Customs The heat soak starter in the Impala problem solved.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Oct 23, 2025.
  1. flynbrian48
    flynbrian48
    Since August the Impala has been hard to start with the engine hot, as if the starter were soaking heat and dragging. This is a pretty common problem with Chevrolet engines with headers that are tight to the starter. Until the other day when I drove to the hardware store for something it’d start after setting for 5-10 minutes, but this time we couldn’t even jump it.
    I was going to get a gear drive starter for it, but thought I’d first make a heat shield and/or wrap the head pipe, so this morning I went out and got under the car. The head pipe is less than half an inch from the starter, making wrapping it tough, and there’s no way at all to get a heat shield between the two.
    After I finally got the pipe wrapped I tried starting it, and it wouldn’t start, turned over very slowly a couple times then nothing. Battery, two years old, showed 14.26 volts resting. I had just put a battery in the T’bird project so I swapped them out.
    The 454 lit right up. What?
    I took its battery to O’Rielley’s to test it , and sure enough, failed a load test.
    6 days past its 24 month warranty date.
    Happily they replaced it anyway, so I’m glad for that. IMG_4254.jpeg IMG_4254.jpeg
  2. Clydesdale
    Clydesdale
    So it wasn't a heat soak issue at all.
    Definitely another lesson in addressing the basics first, the amount of times folks jump into electrical faults without checking Battery, Fuses and Grounds first is crazy.
    Glad you got it sorted!
  3. Jmountainjr
    Jmountainjr
    It's a bit of a drive to a parts store for me so I find the small investment well worth it.
  4. flynbrian48
    flynbrian48
    I should have figured this out sooner, just based on the symptoms, but at least I didn't spend any extra $$ on a gear drive starter and wasted a day dropping the exhaust to put it in. :rolleyes: In my defense, the 4 or 5 times when it didn't start when warmed up, it did after a few minutes to let it "cool down". When it wouldn't start with a jump the lightbulb came on. Dimly...
    X-cpe and winduptoy like this.
  5. RodStRace
    RodStRace
    Yes, that first bit of any electrical testing
    "With a good, fully charged battery,"
    carries a LOT of weight!
    Glad you got to the root cause and got it warrantied.
    X-cpe and ClayMart like this.
  6. RodStRace
    RodStRace
    57Fury440 likes this.
  7. Bandit Billy
    Bandit Billy
    I went to NAPA a few weeks ago to replace a battery of theirs that failed in my dune buggy. It was a "5 year" battery that I bought 3 years ago so I figured it would just be replaced. I wasn't aware that the "warranty" doesn't cover replacing the battery per se, I got a credit for 2/5ths of the price of what I paid for it (minus the sales tax). Of course, the price of batteries is greater now than three years ago, so I got like $30 off the new battery, paid my taxes again and charged a $5.00 disposal fee for the old battery. And they want us driving electric cars? :cool:
    Rant over, sorry B, gad you mixed the impaler. You should call it Vlad.
    i.rant, Hotrodmyk, Butler 32 and 2 others like this.
  8. garyf
    garyf
    This is a way to check a battery until you buy a load tester.
    If you have removable battery caps, remove them all have someone crank the eng. over until it is struggling to turn over. While someone is cranking you are watching all the cells in the battery if you see some or one of them boiling,the battery has a bad cell and needs replacement. Protect your face and eyes when working on a battery.
    tractorguy likes this.
  9. Budget36
    Budget36
    There is a (imo) better one to get. I went to AZ in my driver last year because I could only start the truck with the charger on it.
    The guy came out with a small meter-thing. Hit a ****on, small wires so very little load, and said “yep, bad battery, only has a surface charge”.
    How that little meter thing tested that the battery couldn’t take a load, I don’t know.
  10. RodStRace
    RodStRace
  11. ClayMart
    ClayMart
  12. ClayMart
    ClayMart
    I remember years ago being taught in auto tech cl***es that auto batteries had two sorts of voltage ratings; "surface" voltage and "deep" voltage.
    It was common for a nearly dead battery to still show 12v to 13v when tested with a simple voltmeter. The voltmeter put barely any load on the battery to determine this reading and essentially only indicated that the battery wasn't completely dead, or that in fact it was a 12v instead of a 6v battery.
    A load test is the most accurate way to check real battery health. A given amp load is placed on the battery for a specific time and the voltage is monitored. A good battery will still show maybe 10v to 12v while a battery on its way out may only show 4v or 5v, or even less.
    When doing any diagnostic work we were always encouraged to "knock off" any surface charge before continuing by quickly putting a couple high load cycles on the battery with the tester. Doing this with a load tester was a quick way to determine whether you should continue your diagnosis or not, especially with higher amp load circuits.
    flynbrian48 and RodStRace like this.
  13. pprather
    pprather
    So, heat soak is still present. A great battery can overcome it. A weak battery, maybe not.
    Does the battery ground bolt to the engine?
    When I had minor heat soak problem, moving ground cable from fram to engine solved it forevermore. Same battery.
  14. RAK
    RAK
    When I put the SBC in my 40 Ford I not only wrapped the exhaust pipe next to the starter but also put a DEI insulation heat shield on the starter. As hot as it gets down here I've never experienced a hot start problem. It is flexible and you could squeeze it on there I think.
  15. flynbrian48
    flynbrian48
    Ground to engine block, second ground from block to core support. It wasn't not a ground issue. There's absolutely no room for heat shield, there's less than 1/2" between the exhaust head pipe and the starter, and it runs the full length of the starter. It never was a heat soak problem, it was a battery failure. I drove the car today, it cranked and started every time, cold or hot. It's got a Ford solenoid on the firewall from the previous owner/builder. It's all better now, and O'Rielley's was great about exchanging it out of the 2 year warranty, no core charge either. Well, I did leave the failed one so, it wasn't an issue.
