Projects The Flathead Flathead
Discussion in 'Traditional Hot Rods' started by Jeff34, Aug 30, 2021.
  1. Tim
    Tim
    from KCMO
    Let me send those photos to my starter guy
    Jeff34 likes this.
  2. Tim
    Tim
    from KCMO
    Ok talked to a few people who’s opinions I trust and while a lathe would be the most ideal, you could use a fine file to knock the chunks off and then finish it with some Emory cloth and be on your way.
    Jeff34 likes this.
  3. Dedsoto
    Dedsoto
    from Australia
    I put my a starter in my drill press, like a kinda vertical lathe
  4. Jeff34
    Jeff34
    Thanks @Tim Appreciate the help on this. I've replaced starters, but haven't ever tried to repair one.
    Thanks @Dedsoto This might be a good solution since I don't have a lathe.
  5. Tim
    Tim
    from KCMO
    No hill for a stepper man ;)
    Outback and Jeff34 like this.
  6. Jeff34
    Jeff34
    IMG_5415.jpeg IMG_5416.jpeg IMG_5417.jpeg While waiting to hear back from the builder on what I should do, I tried to be as productive as I could. Mounted the seat with the seat slide and belts. For now, the belts are clipped to the seat, which seems OK for the moment. Future state will be much more secure. I also cleaned up the commutator on the starter and ordered new brushes and springs.
  7. Tim
    Tim
    from KCMO
    Looks great! That seat sure fits nice!
  8. MojoRacing
    MojoRacing
    That seat is killer! Is that a Dodge Caravan 3rd seat?
  9. Jeff34
    Jeff34
    Tim and MojoRacing like this.
  10. MojoRacing
    MojoRacing
    I like how compact it is and seems to sit low to the floor. I think that would be perfect in my 29 RPU.
  11. Jeff34
    Jeff34
    @MojoRacing I had planned to put it on the original seat riser, but it was too tall. Felt like I was sitting ON the car and not IN the car. Thought about sectioning the riser to make it smaller, but that just wasn't working out. I also wanted adjusters on the seat since my wife is shorter than me and needs to be moved forward to drive. Ended up with some cheap sliders from Speedway. I also added a 2" riser on the front, so I'm about 3" from the floor to the bottom of the seat in the front, and 2" from the floor to the bottom of the seat in the back. It also slides at a bit of an angle (up) so as you slide forward the seat moves up as well. Turned out pretty good.
    Still trying to calm myself until I can talk with the builder, so I'm doing what I can to move forward without stressing myself out...
    Deutscher, Outback and loudbang like this.
  12. Jeff34
    Jeff34
    Talked with the builder today. He thinks the resistance to rotation by hand is O.K. Starter ****ping out was the problem, so I'll get the starter put back together with new springs and bushings and see if it's up to the task. I don't think I'll have the parts to do that before this weekend, so it will have to wait until I'm back from a week long trip to get it back together...oh well.
    J.Ukrop and 1-SHOT like this.
  13. Jeff34
    Jeff34
    So I could use some help with my starter. I cleaned up the stator (if that’s what it’s called) and replaced the brushes. All of the copper contacts on this are connected electrically. Seems like it would be shorted? Any thoughts, ideas, or guidance for this old **** would be appreciated!!! IMG_5433.jpeg
    bchctybob likes this.
  14. patsurf
    patsurf
    get another armature at the very least--but easier to find a starter prob,,,,
    Outback likes this.
  15. Tim
    Tim
    from KCMO
    You have to remember that engine has compression. That’s going to give you resistance turning it even with the plugs out
    Outback likes this.
  16. roseville carl
    roseville carl
    you need to cut down the insulators between copper segments, years ago before I got a commutator cutter I used to use a hacksaw blade 32 tooth cut down to about 8ins and taped a handle so I wouldn't cut my hands, it will remove the insul material easily
    3blapcam, CSPIDY, loudbang and 2 others like this.
  17. Jeff34
    Jeff34
    Thanks for the input, guys! Looked into this more last night and I think I figured it out. I was only looking for continuity between things. Turns out that I should be looking at the actual resistance numbers. My multi-meter will beep even if resistance is low. I checked resistance between the elements (adjacent and across) and it seems fine. Put it all back together and it spins like a Tasmanian devil! I’ll put it back on the car and try it again later today
    3blapcam, Deutscher and Tim like this.
  18. Jeff34
    Jeff34
    Got it back in the car. Spins like a banshee!
    I consider this a job…done. Next, accelerator pedal setup, brake bleed, etc.
  19. Tim
    Tim
    from KCMO
    **** yeah! And now YOU are the neighborhood starter guy! Congrats haha
    J.Ukrop, Deutscher and Jeff34 like this.
  20. Jeff34
    Jeff34
    Got my exhaust blasted and painted with VHT. I’ve got to finish some wiring before I cane fire it off again, and figure out my accelerator linkage. IMG_5463.jpeg IMG_5464.jpeg
  21. Tim
    Tim
    from KCMO
    Looks good!
  22. Jeff34
    Jeff34
    Thanks @Tim
    new paint isn’t as glossy as I was hoping, but it will have to do. Got everything mounted back up again. Moving on IMG_5466.jpeg IMG_5467.jpeg
  23. Jeff34
    Jeff34
    Got most of my electrical roughed in...at least enough to make sure it all worked. I also put a couple of gallons of gas in the tank to run the pump and check for leaks. Then I rolled it part of the way out of the garage to give it a run and make sure it all still worked. If I had a gas pedal, I probably could have driven it Saturday. Probably another week or two and then it should be on the road...
    Here it is with the silencers in the tailpipes:
    And without silencers:
    bchctybob, 3blapcam, jaracer and 6 others like this.
  24. Tim
    Tim
    from KCMO
    Oh baby! That ****er sounds great! You’re nailing it on that hot rod! You and Ukrop need to get hose roadsters together!
    Jeff34, J.Ukrop and MojoRacing like this.
  25. Jeff34
    Jeff34
    Nearly done with my accelerator linkage. I used an old A bracket. Cut off the pieces I wanted and made it work. I connected it to the left side linkage of the carbs. Bolted to the firewall with some cool bolts I had. Used the A return spring to help push the links back. I think it will work fine IMG_5514.jpeg IMG_5511.jpeg IMG_5512.jpeg IMG_5513.jpeg IMG_5518.jpeg IMG_5516.jpeg IMG_5521.jpeg IMG_5520.jpeg IMG_5522.jpeg IMG_5525.jpeg IMG_5527.jpeg
    jaracer, ZerroHalfcup and CSPIDY like this.
  26. Tim
    Tim
    from KCMO
    I like that!
  27. Jeff34
    Jeff34
    Tim likes this.
  28. Jeff34
    Jeff34
    Driven out of the garage under its own power for the first time today. IMG_5579.jpeg
  29. Tim
    Tim
    from KCMO
    Oh ****! It’s roadster season! Congrats!
    Jeff34 likes this.
  30. Jeff34
    Jeff34
    One more. The center tail light is just to hold the tags until I can find something else IMG_5580.jpeg
