Folks Of Interest The Glory that is the Hemi, picture thread
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Sep 11, 2018.
  1. Jalopy Joker
    Jalopy Joker
  2. 402BOSSMAN
    402BOSSMAN
    The Truck and Industrial heads are what I prefer. The exhaust cross over already being plugged off in the casting is a major plus. Beats welding in plates for the exhaust crossover. Any 1954 and later 331 head is good just some want the water crossover of the 1955 331 Head (Triple Nickel/ #157 casting). Intake port wise all of the 54 and later 331 heads are the same. Next best is the 354 head and last is the 392 because of the turn it has to make into the cylinder. The 354 head can be made really efficient and what I recommend for many hot rod/street rod builds. The 331 heads are where the power is at!
  3. RichFox
    RichFox
    I poured aluminum in several Chrysler heat riser passages to block them, Other engines also. Did them for $25 a head. Much more easy to do and way cleaner than welding a plate in.
  4. classiccarjack
    classiccarjack
    I gotz two of Dem... Muhahaha!!!!
    But I need them.....
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
    chryslerfan55, Deuces and loudbang like this.
  5. bobbyoz
    bobbyoz
    from Australia
  6. willys36
    willys36
    I'm in awe!!!!
  7. willys36
    willys36
    Thanx for the info Nick. That confirms what I see. And yes the late 331 heads are where it is at with their better angled, shorter intake ports but a I said, finding them is the challenge!!
  8. classiccarjack
    classiccarjack
    It's taken me 3 years to find 3 sets of the 1955 & 1956 heads... AKA "555" & "619"'s.... The one year only big port 1954 331 heads are tough to, just like the 4 BBL intakes. But what are you going to do? Spend $5K on a set of Aluminum Hot Heads? Not that they aren't the cat's meow, they are truly bad****! But I am no Warren Buffet!!!!
    chryslerfan55, Deuces and Flogknaw like this.
  9. classiccarjack
    classiccarjack
    chryslerfan55 and Deuces like this.
  10. 1947knuck
    1947knuck
  11. lilmann
    lilmann
    Howdy, I’m not wanting to turn this into a “hemi how to” thread because these pictures and info are amazing! But wanted to ask for some advice....
    I have a 392 complete motor, number stamped NE57 single 4 barrel. What I’ve heard is the 331 head is better and I have access to a pair of 1955 15561571 heads. Should I jump and purchase them?
  12. slayer
    slayer
    Are you building a competition motor or something hot for the street? If you are't trying to squeeze every last ounce of power out of your 392 I wouldn't spend the extra money on different heads.
    For more information on Hemi's look here. http://www.jalopyjournal.com/forum/threads/hemi-tech-index.118764/
  13. classiccarjack
    classiccarjack
    If you use those heads, you will need a adapter for the intake and also the water tube... Once that is done, you can port that 1955 head and make that 392 gain more flow.
  14. classiccarjack
    classiccarjack
    Perhaps I shouldn't say water tube... But you know what I mean...
    chryslerfan55, lilmann and loudbang like this.
  15. Brand Apart
    Brand Apart
    from Roswell GA
  16. bobbyoz
    bobbyoz
    from Australia
  17. 1947knuck
    1947knuck
  18. Jalopy Joker
    Jalopy Joker
  19. loudbang
  20. foolthrottle
    foolthrottle
    When you think of hemis, I'm pretty sure the v8-60 based Ardun or the Daimler sp250 don't come to mind. Wasn't there a Honda Hemi?
  21. HellsBells5
    HellsBells5
  22. 1947knuck
    1947knuck
  23. Flogknaw
    Flogknaw
    from Texas
    Well sadly my small block forum was taken down for O/T stuff that I didn’t have time to notice, so guys! Please keep this stuff On Topic If you aren’t, it’d mean a lot to me considering this is the biggest forum I’ve got.
    chryslerfan55, loudbang and j hansen like this.
  24. 1947knuck
    1947knuck
  25. LOU WELLS
    LOU WELLS
    from IDAHO
    1932 Ford Coupe With Dodge Hemi... 12631433_10201408734256054_6590245163556927675_n.jpg
  26. lilmann
    lilmann
    No competition stuff just a good street hot rod...but...I’m leaning towards a blower. Is it worth it if using a blower..??..and Classiccarjack is saying an adapter is needed......is that all possible with a normal blower manifold + the adapter? Or am I spending $1000’s for 25 extra hp?
  27. 1947knuck
    1947knuck
  28. loudbang
  29. willys36
    willys36
