Projects The Chevy T WildCaT project
Discussion in 'Traditional Hot Rods' started by Blackbob, Mar 9, 2020.
  1. Blackbob
    Blackbob
    This might be a slow burner, it might flare up, time will tell.
    The idea is to build a Gerberesque SWB sprint/hillclimb/trials car (i live in Scotland in the UK) low centre of gravity, minimal weight, good power to weight ratio and built using parts from pre 1931 so I can access the events i want to.
    the basic plan is to use a T ch***is, flipped front crossmember and the rails splayed on both sides as gerber did on the LH side only so both driver and p***enger can sit down into the ch***is either side of the shortened torque tube and just in front of the rear axle.
    power will be provided by a 1928 Chevy 4 ohv motor and fed via a T flywheel through a T planetary transmission to a T rear axle with the larger '26 drum brakes.
    Dannerr, Vic Walter, Outback and 8 others like this.
  2. flatheadpete
    flatheadpete
    from Burton, MI
    Sounds like a lot of fun!!
    kiwijeff, Stogy and Blackbob like this.
  3. rwrj
    rwrj
    from SW Ga
    I'm watching. Nice sketch.
  4. Blackbob
    Blackbob
    Thanks, its an old Ford drawing that i tippexed and photocopied to draw up my other project in waiting, a twin engined model T straight eight IMG_1758.JPG
  5. rwrj
    rwrj
    from SW Ga
    Holy smoke.
    kidcampbell71, kiwijeff and Stogy like this.
  6. grumpy gaby 2
    grumpy gaby 2
    We will be watching!
  7. dwollam
    dwollam
    I have a friend that put a Model A engine on a T pan and transmission. No water pump. Runs great. Then he did a '27 or '28 Chev on T pan and trans. He said that was even easier! He did run a water pump on that one. He calls the all Ford one a T&A and the other a Cheford.
    Dave
  8. Blackbob
    Blackbob
    I have looked at a couple of options to mount the Chev 4 to the T transmission.
    The first one as your friend (and John Gerber) did is to slightly modify a T oil pan, fit the T flywheel by re-drilling the Chev output flange and re-drill the mounting holes on the pan to suit the Chev Block.
    The second one I've been looking at is to retain the Chev oil pan and use an already cut down lower half of the hogshead (rear part of the oil pan) that I have as a leftover from the TwinT project (above drawing) and do some creative tinwork to make the hogshead oil tight. As I have to put in a new front engine mount/crossmember any way, It makes sense to make it suit the Chev Block. The hogshead can have a crossmember to support the 4th main keeping everything in line. I plan to use a floating input shaft in the trans to help with the balance whatever route I go.
    Martinbuilt, town sedan and Stogy like this.
  9. Stogy
    Stogy
    Primitive Go Fast...Early, Awesome and Wildly Inspiring @Blackbob. The T8...please also do share as it evolves too. 2020 needs all the Goodness we can throw at it...thanks for sharing...;)
    town sedan and Blackbob like this.
  10. Blackbob
    Blackbob
    it is slowly piecing itself together at the pback of the barn :) ... 75412066_2865977543446858_795853179341242368_n.jpg 75627501_2861210227256923_4420538464559169536_n.jpg
  11. Blackbob
    Blackbob
    Thanks :) .. I probably should start a separate thread for it, as I have been working away on it on and off for some time. I'll need to dig all of the pics and notes out. The arrival of the Chevy motors kinda pushed it back in the queue :D
    Outback, town sedan and Stogy like this.
  12. Stogy
    Stogy
    Stogy's excited...:D
    From the time of the Boardtrack racing...even road...I'm thinking...Great Stuff @Blackbob...
  13. Blackbob
    Blackbob
    If you have any pics of his oil pan set up i would love to see them.I offered the T oil pan up to my short block this afternoon and there are a few areas that would need cat and modified to clear the likes of the oil pump, front pulley and the front and rear mains. The front end of the oil pan would need to have the oil damn removed and replaced as well as being cut and lengthened as well as widened to house the pulley.
    Stogy and town sedan like this.
