Hot Rods ---The Dash, 1925 Chev Roadster Update.---
Discussion in 'The Hokey Ass Message Board' started by Jimmy B, Dec 11, 2009.
  1. I got my gauges laid out where I want them. The VDO tach will be replaced when I find a SW tach I can afford. I have an AC oil temp gauge for the empty hole. I also need to find a SW Auburn style temp gauge.
    & decide to remedy the uphill bonnet (hood)
  2. MengesTwinCustoms
    MengesTwinCustoms
    I really like the race style, looks bad ***. I also like the two upper gauges with the cool needles. Keep up the good work!!!
  3. lowsquire
    lowsquire
    from Austin, TX
    Nice!your alloy fairings look great!!
    Those damn whippet grilles are always rusted at the bottom anyway,
    cut it shorter-problem solved!
  4. Cheers Lowsquire!!
    The two I have are both rooted at the bottom. I have one in the mol***es at the moment once it is out I need to send it down to Drewfus.
    I am using the original radiator so that restricts me to how much I can lower it.
  5. SuperFleye
    SuperFleye
    Alliance Vendor
    Looking good Jimmy! Primitive and raw just like back in the good ol' days!
  6. Cheers!! The Crescent pointer SW gauges are a pain to locate, but when they fill out the dash like that there is nothing better.
    Cheers mate!!!
  7. Oh, forgot I have been working on a track nose but have put it on hold. decided I do like the whippet shell more :D
  8. Stovebolt
    Stovebolt
    Jamie - I have a FC Holden radiator which I'll never use - its supposed to fit the Whippet grill shell.
    do you want me to measuure it?
  9. sololobo
    sololobo
    So damn cool!! Love that bad boy!! Thanx for sharing it with us!! ~Sololobo~
  10. have you thought about having the hood seam follow the door line down, like it does in some of the original pics?
  11. Yeah if you could, thanks!! Murphy's Law, it will fit, how do I know? When I traded my EK I included the spare radiator I had and they are the same as FC.:(:(
    Thanks ~Sololobo~
    I can't go down much more as there won't be enough clearance between the engine & bonnet. On the original it has a slight uphill bonnet.
  12. dont lower the hood, the change the hood seam...so the seam follows the body line. Just like in the historical pics you posted.
  13. I really like that car and for some reason the uphill hood never bothered me. It kind of adds to it's charm.
    The dash looks great too.
  14. True it adds charm, but it was starting to bug me to the point I didn't work on the roadster for a month. I'm real happy with how the dash turned out.
    I don't have the tools to change it and can't afford another sheet of Aluminium to make another.
    (above: right side hoodside needs to be bolted at the bottom)
    simulated dry lake dust :rolleyes:
  15. autobilly
    autobilly
    Dash layout looks ripper Jimmy, good luck gettin' an SW tach. Give us a front 3/4 shot when the bonnet/hood is done.
  16. Jay Rush
    Jay Rush
    Good looking car I have liked this car since i first saw one of your threads keep up the good work
  17. i havent a clue where Tweed Valley, NSW is (other than Oz), but i look forward to one day seeing it (I hope it is near the wine country) I am a serious fan of your car!
  18. Royalshifter
    Royalshifter
    Moderator
    Looks right out of the early books.
  19. OoltewahSpeedShop
    OoltewahSpeedShop
    Looking good Jimmy, keep it up.
    Kevin
  20. Thanks Nic.
    Thanks Jay.
    Nowhere near wine country. I'm 1 hr southwest of the Gold Coast. This roadster may find its way stateside one day.
    That was the goal :D
    Cheers Kevin!
  21. I like the lower look, good progress.
    Radiator - also try Suzuki Sierra, might suit your situation depending on position of chev outlets.
    gauges...let me see....
    Are you going to tinker a bit with that drum at the front....(over spring & axle?)
    good progress, how much alloy do you need for that top, will PM over the next couple of days.
    Cheers, great to see your progress,
    Drewfus:)
  22. 29bowtie
    29bowtie
    The artist in you, wouldn't let you accept that uphill bonnet,would it? You are doing a great job, of capturing the "early era of hot rodding", keep up the excellent work.
  23. Cheers!!
    Thanks for the suggestion will keep it in mind
    :D:cool::D
    Yep, going to lower it and make the blister bigger.
    I only need a bit for the bellypan, if I can sell the '29 I will buy a couple more sheets and use the left overs on the streamliner/lakester.
    Pretty much, the bonnet angle stuck out like dog balls, I'm glad I fixed it. Thanks for the encouragement.
    Cheers
    jimmy
  24. [​IMG]
    Jimmy,
    Hands down, one of my favorite pics- love that early 4 peekin' out from under the shell!
  25. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Awesome!!! Love this thing.
  26. freebird101
    freebird101
