Projects The Elza Coupe - 26 T Gow Job build
Discussion in 'Traditional Hot Rods' started by rail job, Sep 28, 2014.
  1. pumpman
    pumpman
    Glad to hear things are working out for and you're back on the project. Good luck man.
  2. volvobrynk
    volvobrynk
    from Denmark
    If she likes hot rod too, you are one lucky SOB! And that was meant in a good way!
    And now the two most *****ing early coupes is in one thread! Yours look damn fine.
  3. 117harv
    117harv
  4. rail job
    rail job
    from Michigan
    1436146273907.jpg Lol at the important notice. Funny really.. one of her fave foods is pizza. I can't believe how low that coupe is!!!
    Also.. thanks for the kind of welcome back. Hambers digging my build mean I a lot.
    Got the column out this week and started making room to remove the body. Also scored some lumber from work so I spent Friday cobbling a bench to mount some tools. Put the blast cabinet together a couple weeks ago. Coming to together now..:)
    kidcampbell71 likes this.
  5. Deuced Up!
    Deuced Up!
    I like the way you are thinking man!
  6. rail job
    rail job
    from Michigan
    1436411460617.jpg 1436411471124.jpg 1436411600232.jpg Thanks dueced up.
    In other news... Houston, we have lift off. Lots of work by myself but I'm glad it's off. Time for the fun stuff!
    Tim and kidcampbell71 like this.
  7. rail job
    rail job
    from Michigan
    1436662955121.jpg 1436662971993.jpg 1436663000916.jpg 1436663017366.jpg 1436663033675.jpg 1436663182987.jpg Been a while since I scored some parts so I took a little field trip today. Got some A goodies I'm quite happy about. I plan on cutting the suicide front off because I don't want it that low and it's not era correct but the frame is nice.
    I'll keep the kick up, reverse eyes and remove front leafs with the stock axle to get the initial stance. Going mechanical brakes too.
    The A plan is coming together!!!
    kiwijeff and volvobrynk like this.
  8. pumpman
    pumpman
    Lookin good man!
  9. rail job
    rail job
    from Michigan
    1437258148464.jpg 1437258158604.jpg 1437258168220.jpg 1437258191173.jpg Thanks pumpman.
    Another big day for the coupe. Banger is in my possession and it's crunch time to get it up and running.
    Started planning where to take 3" out of the frame so the wheelbase will be 101.5. This should give me just enough room to get the head off if I need, center the rear tires, and look pretty good.
    Markings on the kick up show what I will trim to clear the rear sub frame. Once I mock up the body I'll fab rear mounts donward so I don't have to cut such a nice body.
    The banger is a fresh rebuild, touring cam, lightened flywheel, and v8 clutch. For now I'll run a stock carb, down draft next year.
    Excited like a little kid I am. :)
    I'm also on the lookout for some nice model a front hubs and drums if anyone has anything I can use.
    volvobrynk and kiwijeff like this.
  10. chessterd5
    chessterd5
    from u.s.a.
    I like the banger.
    It might be better & easier to C - notch the sub-frame inside the trunk than cut the frame crossmember.
  11. rail job
    rail job
    from Michigan
    Thanks man. I thought quite a bit about notching the sub frame. If the body wasn't as nice as it is I would. The thought of cutting it makes me feel bad.. hahaha.
  12. Cut that thing, yourll love it. :D
    Once you start, it'll be easier.
    Nice to see your still plugging away at it. I'm keen to see more. :)
    volvobrynk likes this.
  13. Kiwi 4d
    Kiwi 4d
    Every hot rod t is cut , stand out from the crowd and stand tall , like T tall, be proud to be tall. Channel or Zee the frame to your hearts content .Keep the flathead so you can enjoy the drive at highway speeds.
  14. rail job
    rail job
    from Michigan
    1437835242681.jpg I'll trim for the frame but the top is staying tall and proud.
    As of this week tires have arrived and I will be cutting the frame today so I can start mocking up.
    Also another score. My girlfriend was nice enough to find a legit medical blanket to cover the seat. Looks like she is a keeper!
    gwhite, volvobrynk and kidcampbell71 like this.
  15. rail job
    rail job
    from Michigan
    1437965384002.jpg 1437965400372.jpg 1437965411495.jpg After a rather boring thread covering a year of gathering parts I'm glad I can finally say I started cutting some stuff. Productive weekend overall and I realized it's been quite some time since I did any welding.
    As of today my frame sits 3 inches shorter! Make up a few plates to box my seams and it's time for mock up. Damn I'm excited.
    gwhite and volvobrynk like this.
  16. pumpman
    pumpman
    Damn, you are spot on about that frame, it's beautiful! Nice job on the cut.
  17. brad2v
    brad2v
    I really like this build. Still keeping the fenders? And count me as one of the weirdos that enjoyed the paint discussion.
  18. soddruntlestuntle
    soddruntlestuntle
    from Fresno, CA
    I love tall T's and I love history, would kill (or at least maim) for a T like this. Kudos to you.