  14. dwollam
    dwollam
    I don't have pics but I do know it took a lot of heating and hammer work. I don't think he ran the oil pump, as running the T flywheel slings the oil around just like a T engine. I recall he redrilled the pan bolt holes even tho they are the same pattern, it worked better to move it. Forward maybe? Hmmm, is that the chevy engine? I was referring to the Model A. Not sure what all on the Chev. I don't see him often but I'll see what I can do.
    Dave
    Stogy likes this.
  15. dwollam
    dwollam
    I just gave Dave (yep, another one) a call. He is out of town. He said the front dam had to be removed and a new one built on the Cheford. Both the Model A and Chev engines had to be moved forward on the pans due to the crank length being longer than a T. The Chev pulley is down in the pan. I'm welcome to take pics any time, but I will wait til he is home.
    He said the Chev was a '28.
    Dave
    Stogy, town sedan and Blackbob like this.
  16. Pete Eastwood
    Pete Eastwood
    from california
    On my T race car , I'm using a full length " C " crank in the T engine.
    Rather than move the engine ahead, I lengthened the pan.
    I used two pans . I cut off the front of the best one , then I cut the front off another pan 5/8th " longer.
    I welded the two together, ( only one weld ) & only had to redrill a few holes toward the back of the pan rail , & rework the bottom opening.
    Hope this helps with ideas .
    RMR&C, Outback, sko_ford and 15 others like this.
  17. Blackbob
    Blackbob
    Thats a great help, and a great looking car. I hadnt considered cut n shutting two pans .. lovin the racer :cool:
    Sent from my iPhone using The H.A.M.B. mobile app[/QUOTE]
    Outback and Stogy like this.
  18. Blackbob
    Blackbob
    Over the last few days Ive been looking at my pile of Chevy bits and my pile of T bits and trying to get my head around the T transmission and Chevy Block situation. The "normal" route would be to use the T oil pan and cut/shut and grind everything to fit together, but I always like to suss out all of the alternatives before I dive in and do what I shoulda just done in the first place :D
    So option 2, is an idea that has been swimming around my in my head is to keep the Chevy oil pan and use a separate transmission case mounted via an adapter plate to the back of the Chevy block. If I use a thick alloy plate I could weld a plugged up alloy hogshead cover to the plate to be used as a lower trans case and simply bolt a second alloy hogshead cover to the top and everything would be where Henry intended and, so long as everything was square to the crank flange would be stiffer than the original ford tin pan. This would only work with a pre 1926 trans as they hd a narrower clutch band. I have a '26/'27 trans so would have to find an earlier band and use the earlier clutch, which I have. I mocked it up using a cast steel 26 HH covered an alloy one and it looks like it should work out. I could use the cast iron '26 one for the top, which has the mounting for a starter motor but as this is going to be a racer/hillclimber I want to keep it all as light and simple as possible and the cast steel HH is really heavy!! 79737749_2932780263433252_5653501078478520320_n.jpg 89827760_3138150819562861_813260698971799552_n.jpg 89924911_3138150809562862_8937092172855902208_n.jpg 89652002_3138150919562851_2559556786201821184_n.jpg
    RMR&C, Stogy, dwollam and 2 others like this.
  19. Blackbob
    Blackbob
    a bit of saturday morning mockuppery using a 26/27 hogshead flipped as the trans sump and an early alloy one on top 89532697_3139223202788956_2310504835436249088_n.jpg 89783235_3139223022788974_6888918360696815616_n.jpg
    RMR&C, Kume, Outback and 4 others like this.
  20. grumpy gaby 2
    grumpy gaby 2
    I was not sure what 'sus' was, but got a good idea now! Great pic's. and ideas of what could be!!!!
  21. Blackbob
    Blackbob
    (slang, transitive) To come to understand (a person). We've sussed him out — he only drinks on Fridays and only in that bar in town. (slang, transitive) To manage to work (something) out, to determine (something). :D
    Stogy likes this.
  22. 64 DODGE 440
    64 DODGE 440
    from so cal
    Interesting project, I have to follow this one.
    Stogy likes this.
