Technical The Hell Does It Belong To?
Discussion in 'The Hokey Ass Message Board' started by Pass The Torch, Oct 28, 2025.
  1. Pass The Torch
    Pass The Torch
    I know the "who" (me), but what does this spare tire carrier fit?
    I have this orphan spare tire mount that needs to be identified. Hoop is 17" (For an 18" rim). It has the round hole for the valve stem, and a slot for the lock lever of a split rim. Legs are 21" across at the mounting holes.
    Closest I was able to find was '31 Buick, although I did find an Olds that was equally similar; neither took the proverbial cigar.
    lostn51 and chryslerfan55 like this.
  2. cfmvw, lostn51, jet996 and 2 others like this.
  3. Pass The Torch
    Pass The Torch
    Well, he didn't so it's not...!
  4. lostn51
    lostn51
    from Tennessee
    You might need to start checking out the independent makers. It could be anything from the 20’s to 30’s and more than likely a higher end car like the 3 P’s or something similar
  5. Pass The Torch
    Pass The Torch
    Not many used the wedge retainer, and the size of the rim does narrow it down considerably. I can say with certainty what it is NOT! That list is growing too. Wood spoked for sure.
  6. dwollam
    dwollam
    Garden hose rack!
    Dave
  7. 5window
    5window
    Ask the man who owns one?
  8. Mr48chev
    Dodge did use that style of rim in 28/30 or so but the way the spare mounts on the bracket looks different. Screenshot (1514).png
  9. Pass The Torch
    Pass The Torch
    Yeah, a ton of them are similar, the one in the top pic is even different than the bottom one. And the search goes on!