  19. rail job
    rail job
    from Michigan
    Thanks pumpman. It's been a while but I'm getting back in stride.
    Thank you.
    First rendition will be no fenders. I have a look in my head for now. If I decide to do fenders I'm thinking about Model A. My friend whom I worked out with the trade with took my fenders. I'll be revisiting paint in the near future once I start scratching on it. Plan remains the same to preserve what I can. I've been experimenting a bit more and I'm quite happy with the results.
    Good stuff, man. and thank you. Something is just too cool about a Prewar Tall T in my book. :)
    Nothing new as of today... Cutting the suicide front, and collecting more hardware. Took my perch pins out of my factory axle so I can run the drop.. Those were some cranky little *******s!
    Outback and volvobrynk like this.
  20. rail job
    rail job
    from Michigan
    Well, another productive weekend.
    After I cut off the suicide fronts I notice some loose rivets and a couple small cracks in the original crossmember. Considering this is much easier as a two man job I loaded up my frame and headed to a undisclosed location to meet up wither fellow hamber, Rogi / also a member of L.E.D.G for some help.
    Rogi is pretty ******** into t's and is who I worked out the trade with for my ch***is. Great all around guy and it was awesome letting me back out to do some work.
    After some sweat, grinding and torching we replaced a few rivets, tightened the others all the old school way, welded some cracks, and I'm still within an 1/8" square. Not too bad for my first time.
    I also reversed the eye on the front, made some caps for the front out of s**** from the frame, added a brace to my seam then something I should have thought about caused me a whole day of work today.
    In retrospect I should have shortened the frame between the emergency brake member and the rear taper. Then I wouldn't have needed to clearance the crossmember for the ujoint ***embly... Oh well, lesson learned, thought about, planned it out and started cutting... That's about it for now. I think I'm cruisin pretty good.
    1438566831769.jpg 1438566846368.jpg 1438566894518.jpg 1438566926922.jpg 1438566942065.jpg 1438566959383.jpg 1438566987990.jpg 1438567006767.jpg
    Outback, brad2v and kidcampbell71 like this.
  21. Dick Stevens
    Dick Stevens
    One small request, if when you post the pictures, select full size for the images it will make it easier and more enjoyable for those of us following your build thread. Thanks :D
    Outback likes this.
  22. rail job
    rail job
    from Michigan
    Are they displaying odd, ****? I did this from my phone as attachments.
  23. Dick Stevens
    Dick Stevens
    They display small and we have to click on them and wait for them to open up, when posting it gives you the option to post them as full size images, then we can view them without waiting. It's not a big deal just makes it easier and quicker for us.
  24. Dick Stevens
    Dick Stevens
    Outback likes this.
  25. rail job
    rail job
    from Michigan
    Consider it done. Didn't know I had that option on my phone!
  26. rail job
    rail job
    from Michigan
    So.. after working on the frame I started thinking about my 16" wheels and how they weren't sitting with me.... Given it will be tall, with a banger, and mechanical brakes I felt a larger wheel would look more at home and be more proportionate to the roof so I decided to go 21" and pay a little homage to the first graphics I laid on a car in my teens with the color.
    Digging the firestones too. :) 1438970348958.jpg
    They actually mounted pretty easy using a garbage bag and one iron. Can't wait to set this thing on the ground!
    Outback, LBCD, brad2v and 1 other person like this.
  27. rail job
    rail job
    from Michigan
    While the girl is away on business the boys work hard on their car. Another productive weekend so far.
    Friday night I mocked up the front axle and messed around a bit. Also took apart the rear spring. 1439129943354.jpg
    Ready for ***embly. I cut the 3 I took out for spacers.
    Back together. I found using 4 clamps along with the rod mad the job pretty easy and a lot less unsettling considering the pressure of the spring.
    Then late last night I enter my favorite part of mockup. That feeling when the tires hit the ground for the first time then you step back and take it in for a few. Man I love it.
    The plan was just a little rake. When choosing tires I decided to run a 5.50 rear. When I received I thought they might be too big but man, I dig it and think it adds just enough hot rod stance to an almost prewar feel.
    Love how it's sitting!
    Hopefully soon I'll have the body on so I can build mounts. Saving the driveshaft as the last fab piece so I can have some fun for a bit.
    Gotta say after so many years of lurking on this site and waiting for everything to align so I can start building I'm quite happy to finally be at this point and share with you guys.
    Outback, gwhite, chessterd5 and 3 others like this.
  28. pumpman
    pumpman
    Stance, banger, big *** wheels just doesn't get any better than that. Great out come. Can't wait to see the body on her.
  29. rail job
    rail job
    from Michigan
    Thanks man!
    I can't wait to set the body down. Have to do a bit of clearance for the kick up but it should be pretty soon.
  30. orangeamcs
    orangeamcs
    I went w 21st on my banger also. Just gives it the old school feel
