"the desert express.1951 ford coe pick up"
Discussion in 'The Antiquated' started by iwanaflattie, Feb 21, 2012.
  1. iwanaflattie
    iwanaflattie
    I'm going to straighten the rear since the frame I found is a suburban and the coes is a c20..then I'm going to weld them together and bolt everything back after I clean and rebuild everything.
    Question for the knowledgeable.
    I'm thinking of making it a dually but using the booster and brake lines...will that work with the bigger brakes?
    Again,I don't plan to haul anything heavy.
    Thanks.
    b-bop, brEad, Lone Star Mopar and 5 others like this.
  2. tb33anda3rd
    tb33anda3rd
    check with the part store to see if the dually uses the same booster.
    Okie Pete and Kelly Burns like this.
  3. RMR&C
    RMR&C
    from NW Montana
    booster should work, but the master cyl might be bigger bore for the dually as they use 3 in wide rear shoes. Also be aware, the Chevy dually pickup rear is wider than the cab/ch***is rear by quite a bit.
    Which leads to the question"how is that going to fit under the fenders?"
    Okie Pete likes this.
  4. 38Chevy454
    38Chevy454
    I don't think you will have any issues with using the current booster and master cyl. Drum brakes especially use pressure more than volume of fluid.
    rod1 and Okie Pete like this.
  5. Okie Pete
    Okie Pete
    Thanks for sharing your progress on the COE
    rod1 likes this.
  6. iwanaflattie
    iwanaflattie
    Thanks for all the replies and suggestions.
    I decided to keep it SWD for now..
    I took both frames apart,the suburban frame is only the same from then front of the rails so I'm going to use the rear frame section of the OG coe frame..
    But that means I have to square and straighten it out before welding it together..
    I took a bunch of measurements..every part that gets unbolted got cleaned and painted...
    I'm building an extention to my Wall so I can get rid of the temp chain link,after that I'll start building the frame.
    I also bolted the good fender since mine is too much to repair..the metal has stretched and twisted too much for me to mess with.
    20250511_133449.jpg 20250511_133452.jpg 20250511_133506.jpg 20250511_133525.jpg 20250511_133518.jpg 20250511_140737.jpg 20250511_140745.jpg 20250519_200808.jpg 20250519_200801.jpg
    b-bop, Squablow, pineknot4 and 6 others like this.
  7. tb33anda3rd
    tb33anda3rd
  8. Okie Pete
    Okie Pete
  9. iwanaflattie
    iwanaflattie
    ****s going back together..
    Taking advantage of the cooler weather this weekend.
  10. The37Kid
    The37Kid
    Good to see progress!
  11. Okie Pete
    Okie Pete
  12. RICH B
    RICH B
    Thanks for the update; looking forward to your truck hitting the road again.
    Kelly Burns likes this.
  13. iwanaflattie
    iwanaflattie
    Thanks boys..
    I can't wait for cooler weather and for my truck to be running around town again.
  14. tb33anda3rd
    tb33anda3rd
    wish I was there to give you a hand Seth.
    it was hotter here this week than it was there a couple days.:eek:
  15. iwanaflattie
    iwanaflattie
    Man that would be nice..i deff need help.
    Been running a one man show for a minute now.
    It was hot this weekend but a desert rat can survive.
  16. iwanaflattie
    iwanaflattie
  17. iwanaflattie
    iwanaflattie
  18. The37Kid
    The37Kid
    Like the progress photos!
    Bob
    Okie Pete and warhorseracing like this.
  19. Okie Pete
    Okie Pete
    Looking good
  20. RMR&C
    RMR&C
    from NW Montana
    Looks great! The fender color matches pretty good
    warhorseracing and Kelly Burns like this.
  21. iwanaflattie
    iwanaflattie
    Thanks guys...my baby Is running great..just need to bleed the brakes again,splice all the lights,install p*** gl*** and install the rest of the cab skirts and battery cover
  22. iwanaflattie
    iwanaflattie
  23. Real cool pics and truck:cool:!!
    iwanaflattie likes this.