  23. Blackbob
    Blackbob
    It's been over 18 months since I did any work on the TwinT, a combination of getting a contract job building wildcat breeding pens and then having a whole lot of work to do at the farm when that came to an end has kept the the project parts under a tarp on the barn floor. Today I got everything set up on the bench so I can get on with it.. tomorrow, I'll put together a list of bits I need to get and a job list. 254518762_4940887022622556_5338701135788294378_n.jpg 247992651_4940887005955891_3161137978363767318_n.jpg
  24. 282doorUK
    282doorUK
    Glad to see you're back on it, looking forward to plenty more tricky problems and cunning solutions..
    Blackbob and Stogy like this.
  25. Blackbob
    Blackbob
    Ha, I should have posted that in the right thread .. I also pulled the Chevy lumps out and set them up on another bench, trying to work out where @AndrewMcCann got to from his thread so I can take it forward.. 253268941_4919247454786513_7736077243854696599_n.jpg 253785379_4919247238119868_8127940575909505295_n.jpg 255511063_4938145259563399_4527280551666433176_n-1.jpg 255689177_4938145276230064_6290487121567495363_n.jpg 255554444_4938145406230051_7555254641778414058_n.jpg 255511063_4938145259563399_4527280551666433176_n.jpg
    RMR&C, Kume, Outback and 2 others like this.
  26. 41rodderz
    41rodderz
    from Oregon
    That’s what I enjoy is a good tech thread with ingenuity ( meat and potatoes) without the fluff . Go Bob Go !!!!
    Blackbob likes this.
  27. I know a man down Cheltenham way that's had an A ch***is modified to build a low slung Gerberesque style car.
    He may be convinced to part with it now he has a narrow single seater to play with instead...
    Outback and Blackbob like this.
  28. Blackbob
    Blackbob
    I'd be very interested, subject to price ;)
  29. Blackbob
    Blackbob
    Here’s what i’m starting out with and hoping to achieve. Tail end of 2019 I bought two ’28 Chevy National 4 cylinder motors from Andy McCann here in the UK. the stock grey one is pretty much bone stock and apart from a 1.5” crack in the water jacket should be able to get into running order as is without too much h***le. The second (John Deere green) block came bored out to suit oversize A Ford pistons with a bore of 3.870” which is a fair amount over the 3.690” stock bore giving a capacity of 183cu". Standard Chevy crank will use Ford A rods, I need to work out a thrust set up to take up the journal width which is wider than the big end of the model A rods. Using the A rods which are longer than stock Chevy ones which helps to bump up the compression a fair bit.. calculations later.. Sitting up top is a 1921 Oldsmobile 3 port head, the rare as rocking horse **** (over here in Scotland anyway ;) ) the , bolt straight on, go faster mod for 20’s Chevys and known as the “poor man’s Rajo” for Ford T motors which need an adapter plate or two and a bit more bolting to make work.
    My Olds head needs two holes patched on the top where someone has broken in to the water jacket for some unknown reason, but I plan to get the top milled to fit 1.5:1 rockers anyway so I may make up a full cover for the top to bolt down and seal the holes (still to be decided). Olds valves are similar in size to model T ones, you can re cut the seats to take SBC valves which helps the breathing a lot, increasing the rocker ratio gives more lift on the stock cam, a change of cam to model B Ford specs helps a lot more.
    The spec I’m headed for should make for a well balanced rev motor that will push the hp up a fair bit from the bone stock 35hp. With a Ford T transmission and a Ruckstell back axle in a rolling ch***is that should end up weighing in at around 1/2 a ton or less I reckon it will be a potent wee beastie!
    Stock Ford T is all outta breath at 1200 rpm and pulling 45mph on the flat, a stock Chevy 4 revs to 2200 rpm, with the above mods and a lighter T flywheel with no magnets it should spin to 3000 -3400 rpm without too much h***le, feed that through a T Trans and that is how John Gerber won races :)
    RMR&C, Kume, Dannerr and 2 others like this.
  30. 282doorUK
    282doorUK
    Don't care what thread you post in, just keep posting!
    My '28 Chevy racers motor needs a rebuild and there are very few who have been there in UK, so I'm watching very closely.
    IIRC the Mc Cann motor after boring had almost no block metal left between the bores, is this a problem to you?
