Hi HAMBer! we're hot rodder from Switzerland / Europe and where at the Turkey Run last year. This year we're planning to to eather to the Goodguys Show in Indianapolis or Rhinebeck... we have to look for "easy" flights to the US... So, is Rhinebeck a good show? Some cars to buy eventually? Or are there much better car shows - we cannot go to Louisville this year... Thanks for your advice and tip!! Peter
When will you be here? If you'll be here in October, you could catch the Pileup (http://www.hunnertcarpileup.com). Chicago has an international airport and is about a 4 hour drive from Indianapolis. If you'll be here in June, there's BilletProof East in Detroit, which is about 5-6 hours(?) from Indianapolis, and there's the Road Rockets' show at the Rockabilly Rebel Weekender in Indianapolis... Gears and Ears in the suburbs of Chicago, Kropdusters' Rust Revival in Missouri, the Blacktop Barons' Road Block, and the Tin Benders' show in Northern IL. End of June/beginning of July is the HAMB Cinematic in Ohio...5-6 hours(?) from Indianapolis... and tons of other shows... it all depends on when you'll be here
