History THE DREADED PREVIOUS OWNER
Discussion in 'The Hokey Ass Message Board' started by bobg1951chevy, Jan 7, 2017.
  1. How many threads or posts have we read, where the "P.O." screwed up something, making our work ***ignment a longer experience in the garage.
    Darn those P.O.'s, don't they EVER do anything right ?
    WE continue to buy from those P.O.'s , but then we're continually punished by the actions of those darn P.O.'s.
    But then, after regaining my composure, I realized I was a P.O., as well !
    Certainly, no one could ever complain about my work. :confused:
  2. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Some POs screw things up so bad that they paint themselves into a corner and have to sell.
  3. hotrodA
    hotrodA
    I hope that I'm going to leave my 32 sedan in better shape than I found it. It's been abused with more than its share of PO caveman engineering. Just look at my build thread.
  4. too many fords
    too many fords
    from Las Vegas
    If everything was built by a pro, it would be too expensive
  5. Larry T
    Larry T
    When I bought my 34 International pickup, it was always "Oh, you've got Jackie's old truck." I changed everything front to back/top to bottom and it was still Jackie's Old Truck right up to the day I sold it when it magically became Larry's Old Truck. :D
  6. gimpyshotrods
    gimpyshotrods
    You got that right. I am a pro, and I cannot even afford to build myself a car.
  7. stanlow69
    stanlow69
    How many times have you heard the P.O. wants to buy his old car back. But the current owner has had it for 30 years. And the P. O. only had it for 4 years.
  8. A job can be performed correctly, whether a pro or a hobbyist.
    The problem arises when repairs are done with "caveman engineering", as noted by hotrodA.
    That phrase really sums up some of the messes that we see.
    Like hotrodA suggested, leave it better than when you found it, a good motto.
    Bruce Fischer, mad mikey and RMONTY like this.
  9. Texas57
    Texas57
    Ha, mine was 100% built by the PO (Present Owner)....got no one to blame but me.
  10. mgtstumpy
    mgtstumpy
    Plenty of shade tree mechanics are PO and think they are the bees knees when it comes to engineering and other technical skills. No warranty claims whatsoever with anything I've built and sold. Maybe I'm too pedantic and won't lower my standards or cut corners unlike some! Do it once, do it right.:D
  11. Just check my signature link, that's one hell of a PO horror story.
  12. gnichols
    gnichols
    from Tampa, FL
    In the blowing your own horn department... when I sold my 37 Fordor (first build) several large, 3-ring binders full of info went with the car - instruction sheets from every aftermarket component, part numbers, saved box ends, lots of build pix etc., etc.. I didn't put the books together so much with resale in mind, but for myself. Who wants to guess at the part number with the counter guy if you already have a record of it or the actual box end with the part number? While this doesn't mean I built a perfect car, I felt pretty proud of myself when I turned over the books with the car, thinking that would be a big help for later for others. Unfortunately, that new owner wasn't much of a car guy. He called me several times about this or that, but when I suggested he look in his books, he said he'd have to haul them down from the attic to do that... Gads. The car has a 3rd owner now and I hope he got the books with the car. Gary
  13. The Previous owner did it, sounds alot like the guy who says "my buddy did that" at the swap meet.:D
    LOU WELLS likes this.
  14. tb33anda3rd
    tb33anda3rd
    just keep telling yourself.........at least he didn't junk it.............although in @31Vicky with a hemi case it may have been better off..........:eek:
  15. upspirate
    upspirate
    How many WFO (wanna be future owners) tell you how THEY would have built your car at car shows??!!!
  16. flamedabone
    flamedabone
    P.O.
    Fixed.
    P.O.
    Fixed.
    P.O.
    Fixed.
    P.O.
    Fixed.
    -Abone.
  17. 4dFord/SC
    4dFord/SC
    Sort of like "PM" (Previous Mechanic), as in "Who worked on this car last?"
  18. I hope I get it finished before I need diapers
  19. Ned Ludd
    Ned Ludd
    Perhaps we're inclined to accept P.O. bodges in areas we're looking to redo anyway. The mild steel plates bolted under the rusted-through floor of my Morris is a case in point. Problem is, I wasn't able to do my modifications as quickly as I'd hoped, and I ended up driving the car that way for a few years. The car is laid up now but the work has still not been done.
  20. wicarnut
    wicarnut
    A good piece of advice given to me many many years ago, when buying a used car/rod/anything, exspect to have fix something's and spend some money on it. The car Hobby is full of hobbyist, not pro mechanics and pro builders, granted there are Pro's involved but the majority of buyers, sellers are not on that $$$ level IMO. In my own experiences, I just appreciate some honesty from seller, not thats always been the case, I have been fortunate and never been burned badly, when I buy cars/things, try to be smart, educate myself about subject and not let my emotions take over. On the other hand, when you see a car that just trips your trigger, buy it, because IMO no matter what, you will still be happy with it. IMO, this hobby is about P***ion, have had several cars/rods and they always make me smile/happy and when that wears off, it's down the road to its next owner/care taker, always better than when I received it, never perfect as any of my cars are not at that level of perfection and $$$ value.
  21. 283john
    283john
    You did a good job. Looks a lot like a '57 Ford.
  22. 41 C28
    41 C28
    Remember that we are talking about OLD cars here and that's just what they were to someone (P.O.) at one time. The P.O.'s that worked on them originally probably were just trying to get by and worked with what they had just so they had transportation. Examples are screen wire, steel wool and gallons of bondo vs. tig and mig welders and fancy shop tools. Be thankful for P.O.s because we have em now.
  23. Texas57
    Texas57
    ??? HaHa. thanks, I think.
    Only looks like a '57 Ford on the outside.
    283john likes this.
  24. stanlow69
    stanlow69
    It`s funny when someone starts with a pile of ****. Restores the car. Then the P.O. tells everybody it used to be his.
  25. Texas57
    Texas57
    One thing I've figured out...if I ever buy a driver from someone, it won't be somebody who's afraid to take it out of town. My avatar pic was taken about 350 miles from home at Lake Texoma..just out on a weekend cruise before winter set in. I put about 8K miles on it in it's first year after driveable (still not finished. 11 year build, my first). Makes me wonder about cars you see for sale with 300 miles driven since finish. wtf?
    and Lake Texoma 007 crop,adj.JPG even full size, it still looks like a '57 Ford, lol.
    I've posted this before...yes, I did ignore the "NO PEEING" sign.
  26. Gman0046
    Gman0046
    I'd rather start from scratch on a project rather then try and repair someone else's screw up's. Its much easier in the long run. Some of these PO screw ups I've seen posted on the HAMB are down right dangerous.
    Gary
    Bruce Fischer and bobg1951chevy like this.
  27. bobss396
    bobss396
    This is how my Ford was, virtually untouched and missing parts. Can't screw up what is not there. I can take the blame for everything I've done on it.
    Bruce Fischer likes this.
  28. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    If you start wearing them now, you will have more time to get the car done.
  29. Montana1
    Montana1
    This car has no PO... That being said, I'm sure there are some things that I could have done better, but this is my first attempt with hot rods. I'm very pleased with how it came out, and the next owner will be my kids or grandkids. They will have to figure it out then.
  30. warbird1
    warbird1
    Where would WE be without THEM to blame it on...
    bobg1951chevy likes this.
