The one that gets used when bones get split... size, diameters, threading... What vehicle it appears on, better yet, Napa part number? Thanks, J
Dunno the numbers,but there are two types,big and little. big ones from trucks,I think. (most used?) (kinda BTT reply..)
There's also a larger one that's used on late-model Chevy trucks -- very common, easy to find, tough. I'll see if I can find a part number and post it. Steve.
well, I shoulda stated that I have em already, shot ones on the car... (sorry, been up 17 hours...) Is there a number I can pull off them that will make sense? Thanks, J
TRW/MOOG ES150R 3/4"x16 RH Thread 61-66 Chevy 1/2 & 3/4 ton 4x4, 48-76 Ford 1/2 ton 4x4 w/ DANA ES150L 3/4"x16 LH Thread 61-66 Chevy 1/2 & 3/4 ton 4x4, 48-76 Ford 1/2 ton 4x4 w/ DANA ES2847R 3/4"x16 RH Thread 86-96 Dodge 1/2, 3/4, 1 ton 4x4 w/ 3500lb. axle (DANA 44) ES2847L 3/4"x16 LH Thread 86-96 Dodge 1/2, 3/4, 1 ton 4x4 w/ 3500lb. axle (DANA 44) ES361R 11/16"x18 RH Thread 66-78 Eldorado & Toronado Camaro based racing front ends (outer) ES370L 5/8"x18 LH Thread 65-68 Bel Air, Biscayne, Caprice, Impala Interchanges with 5/8" rod end ES370R 5/8"x18 RH Thread 65-68 Bel Air, Biscayne, Caprice, Impala Interchanges with 5/8" rod end I use 3/4 right hand thread. #ES150R to split bones.
