The Boring Malibu
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Feb 25, 2026.
  1. pprather
    pprather
    These young hoodlums, no end to the trouble they cause!
    Just think of the trouble you'd be in if you were driving something crazy, like the Plan II.
  2. squirrel
    funny thing is I drove that wild altered wheelbase car all over the place, 33k miles, never got pulled over once. Drive a ****py old Malibu, it only takes two weeks.
  3. RodStRace
    RodStRace
  4. slowmotion
    slowmotion
    Ahhh..... The Rag-Picker Theory
    I've seen prime examples, true in effect. Jim, however, never struck as such! Who knew?
    :eek:
    :D
    squirrel, Sharpone and porkshop like this.
  5. RodStRace
    RodStRace
    JAY
    Me and Silent Bob finally bought a car, we’re cruising down to the boardwalk. F@@kin’ Middletown cop pulls us over for su****ion of mischief.
    TEEN 1
    What the f@@k’s that mean?
    JAY
    We were driving around with a deployed air-bag.
    The Teens stare at Jay and Bob, confused.
    JAY
    Don’t ask.
  6. Greg Rogers
    Greg Rogers
    yeah Jim, you better check rear wheel bearings- knowing your history.....
  7. gene-koning
    gene-koning
    Jim, maybe the cop's parents had a Malibu just like this one and remembered how bad it was?
    Then again, with the cop watching the old guy driving erratically (making wide turns), in an old rusty rough looking car, with questionable plates, its probably a good thing the cop was checking you out.
    It may be an omen of things to come though. This one might be a good car to just keep the modern plates on... Old plates on an unkept car may draw more attention then you want on the road, when you are out of your home state.
  8. squirrel
    When the new plate arrives, I plan to just put the sticker on the old plate. It's the same number. AZ has fun YOM plate laws...I've got away with it a few times already, ordering a new personalized plate with the same number that's on an old one, and putting the new sticker on the old plate. You're supposed to go through a different process for YOM plates, which includes having the plate inspected to make sure it's in good enough condition. This one isn't. But I think LEOs on the street see it differently than LEOs that sit in the DMV office.
    And when I hack up the car and put the Conestoga wagon on the back of it, and dress up like it's 1840, I'll be really su****ious!
  9. Sharpone
    Sharpone
    Dang gum Aryzona Hoodlums
    Dan
  10. 49ratfink
    49ratfink
    I bet the cops were very disappointed when they pulled you over. that car has a "meth inside" sticker on it that only cops can see.
  11. 1946caddy
    1946caddy
    from washington
    Maybe they're looking for kidnapped old lady.
    hotrodjack33 and 49ratfink like this.
  12. squirrel
    Wrong county, I hope.
    I h***led the ebay outfit that sold me the backwards reading fuel sending unit, and they finally gave me a part refund for it being ****py. So that's a mild success. I "fixed" the gauge this way
  13. southerncad
    southerncad
    A perfect " HAMB Friendly" fix......
    Deutscher, Sharpone, porkshop and 2 others like this.
  14. Nostrebor
    Nostrebor
    Given the overall condition of the car, that fix is an improvement on the overall theme!
  15. SS327
    SS327
    After you get the rear cover off you will probably find the bolt that holds the pin in broken off. However they are easy to extract. Unscrew the easy part. Hose out the threads and broken part with brake clean. Use clean dry air to thoroughly dry the brake clean off. Take a brand new pencil and put one small drop of superglue on the eraser. Put the eraser in the hole and hold it tightly against the broken bolt and wait a few minutes. Then gently unscrew the bolt. It has worked for me dozens of times and never failed once.
  16. RodStRace
    RodStRace
    @SS327 I think you stayed up too late last night. Was this reply for this post?
    EDIT: My mistake! It makes sense now. Guess MY morning coffee hasn't hit yet. :confused:
    porkshop, SS327 and Sharpone like this.
  17. squirrel
    Yes, this reply was for this post, I did mention that I need to pull the axles to inspect them.
    Neat idea, thanks! I've always been able to get the broken bolt out, but never with this trick, it's always a struggle.
    ffr1222k, winduptoy, porkshop and 6 others like this.
  18. squirrel
    Got a new windshield this morning. So I can see now.
    But there's this problem....
  19. SS327
    SS327
    Quick put a sheet metal screw in it!
    guthriesmith, Deutscher and Sharpone like this.
  20. squirrel
    that should do it!
    but it's pretty rusty....
  21. RodStRace
    RodStRace
    A rusty screw, so there is no allergic reaction?:p
  22. Wanderlust
    Wanderlust
    Uhh that’s not gonna help the milage, don’t touch it it’ll only leak worse, just went through this myself, thought maybe I could patch it, nope! New tanks the only solution :(
    41 GMC K-18, porkshop and squirrel like this.
  23. Wanderlust
    Wanderlust
    Be sure to get a tank with the filler neck installed, you might think that’s an odd statement, I was unaware they could be supplied without, guess what, they can and I found it to be a miserable son of Biach to swap over:mad:
  24. squirrel
    I looked into new tanks already and discovered the filler neck thing...that's why I didn't buy a new one yet.
    I might find something else that I can make fit. I'm still planning to hack up the back of the car, so that would make it so I could use whatever I can find cheap and make fit.
  25. Fifty gallon oil drum
    porkshop, winduptoy and Sharpone like this.
  26. Rub a bar of soap on it. You'll be fine
  27. slowmotion
    slowmotion
    That's what sh...never mind!
    :eek:
  28. squirrel
    The JBWeld Tank Sealer stuff is holding so far....
  29. Sharpone
    Sharpone
    Good for 3000 miles or 3 months whichever occurs first. LOL
    Dan
    Deutscher, porkshop and squirrel like this.
  30. I actually had a patch on a tank made from a screw with a quiksteel gasket coated in jb weld last a decade once lol
