Projects The Chris Casny Coupe, Model A build pics
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Apr 25, 2008.
  1. No outside bearing, that thing is wayyyyyyyyyy strong. Basically the same set up as I did on the boat tail but 10 times stronger.
  2. 60'shotrod
    60'shotrod
    That finished steering is nothing short of art!Looks quite a tactile shape. Very nice work as ever.
    Nick.
  3. scootermcrad
    scootermcrad
    Yeah, it looks WAY strong for sure!
    What size is the extension tubing?? Is that 1/2" plate for the arm?
  4. Yeah, 1/2"
  5. What size tubing did you weld the splined part in? I ***ume you tested it to see if a socket will fit in there. I used 2 3/8", and I even found a huge bearing to fit. Maybe I don't need the bearing?
  6. gnichols
    gnichols
    from Tampa, FL
    Impressive work on the steering. If you don't mind me asking.. what is the resultant steering ratio, between the box, the link at the cowl and whatever you may have on the spindles? Thanx, Gary
  7. -Brent-
    -Brent-
    Your attention to detail is phenomenal. I love this build. How much of a pain was it to press the bearing in straight?
  8. jj mack
    jj mack
    NICE DREADMAN!!!
    Scooter...
    I have extra...what is your drop?
  9. scootermcrad
    scootermcrad
    WOW! What are the odds of that!? :eek: I don't know yet. Probably like 6 or 7 inches. Maybe 8. I'll see if I can get a guestament. I need to get the damn stock arm off first before I can mock it up in the cowl area. Haven't had a chance to mess with it.
  10. I'd start soaking those splines now...
  11. I used a "special" 2 1/8" tube
    The steering ratio, good question, I know this box is, I was told a rare 25 to 1, normally they are 16 to 1. The ratio depends on the pitman arm length and steering arm length.
    25 to 1 has 4 turns left to right, 16 to 1 has 5.75 turns left to right, if I remember correctly.
    It was so easy to press that bearing in, I was amazed.
    What I used on this, is a 7" pitman arm. I used 8" (center to center) on my other car and it is "too" long (hard steering).
    As per Jimmy White, 6" is ideal and if you lengthen the steering arm by 1" or more even better.
    Rule is, the shorter the pitman arm the easier it is, to steer.
  12. Ratty55
    Ratty55
    from Frohna,MO
    I really like the way you did your steering. I think I'm gonna steal it :) Thanks for the inspiration. Now i gotta talk to the mopar guys.......
    Justin
  13. scootermcrad
    scootermcrad
    Well alright! Great tip! Thanks for p***ing that along Chris! Sounds like I know what length my pitman arm will be...
  14. jj mack
    jj mack
    Okay help me out here. I determined my length based on keeping the steering arm parallel with the radius arm to prevent bump steer.:confused:
    I am at 8 1/2".
    So...do I drop the steering box to reduce the length of the steering arm or is 8.5 gonna be a big problem.
    PS sorry not trying to hijack the thread....
  15. Have you driven the car, do you have bumpsteer???
    Here is a steering arm I've bent (needs boxing, for strength).
    Bending the steering arm up might be better than having a long pitman arm.
    I've also made longer steering arms and bent them in the past, because if you bend a stock steering arm you will loose alot of length.
  16. Glen
    Glen
    Awesome pictures, I see you like to measure once, cut twice too.
  17. Glen
    Glen
    In this picture it looks like there is a baffle in the cone.....is there and if so how did you make it? I am making headers this weekend.
  18. jj mack
    jj mack
    Thanks for the advise!
  19. munster
    munster
    from burbank
    damn chris! the ****er is turning out amazing!
  20. sodas38
    sodas38
    Sick build...just plain sick.
  21. ratster
    ratster
  22. Mart
    Mart
    Nice work going on here.
    Mart.
  23. langy
    langy
    Don't know how i missed this thread, Very interesting.
  24. skwurl
    skwurl
    Nice work. Killer car!
  25. DanCollins
    DanCollins
    hey Chris comin out nice, I'm impressed. cant wait to see it in person....
  26. Baumi
    Baumi
    Wow, your headers are a piece of art!!! Awesome!
  27. SAVAGE
    SAVAGE
    Alliance Vendor
    looking killer man
    Great to see you last weekend too
    aaron
  28. -Brent-
    -Brent-
    Any updates? This is my favorite build-thread.
  29. Strange Agent
    Strange Agent
    Cool car. Nice choice on the motor! I love to see Nailheads getting used in hot rods! They're just too cool! The body on your car looks as clean as a whistle, that's some good metal! Excellent job on the frame, too! I'm excited to see what this thing looks like finished.
  30. quandel_garage
    quandel_garage