    Bandit Billy, loudbang and pprather like this.
  16. flynbrian48
    flynbrian48
  17. flynbrian48
    flynbrian48
    Removable batter caps? I haven't seen a battery with those for 30+ years. ;)
    Bandit Billy and Black Panther like this.
  18. VI Lonewolf
    VI Lonewolf
    From the motorcycle world just put a volt meter on the battery and hit the start ****on. If it drops to 9+/- volts buy a battery.
  19. garyf
    garyf
    I own vehicles with a total of 10 batteries,,all have removable caps. all batteries less than 5 yrs old.
    jimmy six likes this.
  20. lo-buk
    lo-buk
    from kcmo
    I had a problem like that years ago and I took the starter off, cleaned and painted it with vht white paint and it cured the problem.
    atch likes this.
  21. I had the same problem on my 27 track roadster 327/350, after batteries and starters I finally replaced my old cables with 00 , problem solved.
  22. 409 Bob
    409 Bob
    Hi Folks,
    My two cents:
    When I worked at Chevy in 1978-82, they had a kit for heat soak. It put that "Ford" solenoid inline with the purple wire to the starter, with a jumper straight from the battery lead. Full battery voltage without going through the ignition and neutral safety switches. #8 or #10 wire.
    Bob
  23. deucemac
    deucemac
    I have been through this lots of times in my life and found the perfect solution. Take the Chevy starter and jumper from the battery stud to the start pole. Then install a Ford starter relay in line. Run the wire that used to be at the starter to the terminal on the Ford relay. Run a starter cable to the solenoid on your starter, to tgebFord solenoid. And of course run the power cable to the other side of the solenoid. I did this lots of times without problems. Ford did just what I described in the early 70s-late 60s , to the factory 429/460 Thunderbirds at the factory. I did the conversion to my own 68 El Camino over thirty years ago and not one hot start problem! I am running headers that come very close to the starter and have never had a heat related problem since I inherited the truck after my father's p***ing. I have also done the conversion to many friend's cars without further starting problems. From dead stock to all out racer, never a problem and I used the stock starter, not some high zoot over priced starter and always been successful. It's cheap and it WORKS!
  24. Adding to 409 Bob’s post.
    I was in GM parts departments from 1970-2017. Around the 1981-82 ear GM also released a new solenoid plunger spring,1978281. Less effort for engagement. Google GM 1978281 and you will see stuff come up on this, a thread in Nasty Z28 from 2015 addressed this.
    I used those often. We rebuilt our own starters and alternators in the service department as the quality of remans left much to be desired even back then. I e em stocked a couple of the most common armatures if there was one we couldn’t save.
    Fun side story here. Small town New Mexico, I was also a Firefighter/EMT there. Fire Chief was complaining about the G30 Chevy van ambulances and how the crews were getting stuck in the city and or tow bills due to hot soak. Since I just received my EMT license I was now part of that circle. And how many starters they had replaced to no avail.
    I told the Chief “I’ve got a fix”and his reply “So has everyone else in town.” So we had a little test. That evening after work the Chief and I met at the main station. In the bay I dropped the starter checked the wiring (two year old “rig”), pulled the end plate off, all looked good. Pulled the solenoid, there was differences in the OE and the 1978281 back in and as fate struck, interhospital transfer to Abq now. Told the crew. “ When you radio 10-36 (time check) at leaving Pres (hospital) let the dispatcher know how it works.
    So now we’re sitting at the station about two hours, long enough to pick up the patient, go to the city, leave it hot soak at the hospital and restart. When the crew called in (***istant Chief was on it, we had working officers) The radio call went something like Rescue 12, 10-36, enroute back and it started!
    I looked at the Chief and said “I told ya so but you didn’t believe me!”
  25. Jay McDonald
    Jay McDonald
    Harbor freight load tester, like 18 bucks, find myself grabbing it all the time, it is also an easy to read volt meter, didn't even know that I needed it and now I couldn't go without it.
    RodStRace likes this.
  26. Bandit Billy
    Bandit Billy
    My Olds was a horrid hot start POS mess at one time. I moved the battery to the trunk, added a ford style solenoid in the trunk, put a high torque stater on it, wrapped it with a heat shield that looks like NASA had a hand in making, installed a one wire 130 amp alt, added ground straps to the starter mounting bolts as well as the block and transmission and it never had another issue. It's an 11:1 455 and it takes a bit to crank her up with 20/50 in the case. Been 15 years now, I don't even keep it on a battery tender on it all winter, starts every time. I have a horrible habit of getting pissed and throwing parts at things but it worked. Glad your issue was a simple and less costly one.
    When you headed back down to Florida!?
  27. flynbrian48
    flynbrian48
    We just got here.
    Bandit Billy likes this.
  28. Bandit Billy
    Bandit Billy
    I read a post yesterday about the crazy drivers in Florida and wondered if you had shown up already :cool:
  29. onetrickpony
    onetrickpony
    from Texas
    Over the years, I have seen several hot start problems blamed on heat soak that turned out to be the missing support from the end of the starter to the block. That little bent angle that goes on the threaded stud at the starter and reaches to a hole in the block. It's a pain in the rear to install, but it keeps the gears from binding when the aluminum nose housing flexes when it gets hot.
    teach'm likes this.
  30. 57Fury440
    57Fury440
    That pipe is close. I would make a nice heat shield.
