The Flaven & Flaven Model A build.
Discussion in 'Traditional Hot Rods' started by Pete, Nov 23, 2014.
  1. Pete
    Pete
    Had some time today....started on the pedals, using F1 pedals. Made a plate that will later get boxed both top and bottom. Making the clutch linkage is going to be tricky.
    volvobrynk and patmanta like this.
  2. Crankhole
    Crankhole
    Is there an adapter available to run that MC with the F-1 pedals...or did you build one?
  3. Great build, enjoying this a lot.
  4. Squirm
    Squirm
    from New Yawk
    Doze Nutz look great !!
    Keep up the great work !
  5. Pete
    Pete
    Cooter,
    I built the adapter.
  6. Pete
    Pete
    Pedal mount done and tacked in place.
  7. Pete
    Pete
    Squirm.....
    Dude....
    Allah called looking for you......Allah deez nuts!
    kidcampbell71 and russellmn like this.
  8. '54Caddy
    '54Caddy
    Did you use your CNC plasma to make that bracket? ;)
  9. Pete
    Pete
    You betcha!
  10. wheeldog57
    wheeldog57
    i like the "lincoln" work bench, i have one just like it
  11. Pete
    Pete
    Everybody should have one....
  12. Pete
    Pete
    Were in the shop right now working on the roadster, Mike has a hall pas tonight so we're knocking stuff off the list.
    We cut up a model a headlight bar, heater and bent it, re welded the cross bar in. Bolted some guides on... Me like
    kidcampbell71 and volvobrynk like this.
  13. Pete
    Pete
    Just finishing up the modified F1 front shock mounts, shortened them drastically than re positioned the frame mount side.
    Shocks are done. We're starting on the ressrs now. I'll post real time updates.
  14. Pete
    Pete
    Spent some time on the rear shock mounts but shoot it was midnight and we were tired.
    Interesting tid bit.... Jeep front shock mounts work perfect as rear shock mounts. I'll post a pic of them in a few.
  15. louisb
    louisb
    Great build so far.
    --louis
  16. Shamus
    Shamus
    from NC
    Looking good, Pete. Maybe I'll stop for a visit - family reunion will be in Oxford in August.
  17. Pete
    Pete
    Shamus,
    Let me know, it would be great to meet you.
  18. Pete
    Pete
    Progress....
  19. rust
    rust
    what jeep?
  20. damnh6
    damnh6
    from australia
    Great build watching with interest as I am about to start my A model hiboy project soon ,nearly have enough parts to get serious putting pieces together . What type of master cylinder have you used? Thanks Gary.
  21. patmanta
    patmanta
    from Woburn, MA
    Hey there Pete, how many leaves / what spring are you running out back?
    I've been racking my brain and considering a double pie cut to drop and shorten my frame on my build, but I know I'm going to have trouble dialing that in if I go that route versus how you went. It looks like you've got a comparable spring to the one I've got kicking around. I've also got a 4" drop axle in front so I'm eyeballing your stance here.
  22. Pete
    Pete
    The rear spring is stick model A, I'll ask my brother if he removed or added any springs.
    patmanta likes this.
  23. Wheeliedave
    Wheeliedave
    I like the work you're doing! It is very nicely done.
    Whose steering arms did you use and where did you purchase them?
    It appears they would work well on my '32.
    Thanks, Dave
  24. Pete
    Pete
    Dave,
    I think mike got them from speedway, not 100% sure.
    The shock mounts came off a '79 cj frame but are the same up to the late 90's
    Gary Jr likes this.
  25. Wheeliedave
    Wheeliedave
    Thanks Pete! I'll keep watching.
    Dave
  26. Pete
    Pete
    Sooo.... After a long nap were back on the roadster.
    Spent all day Thursday getting the body secured and squared to the frame. Since the rear of the frame is pinched and Z'd we had to re configure some of the rear mounts. Since the rear of the frame is Z'd I had to make a portion of the sub rails to re connect the area that was removed for clearance.
    I made rear frame extensions to secure the rear of the body to, as an xtra precaution I boxed each end of the rear cross member to minimize flex.
    These bodies are super flimsy so we added an X stiffener that allowed us to get the quarters moved where they kinda should be.
    slv63 likes this.
  27. Pete
    Pete
  28. Pete
    Pete
    I thought about removing the entire rear '32 sub rails but decided to just modify the "ramp" by extending it to reach the X brace.
  29. Pete
    Pete
    image.jpeg Mike started cutting holes in the brookville floor for the master cyl, shifter and column.
  30. adam401
    adam401
    Looks good Pete. Nice to start with a body that you dont have to build from 3 new england wrecks then weld the bottom 6 inches on haha
