. Retro Jim
    Retro Jim
    I agree , give the man a break . He could have gone and cut up the dash and took a piece of plastic and clued the air plane gauges in and THEN did the post and ask use how we all liked it !!! I would make a flat piece that fits the Merc dash to mount the gauges in . I don't think you can get all those gauges in there anyway . Put the dash in the car , sit in the drivers seat and take your time and think it out . How are these gauges going to look in my Merc . Then it will hit you like a ton of bricks . I shoud have FIRST asked the guys at the HAMB what gauges would look good in a Merc . You did it backwards . Send the gauges back or get new one . BUT Hey it's your car in the end and you have to live with the airplane dash . :eek::eek:This is my 2 ents worth .
  30. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Your killing me smalls!!!! NOT to the merc! You sure are new to this," With all due respect", oh hell, who am I kidding. GET A CLUE!!!!
