The Filling Station
Discussion in 'The Hokey Ass Message Board' started by spiffy1937, Feb 19, 2012.
  1. spiffy1937
    spiffy1937
    from Florida
  2. You want to get a hold of
    ECI guy on here. The best
    In my opinion
    1-866-872-7046
  3. I built one like that myself. Mine seems to work ok. I have a v-8 in my car and the exhaust is pretty close to the brake lines though.
  4. spiffy1937
    spiffy1937
    from Florida
    I have used alot of ECI products on other cars but this '50 Chevy Fleetline has the clutch and brake pedal pivots right on the master cylinder and I want to keep it that way for now. Thanks TIMMY P, I am figuring on making one.
  5. TagMan
    TagMan
    I built my own that looks identical to the one The Filling Station sells, using my stock m/c as the base. It took a bit of work, but it was a fun project and works great.
  6. pbr40
    pbr40
    from NW Indiana
    where was this thread a couple weeks ago?! no i ended up fabn up a bracket to use stock pedals. i used a corvette mc for the ease of things
  7. ooooh fancy corvette parts!
  8. He has a kit that uses the stock pedals and mounts
    Like the stock master only better
  9. I made my own. Way less $$$. I used a 67-76 Vette NON POWER M/C. It keeps the original M/C so nothing changes with your stock pedal location. Todd
  10. Other than the master ends up under the seat it's fine, you have to either change the access or rig up a remote fill.
    It's even cheaper to just put it on the firewall - if you have a clutch, leave the stock one there for the pivot and unbolt the top of the brake pedal arm.
  11. Hellfish
    Hellfish
    I had one. It was well-made and worked well. Buffalo Enterprises makes them for Filling Station. I think you can order them direct, but it's the same cost. Filler acces wasnt a big deal. I just cut a new hole.
    Moving it to the firewall requires reinforcing the firewall.
  12. spiffy1937
    spiffy1937
    from Florida
    Thanks DIRTBAG54. I'm going to be calling ECI in the morning to find out more about the EC-440S mount. I like everything else that I've ever purchased from them.
  13. N2hotrods
    N2hotrods
    I have used the filling station product 3 times works well, no complaints.
  14. spiffy1937
    spiffy1937
    from Florida
    Thanks N2hotrods.
  15. spiffy1937
    spiffy1937
    from Florida
    I just spoke to the guy at ECI and after finding out more about the EC-440s I ordered one. $159.95. It bolts in the stock master cylinder mounting holes and has the bushed pivots for both the clutch and brake pedals. The dual master cylinder is going to be great with the front discs I just ordered from Eckler.(President's Day discount) Thanks DIRTBAG54 and everyone else that replied. HAMB is excellent!!:)
